Toyota Racer #4611: KOH Stock Class Build - Page 28 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-26-2016, 06:13 PM   #676 (permalink)
Member # 166048
Josh Roach
[COLOR="DimGray"]99 4runner 3.4 5spd boosted and locked
79 pickup 2rz, w56, dualed, e-locked, caged and injected :smokin:[/COLOR]
Build Thread-ish
jroach3210 is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 06:23 PM   #677 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Charlie Wenzel..........
MY BUILD
04 Rubicant Ultra4
My precious.... 72 K5 Blazer
web wheeler...
DJ404564X4 is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 06:37 PM   #678 (permalink)
desertPOS's Avatar
Member # 3835
Yours I already know...
If that's what you want it to say though
Special Thanks to:
, West Kern Environmental Consulting,
desertPOS is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 07:22 PM   #679 (permalink)
Member # 40301
Kris Scrivens
You can't believe everything you read on the internet. That is how WWI got started.
trialsintrigger is offline   Reply With Quote Quick reply to this message
Old 01-27-2016, 10:51 PM   #680 (permalink)
Member # 203479
Well...back to the Livestream I go.
I can't afford to go because I gave all my lunch money to you Chris so you can race
Shit kidding. Plans didnt work out, so i'll just have to stream it
Toyota.
83' Pickup 4WD,81' Pickup 4WD,92' Pickup 2WD
UndefinedTaco is offline   Reply With Quote Quick reply to this message
Old 01-27-2016, 11:56 PM   #681 (permalink)
Member # 41156
Bah...went to a great cause
'00 SA Tacoma with a few mods
'00Tacosinger is offline   Reply With Quote Quick reply to this message
Old 01-30-2016, 01:50 PM   #682 (permalink)
desertPOS's Avatar
Member # 3835
Well, quick update. Felt like taking a step forward and two steps back for a day or two there, but had to redo a couple things.
When I had my axle apart a couple weeks ago, found a broken tooth on the rear ring gear, and a funky wear pattern. Apparently it's not good for the r&p to drive with low or no oil in the diff
Put the axle all together and was just going to run it for trail riding, but as soon as it was clear that we were racing, I knew I needed to deal with it. Send the diff off to Yotamasters - they got it set up with a new r&p in record time, and my brother picked it up from them yesterday morning and brought it up. Also picked up a new set of front springs, bushings, and front axle rebuild kit with some new wheel bearings.
Rear axle is all reassembled and done. Next setback was checking fluids in the tcases/tranny - rear tcase drainplug/oil was nice and clean, no metal. Front tcase drainplug was COVERED in steel shavings, and had large flakes mixed in the oil
So, tcases had to come out.
One of the bearings was eating itself alive in there. Luckily I had a replacement bearing right there in the shop, swapped it out, and got everything back together...
Tcases are all back together, reinstalled in truck, filled with oil and DONE. Spent some time cutting welding shifters so their a little more ergonomic to use - was a pain in the ass shifting them last year. Little things...
Took both driveshafts apart, cleaned all old grease out, filed any burrs or rough spots on the splines, and put back together with fresh grease in the splines and pumped some grease into all the ujoints.
Got belly skid back on, rear dshaft installed, tracbar installed. Tracbar will be seeing some modification today, then just have to rebuild front axle and get the new front springs on... Looking good, and feeling good after getting RA/tcase issues dealt with
Special thanks to Yotamasters for the super fast turnaround on my diff and other parts. They even through in a set of Old Man Emu bushings for the front - apparently they're the shit
Special Thanks to:
Old 01-30-2016, 02:06 PM   #683 (permalink)
rugburn's Avatar
Member # 45
Kick ass update.
When are you hitting the road ?
John Runberg
Swedish American :usa:
rugburn is offline   Reply With Quote Quick reply to this message
Old 01-30-2016, 02:20 PM   #684 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
nice
Old 02-01-2016, 05:31 PM   #685 (permalink)
Member # 19077
You are going to like those OME bushings Chris. They are better than any others we have used. Good luck. See you thurdsay.
yotamasters.com
Max Volume is offline   Reply With Quote Quick reply to this message
Old 02-02-2016, 04:20 AM   #686 (permalink)
desertPOS's Avatar
Member # 3835
They seem a lot 'harder' than the normal bushings - I like that. We'll see how they do. Last year the only thing in the front spring eyes was a bolt and air - no bushing to be found. We'll see how these do
I don't have much in the way of pics, but thought I'd update. I'll have a better update later today. Other than throwing some nitrogen in the rear shocks, suspension is 100% done.
Tracbar was under an extreme amount of tension, and I think it was causing the rear springs to not be able to cycle the way they should, and wear out more quickly. Decided to make a little tweak:
No finished pics, you'll just have to use your imagination
Biggest things left to do are bleed brakes, and replace valve stems in 3 more tires. Then just a lot of little things. Should be loaded on the trailer and KOH bound late tonight or early tomorrow morning
Originally Posted by SMKYTXN View Post
And I was serious about sending some of my magnetic koozies your way. PM me your addy when you get a chance.
Magnetic koozies from Trail Toys | Trail Toys
Thanks! They don't seem strong enough to hold a beer to the dash while racing, unfortunately, but are a big hit in the shop
Special Thanks to:
Old 02-02-2016, 05:37 AM   #687 (permalink)
YANHFUYAB
SMKYTXN's Avatar
Member # 463786
Glad to see you're getting some use out of them. Good luck getting things wrapped up and out the door.
And the electromagnet version of the koozies was tossed due to high battery drain.
SMKYTXN is offline   Reply With Quote Quick reply to this message
Old 02-02-2016, 02:40 PM   #688 (permalink)
desertPOS's Avatar
Member # 3835
Steeker update! I was slightly sleep deprived and in a rush to get this made - if I left anyone's name off the list I sincerely apologize. Post up, and I'll write it on the hood:
I want a sticker on the truck that says
' "Fuck your buggy" - Justin '
You want it you got it. I tweaked it a bit though...
Special Thanks to:
Old 02-02-2016, 02:47 PM   #689 (permalink)
Member # 203479
HOLY FAWK...I am dying of laughter at work and people are staring at me thinking I'm crazier then I already am
That is AWESOME!!
Fuck yeah can't wait till Thurs to watch now
Toyota.
Old 02-02-2016, 02:54 PM   #690 (permalink)
Member # 19077
I need the Ricky sticker!!!!
yotamasters.com
Old 02-02-2016, 02:58 PM   #691 (permalink)
YANHFUYAB
SMKYTXN's Avatar
Member # 463786
That's awesome!
Old 02-02-2016, 02:58 PM   #692 (permalink)
NwiTACO's Avatar
Member # 145042
Nice!
My 2005 Tacoma SAS:
NwiTACO is offline   Reply With Quote Quick reply to this message
Old 02-02-2016, 04:08 PM   #693 (permalink)
Member # 41156
Awesome! love it!
Old 02-02-2016, 06:12 PM   #694 (permalink)
Member # 143131
Wish I was seeing it in person.
xj chopper is offline   Reply With Quote Quick reply to this message
Old 02-02-2016, 07:27 PM   #695 (permalink)
Member # 166048
Shit yea!
Build Thread-ish
Old 02-03-2016, 06:35 AM   #696 (permalink)
rugburn's Avatar
Member # 45
Good Luck out there !!!!!
John Runberg
Old 02-04-2016, 09:15 AM   #697 (permalink)
desertPOS's Avatar
Member # 3835
Ready for battle...
Special Thanks to:
Old 02-04-2016, 09:28 AM   #698 (permalink)
YANHFUYAB
SMKYTXN's Avatar
Member # 463786
Good luck!
That was Chris starting in the 2nd to last group, correct? I'm not seeing 4611 on the live tracker though.
Old 02-04-2016, 09:57 AM   #699 (permalink)
Member # 140656
Good luck!
Same. They're not popping up on live tracker. I saw them take off. What happened to your tracker?
Pirate Joe is offline   Reply With Quote Quick reply to this message
Old 02-04-2016, 10:15 AM   #700 (permalink)
YANHFUYAB
SMKYTXN's Avatar
Member # 463786
At least we know he's out there!
