Anyone put together a Rock Assault housing from TG? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2011, 02:25 PM   #1 (permalink)
dntsdad's Avatar
Member # 125937
Couple of issues. I have the Elocker flavor.
First, the 3rd is nowhere near fitting to drop into the axle as the stud splay is way off. I guess I could knock the studs into "place" with a mallet or put a nut on them and hit with a hammer. Anyone ran across this? What did you do to remedy?
Second, I have heard report of the rear spewing gear oil from the breather, on the rears especially. Anyone have this issue? I was thinking of adding a baffle around the breather. Again, anyone do this and maybe have a picture of what you did and your success in not having a gear oil leak.
dntsdad is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 03:05 PM   #2 (permalink)
91norcalcrawler's Avatar
Member # 140406
Yea they are mass produced and the stud alignment is usually screwed just be happy you checked before applying silicon just wack the studs a bit unroll it goes on smooth I don't know about the breather problem but your idea sounds good
91 Toyota pickup turbo re locked longs tubed 39.5 iroks RIP
92 extra cab project inspired by 91
91norcalcrawler is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 05:28 PM   #3 (permalink)
Member # 181071
Friend of mine has problems with the rear TG housing spitting gear oil. Extended the diff breather with some hose and then it started blowing axle seals. We saw a couple of the TG guys at the Rubithon and talked to them about it. Basically you need to fix it yourself is what they said.
toyotathomas is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 05:38 PM   #4 (permalink)
dntsdad's Avatar
Member # 125937
I know that its shitty to have to fix yourself but at this point I dont mind since its new in the box. If it all assembled and on the raod I'd be more upset.
Did they suggest anything to "fix" it?
Old 12-30-2011, 07:14 PM   #5 (permalink)
94toytruck's Avatar
Member # 18614
Sell it and get a Diamond axle
Someone had to say it
Eric
94toytruck is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 07:28 PM   #6 (permalink)
Member # 85972
by breather are you talking about the bellow thing that expands? those dont do anything but create PRESSURE after absorbing about 1% of what the axle produces. they create enough pressure to douche your face with hot gear oil at 2am on the side of the highway. run a hose up to a valve cover filter at the frame and you'll be golden.
I'm not on Pirate much anymore, but you can find me on here-
And yes I still have lots of build parts for sale! New website coming soon!
billybob13 is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 07:29 PM   #7 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I had to knock mine into place with a brass hammer.
Mine has not done it but if it did I was going to plug the hole and install a bung in a difference spot.
Old 12-30-2011, 08:10 PM   #8 (permalink)
popeye
yotee's Avatar
Member # 20027
i bought a diamond, my third dropped rite in like the og housing
Its a jeep, sand it with a brick- paint it with a broom
yotee is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 08:26 PM   #9 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Brian is a little more anal about his products then TG is!!!!
Old 12-30-2011, 09:03 PM   #10 (permalink)
Member # 166048
Had the same issue with mine. Two of the studs even came pre bent for me!
[COLOR="DimGray"]99 4runner 3.4 5spd boosted and locked
79 pickup 2rz, w56, dualed, e-locked, caged and injected :smokin:[/COLOR]
Build Thread-ish
jroach3210 is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 09:49 PM   #11 (permalink)
Jason4x4's Avatar
Member # 104033
I just drilled all the holes on the third a hair bigger then stock, and they fit.
I put
until I can take the third back out and weld a baffle under the hole. I also considered drilling a new hole off to the side, and putting a plug in the original and running the breather off the new one.
Jason4x4 is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 09:58 PM   #12 (permalink)
O-ring Technologist
friggnxj's Avatar
Member # 62564
Your location says Fresno. Why not drive over to TG and have them answer your question? Maybe they can finally get around to fixing to what seems to be a common problem.
You don't have a clue so shut the mother fuck up.
friggnxj is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 03:22 AM   #13 (permalink)
Member # 36308
I have a taco width TG rear housing on my truck that I DD and I haven't had any problems with it puking gear oil. I ran a breather hose up to the frame, stay away from the stand alone type. I had to tap the third with a dead blow to get it to seat, didn't take a lot though.
chromewontgetyouhome is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 05:03 AM   #14 (permalink)
CronusTRD's Avatar
Member # 11141
i have a taco elocker housing. no issues on assembly, and I am using a stock taco breather since my muffler is right above the center pumpkin.
Mike
CronusTRD is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 05:20 AM   #15 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
don't say anything bad about these housings... or you may have the same fate as Rick
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 08:09 AM   #16 (permalink)
dntsdad's Avatar
Member # 125937
I am not saying anything bad about the housings and certainly not talking shit. Its a nice piece. I understand mass produced items can be a little off. Just seeing if smarter people than myself had another idea that I hadn't thought of
I am just looking to solve problems before they start since I am just looking to get the thing together and installed in the next month hopefully.
Thanks everyone for your thoughts
Old 12-31-2011, 11:20 AM   #17 (permalink)
Member # 163057
i had to knock mine in. i didnt put enough silicone on though so im going to have to take it apart again and im planning on drilling out the 3rd and making some more room for the gears. luckily im in no hurry to go out or id be more mad
laskt9 is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 11:26 AM   #18 (permalink)
Member # 132064
What fittings have some of you used to bring you breather up to the framerail?
Redfin is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 11:42 AM   #19 (permalink)
TOYOTAPARTS's Avatar
Member # 61493
Originally Posted by Redfin View Post
What fittings have some of you used to bring your breather up to the framerail?
Toyota intake vacuum fitting.
Great deals on Toyota Parts: :
RCV 30 Spline axles FREE shipping.
Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs
TOYOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 12:28 PM   #20 (permalink)
Member # 6170
I too would say sell it and buy a diamond, but....
I don't have either housing, but after modding my stock rearend I had some breather issues too. If you could put a baffle in that will most likely help as the factory rearends come with baffles. On mine I had to just relocate my breather further away from the ring gear. The ring gear and carrier would essential coat the breather hole with oil and once the rearend got hot the change in temp would force oil and air out the vent. One other idea I thought of was to go to a bigger vent hose. I was using 1/4NPT fittings and 3/8" hose, stepping it up to 3/8NPT or bigger might make the vent hose less likely to "plug" with oil and allow the rearend to vent.
I'm surprised anyone actually uses those stupid bellows things.
Kevo
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 01-01-2012, 01:29 AM   #21 (permalink)
Member # 161484
Do you guys shave the bottom of your thirds so they don't hang down or do you leave them as is?
89 Toy Pickup. SAS, ARB, Detroit, 5.29 Gears, 4.7 Case, Corbeau's, Ram Assist.......
Max-Power is offline   Reply With Quote Quick reply to this message
Old 01-01-2012, 02:01 AM   #22 (permalink)
DWT
DWT's Avatar
Member # 19850
So if someone says something bad they will throw a tantrum and go through and delete most of the tech they had posted? I somehow doubt that...
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote Quick reply to this message
Old 01-01-2012, 08:23 AM   #23 (permalink)
Member # 136268
max p, I know what you are talking about and this is gona sound dumb but we cut a small triangle piece and welded it to the bottom of the housing so the diff casting wasnt hanging down. Just looked like it either needed shaved or needed a "ramp" to get rocks not to snag on it and possible break the casting. Kinda defeats the purpose of the shaved housing welding a 3/8" plate on but it looks right now and my buddy didnt want to shave the casting. My casting, on the other hand, is shaved down in that area and the seal surface is pretty thin but is working OK. I think shaving the casting would be more popular, but both work. Heck, most probably just let the rocks grind away the extra...
topolino is offline   Reply With Quote Quick reply to this message
Old 01-01-2012, 08:46 AM   #24 (permalink)
Member # 166048
^^ I didn't notice this till after I took mine for a shakedown run. Luckily I didn't break the diff lip off! I fell asleep last night contemplating how much material would be left if I shaved it off.
Build Thread-ish
Old 01-02-2012, 01:48 AM   #25 (permalink)
Member # 161484
I wish there housing was round enough that it didn't have the 3rd hanging down. I would lean toward welding a lip on the axle housing.
