2rz swap - engine harness plug id - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2016, 09:05 AM   #1 (permalink)
Member # 190076
I have a 2rz from a 96 2wd tacoma.
Can anyone help me id these plugs? I have the fsm for the recipient truck, but not much for the tacoma.
From driver side
From driver side
From driver side
From Passenger side
From passenger side
From passenger side
From passenger side
Appreciate any help
BazookaBoy is offline   Reply With Quote Quick reply to this message
Old 08-14-2016, 06:45 PM   #2 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
I have the same setup. I can look tomorrow. Do you have the fuse panel, mounts drivers side engine compartment, there is also a panel that mounts inside drivers kick panel.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 08-14-2016, 07:53 PM   #3 (permalink)
Member # 190076
Yes I have everything.
Truck was an 89 3.0 5 speed
Tacoma was 96 2wd 5 speed
You have this same setup?
Old 08-14-2016, 08:47 PM   #4 (permalink)
Shift to the Best
Member # 68266
96 2wd 5spd harness, complete in my 83 truck headlights to tail lights.
Old 08-15-2016, 09:03 AM   #5 (permalink)
Member # 190076
If you happen to have your notes for the Tacoma end of the wiring that would be useful, but other than that im trying to avoid a complete rewire of the truck.
I want to retain as much of the old trucks wiring as possible. Just splice into it enough to run the motor.
Old 08-15-2016, 10:26 AM   #6 (permalink)
Shift to the Best
Member # 68266
I kept none of the original wiring, a complete use of the Tacoma only. I use the Taco, column and instrument cluster. I am heading out to look at my truck now.
Old 08-15-2016, 11:27 AM   #7 (permalink)
Shift to the Best
Member # 68266
From what I can tell both of those plugs should be in the cab and connect to the interior dash harnesses.
