4.7 or dual cases????? - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: what would you recommend
4.7 gear set 67 16.18%
dual cases 347 83.82%
Voters: 414. You may not vote on this poll
Old 01-15-2003, 10:29 PM   #1 (permalink)
TOY 2's Avatar
Member # 12800
I want to get a lower final drive on my toy but can't decide on the dual cases or the 4.7 gears???I can't afford both so that's not an option............What would you recommend and WHY?????
TOY 2 is offline   Reply With Quote Quick reply to this message
Old 01-15-2003, 10:35 PM   #2 (permalink)
Fueler's Avatar
Member # 13071
duals..
more gear selection
As long as there is still Beefaroni and Budweiser everything will be just fine.
Fueler is offline   Reply With Quote Quick reply to this message
Old 01-15-2003, 10:35 PM   #3 (permalink)
TNToy's Avatar
Member # 5776
No one who has gone dual cases has wished they'd done a 4.7 gearset instead. I challenge you to find someone who has done the 4.7 gears (like myself) and doesn't wish they still had access to a 2.28 low range from time to time.
Go duals.
Old 01-15-2003, 10:43 PM   #4 (permalink)
TOY 2's Avatar
Member # 12800
wouldn't it be alot cheaper to do just the gears????No driveline mods........
Old 01-15-2003, 11:15 PM   #5 (permalink)
SamuraiChris's Avatar
Member # 10560
Send a message via AIM to SamuraiChris Send a message via Yahoo to SamuraiChris
I say go Duals, yeah you gotta mess with the driveshafts, but you get that out of the way, that way when you are ready to add the 4.7s later on, all you gotta do is bolt them in and everything else is set.
SamuraiChris is offline   Reply With Quote Quick reply to this message
Old 01-15-2003, 11:42 PM   #6 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
More slection and if you have 4:70's in the rear case you can start it up, put it in lo-lo-lo get out and tell it to get in the shop, and it will drive itself there. Make sure you are there to stop it or it might end up in your bedroom!!!!!!
Old 01-15-2003, 11:57 PM   #7 (permalink)
Member # 14600
Go duals.
I installed 4.7s in my 85' and have never missed my stock low range (got four other gears besides 1st to choose from). If you don't want to go through the hassle of lengthening and shortening drive shafts, relocating shifters....... go with the 4.7s. It's a huge improvement over stock. But be prepared to tear your T-case apart. It's tedious work, but worth the effort. Makes your truck a total sleeper! I am considering doubling up though. You can never go too slow!
Oatmeal is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 12:15 AM   #8 (permalink)
Member # 5431
Send a message via AIM to ROCKPIMP
Go dual cases with a gear set and be done. that way you have low, low, and lower. Then why your at it you can get a long slip front drive line and a rear CV drishaft. Unless you are POOR and just want lower gears then get the 4.7's
Originally Posted by camo
that guy is a fawken pussy......if it was me i would have pryed the hacked off section of my arm out from under the boulder, made a fire and had a BBQ to feed my hungy belly before I had to hike out.
ROCKPIMP is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 12:53 AM   #9 (permalink)
Wilson's Avatar
Member # 7233
duals first and then gears. Diveline mods are not real expensive as long as you already have appropriate shafts ie long travel front (you should have thsi already) and a cv rear. Call Jess, tell him what you want/need, his prices are always fair.
Old 01-16-2003, 01:12 AM   #10 (permalink)
Member # 5431
You following me around, and posting after my posts????
Old 01-16-2003, 06:30 AM   #11 (permalink)
ROKTOY's Avatar
Member # 400
Unless you really think you'll never want to go lower
or will not miss 2.28, 4.7 only is ok. Otherwise
start with duals....much more versatile.
Jay
ROKTOY is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 08:29 AM   #12 (permalink)
Member # 24
Send a message via ICQ to Lemoore-on
Yep, go duels.
gives you more options in gear selection and you gonna need drive line mods eventually anyways. At least in the front (long travel)
Lemoore-on
Mike, 85 Toyota SUV
[B]
[/B]
Lemoore-on is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 09:23 AM   #13 (permalink)
RE:Todd's Avatar
Member # 422
Cool
Duals, 2 low availability. I did 4.7's first, so I know from experience.
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
RE:Todd is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 11:54 AM   #14 (permalink)
desertPOS's Avatar
Member # 3835
how cheaply can duals be put in? I know it's like $1600 or something like that to just buy the entire bolt-in deal from marlin, but what if you find the case yourself, just buy the adapter? Who has done this for nothing?
Special Thanks to:
, West Kern Environmental Consulting,
desertPOS is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 12:34 PM   #15 (permalink)
desertoy's Avatar
Member # 292
I did it. Not that hard. You just have to be able to follow directions. You have to modify a shift rod though (weld a tab on and maybe cut a little off the end). You could probly buy a modified shift rod though.
JUST DO IT AND THEN YOU WILL KNOW
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup
desertoy is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 12:46 PM   #16 (permalink)
Member # 6529
Definately dual cases first. Besides what everyone else has mentioned, 2wd 2.28:1 low with a locked rear end, the 4 banger wound out, playing Ivan Stewart on a twisty dirt road is just too much fun! (no windshield improves the effect greatly)
[B]BTG[/B] Rockcrawlers
zags is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 01:22 PM   #17 (permalink)
RE:Todd's Avatar
Member # 422
Cool
With the fumes of gas leading the way .
Todd Steele
TINBENDERS
Old 01-16-2003, 01:38 PM   #18 (permalink)
Member # 15536
Send a message via AIM to yacker711
Dual cases for sure and add the 4.70 later.
85 Yota,tubed bed,4 linked and coilovered, 60/70U, Arbs,6.17s,dual cases and a 4.70, 44" TSLs ,And a bunch of other junk.
My other rides your mom.
Iv got freinds in lower places.
JackAss Wheelers
How bout it
"El Burro Negro"
JUST 4 BIB BOY
CAUSE U CANT MAKE IT!
yacker711 is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 01:42 PM   #19 (permalink)
Member # 4948
Cost me a little less than $700 including driveshaft mods:
MC07 $475 shipped from FRORF
Used T-Case $110 shipped
Driveshaft mods: $98 (local shop)
The only catch was that shortly after installing the dual cases I realized that I needed a better x-mbr for more protection for the rear case (Budbuilt). So, I guess that is an expense too but technically not necessary.
-Mike
85 4Runner
carter is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 03:59 PM   #20 (permalink)
TNToy's Avatar
Member # 5776
I have 2-low with a 4.7 and no twin stick.
Anyway, like my first post in the thread... Duals first. You WILL want 2.28 low back, wehter you really think so or not.
Old 01-16-2003, 06:36 PM   #21 (permalink)
splatt's Avatar
Member # 6557
i did duals first so i would only need to make driveshafts one time,
just got my 4.7s installed and now it is fawkin sweet!!!!!
trail plug under construction
splatt is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 09:22 PM   #22 (permalink)
Member # 4952
Send a message via AIM to brimy311
i have the 4.7's, i did that first cause i figured with the deal i got on them, i would be able to buy duals later....less mods now too...i like my low gears
brimy311 is offline   Reply With Quote Quick reply to this message
Old 01-16-2003, 11:19 PM   #23 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
perhaps you have selected the wrong hobby
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 01-17-2003, 12:41 AM   #24 (permalink)
Member # 11759
4.7 no driveshaft mods and cheaper and can always go to duals
darkfader is offline   Reply With Quote Quick reply to this message
Old 01-17-2003, 07:53 AM   #25 (permalink)
TOY 2's Avatar
Member # 12800
I was thinking the same thing ........It dosne't help that I'm jobless right now
