1 ton taco truggy build up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2008, 12:40 PM   #1 (permalink)
Member # 2115
ok, so i think i got enough to start showing some progress, i don't have too much time so this is a slow process.
the basics...
d60s front and back
5.38 gears
detroit front, welded rear.
DIY beadlocks
ADS coilovers front
Fox airshocks 2.0 rear
tube the rear of the taco
full hydro
36" iroks (for now)
if i have time and $ i would like to make a new dash with gauges etc (last option after everything else is running and working).
I think that's if for now.
first off, removing the tired D44
clean up and reinforce the frame...
find a donor vehicle for the d60s.....1979 f250, front HP kinpin. took forever but i finally found one.
take the axle from the truck and clean up time, lots of rust but all the bearing and shafts look really good considering how old this truck is.
parts start showing up...
neighbord helping out a lot.
couple accidents here and there...
1 ton '48 Willys in progress
alienjeep is offline   Reply With Quote Quick reply to this message
Old 01-11-2008, 12:58 PM   #2 (permalink)
Member # 2115
more pics...
got some tubing and a new DD, 03 dodge dually, 6sp,4x4!!!
so i really like ballistic's tacoma so i'm going to do the back of mine just like theirs, sure not as nice but somewhat like theirs, that taco just rocks!!!
Old 01-11-2008, 01:09 PM   #3 (permalink)
Member # 2115
rear disc brake brackets
trying to find out how are we gonna do this
got some stuff from ballistic
beadlocks
Old 01-11-2008, 01:23 PM   #4 (permalink)
Member # 2115
Old 01-11-2008, 01:29 PM   #5 (permalink)
Member # 2115
that's where i am so far. more pics later.
Old 01-11-2008, 03:12 PM   #6 (permalink)
Member # 2115
i had to sell my Z so i could have some $$$ to finish my taco.
Old 01-11-2008, 03:27 PM   #7 (permalink)
Member # 2115
more goodies...
psc orbital
highangle flanges
sandblasted all my brakes but i might need new calipers on the front.
grinded down my rear calipers so my rims fit
Old 01-11-2008, 04:32 PM   #8 (permalink)
El Presidente
Infernal Jeep's Avatar
Member # 38540
Looks Good,can't wait to see it done!!
TTC 2013 ! ! ! - THANKS FOR THE SUPPORT EVERYONE ! ! !
BRAWLERS* So-Cal
Fifth annual SoCal Off-Road Truck Show . Coming 2013 .
Infernal Jeep is offline   Reply With Quote Quick reply to this message
Old 01-11-2008, 05:46 PM   #9 (permalink)
Member # 89235
Send a message via AIM to kschaper Send a message via Yahoo to kschaper
Looks good. If you want to put your axles under my yota, I'm right here in s. elgin.
kschaper is offline   Reply With Quote Quick reply to this message
Old 01-11-2008, 07:34 PM   #10 (permalink)
Member # 2115
thanks man, your yota its pretty kick ass too, i saw the build up threat and its niiiiice! love the color.
sure bring it over, leave it in my garage for a little while and i'll take good care of it
Old 01-13-2008, 09:48 AM   #11 (permalink)
Member # 2115
bolting down the beadlocks, this is going to take awhile!!!
this might take too long!!!
gotta get help!!!!
Iroks look sooo fat!
Old 01-13-2008, 09:51 AM   #12 (permalink)
Member # 2115
started grinding down the front calipers
took a little long but we got it. before and after...
Old 01-13-2008, 07:46 PM   #13 (permalink)
Member # 37026
nice work i liked the rear of ballistics truck to. looks like your running 42's on that? also what BS wheels are you using?
[COLOR="Red"]ECV 7-11[/COLOR]
KYOTA Forever
kiyul4130 is offline   Reply With Quote Quick reply to this message
Old 01-13-2008, 07:53 PM   #14 (permalink)
Member # 2115
thanks man.
no, for right now i got to keep running my 36s iroks, not enough cash to buy bigger ones.
Old 01-15-2008, 04:20 PM   #15 (permalink)
Member # 2115
ordered a new battery, this are supposed to be the shiat!!!
Old 01-15-2008, 10:22 PM   #16 (permalink)
Member # 2115
progress tonite, not much but some.
plated the back end and mounted the lights...
made the orbital bracket
welded
set up steering
Old 01-16-2008, 05:03 PM   #17 (permalink)
roctaco's Avatar
Member # 69496
Are you locating the "orbital valve" near where your old steering box was for any specific reason? If I ever get around to doing my SAC I was wondering if I could use my stock steering linkage and not have to make a new linkage or mess with modifying the plate on the floorboard that it passes thru. I plan to do full hydro steer on mine as well and thought maybe I could mount the orbital in line with the stock linkage. I'm jealous of your build & look forward to seeing the finished product.
'96 taco mall crawler on tons
roctaco is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 05:44 PM   #18 (permalink)
Member # 2115
thanks for the compliments man.
the reason i'm keeping the orbital valve there is because i was running hydro-assist before so i can use the hoses that i had then. i would like to run the orbital closer to the firewall so there is less stuff under the hood but then i would have to buy the new hydro-lines and they are pretty expensive and i can't affort it right now. ideally would be to mount the steering wheel to the orbital and that's it, like the comp buggies. but you can do what i'm doing re-using your excisting steering.
do you have a link for your build?
just get this from polyperformance the one for imports and it would bolt right up to your current steering shaft.
Old 01-17-2008, 05:13 PM   #19 (permalink)
roctaco's Avatar
Member # 69496
thanks for the info. on the orbital setup. I don't have a build thread since all I've done so far is swap in the rear 60. Unfortunately the truck has become my DD again & an empty wallet is preventing further progress. I will likely add some sort of rollover protection before doing the SAC, since my wife hates that I have to drive our son in it, even though he's never been off-road & I've never rolled it....women.
Old 01-17-2008, 05:16 PM   #20 (permalink)
Member # 2931
great build! i especially like the tubework on the rear section
[B][U][I][COLOR="Red"]Www.4wheelunderground.com[/COLOR][/I][/U][/B]
Booger Weldz is offline   Reply With Quote Quick reply to this message
Old 01-17-2008, 08:35 PM   #21 (permalink)
Member # 2115
thanks man specially since it was my first time bending tubing.
Old 01-18-2008, 04:18 PM   #22 (permalink)
Member # 75648
Why do you have to steal my idea of stealing the Ballistic Taco's bed
sellout
TachedOutOffRoad is offline   Reply With Quote Quick reply to this message
Old 01-18-2008, 05:07 PM   #23 (permalink)
Member # 2115
cause you are moving too slow
Old 01-18-2008, 07:39 PM   #24 (permalink)
Member # 23506
You better get a job soon.... you are making way too much progress! Looks good!
97 Tacoma Truggy, Rockwelled on 42" TSL's
1970 M35A2 Deuce and a Half 6x6
00 Chevy silverado 2500 4x4 tow rig
SWAMPZR2 is offline   Reply With Quote Quick reply to this message
Old 01-18-2008, 08:44 PM   #25 (permalink)
Member # 2115
thanks, i think i'm ready for the links now!!!
