Operation"Forever Tinkering" accidental 3rd gen, Vortec, Tons, 4D2s blah blah - Page 73 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-19-2018, 09:47 AM   #1801 (permalink)
Member # 235434
Originally Posted by YotaAtieToo View Post
What axles/calipers?
I have a dana 60 kingpin from a 80's dodge front, and 14 bolt rear, I have the half ton gm calipers from 4x4 truck on the 60, the 14 bolt I got from a guy and it was already converted, but the calipers look to be the same as the front. The master is from napa it's a M2533 for 83-86 K30 one ton truck.
Edit : also. it's a 85 runner and the brake booster is stock, but I have the om617 5 cylinder mercedes motor, I have thought about the t100 booster but they are like 300 bucks
tahoechief is offline   Reply With Quote Quick reply to this message
Old 04-19-2018, 10:02 AM   #1802 (permalink)
Member # 235434
Old 04-19-2018, 10:18 AM   #1803 (permalink)
YotaAtieToo's Avatar
Member # 25632
Maybe the vacuum pump is weak on the engine?
There is also a chance your master is too big. You have half ton brakes and a 1 ton master..... I run the same calipers on my front with just an FJ80 master.
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 04-19-2018, 09:20 PM   #1804 (permalink)
Member # 235434
Thanks for helping on this.
Hmm, that could be, not sure how much vacuum the pump is pulling, diesels don't pull a vacuum so they have a cam driven external pump, I just guessed it was working. I'm going to see if after a moment of engine run time, if theres residual vacuum when I pull the line, I have a vacuum actuated solenoid that pulls the diaphragm in the fuel pump to shut the motor down, and it is working correctly, but it requires little vacuum. The mercedes cars ran everything off of vacuum so the pumps are pretty strong normally.
Fj80 master ? Any adaption needed you think to get it to fit the stock 85 booster ?
Old 04-19-2018, 10:53 PM   #1805 (permalink)
Member # 25632
Bolts right on. I would make sure everything is working properly before trying a new master, there is also 3/4 and half ton masters that should mount the same as the 1 ton.
High jack over
Old 04-25-2018, 05:51 PM   #1806 (permalink)
Member # 182242
Iíve HEARD Ď97 Tacoma booster May also bolt on. Canít verify personally.
Land cruiser Partsís sound more effective though.
Hope you figure it out!
-'92 Yota,4.3vortec /R150 5-speed/2.28/Atlas4.3/
D60/14B 5.38's 42"PBRs, 3/4linked and exo'd.
-'06 Tacoma 6-spd
-'97 Int. 4700 box truck RV/toy hauler/ mobile shop.
-'02 KLR650 bugout bike
Always up to something on WilsonFab (FB) and @wilsonfabsparks on IG.
Von Wilsonator is offline   Reply With Quote Quick reply to this message
Old 04-25-2018, 06:15 PM   #1807 (permalink)
Member # 182242
Front 60 cover has seen better days. This blue torch fab DIY cover I TIG’d back when I built the axles has been worn down by my inability to avoid rocks. Hardware gets ground down every run, and leaks.
Got an old OX cover off eBay (apparently they’re still a company) had to clearance the top for the tie rod, and of course needed the pipe plug again.
Sealed up with “the right stuff” again, and hope for the best!
-'06 Tacoma 6-spd
Old 04-26-2018, 04:02 PM   #1808 (permalink)
Member # 67357
Awesome Thread.
KyTrash is offline   Reply With Quote Quick reply to this message
Old 04-26-2018, 05:55 PM   #1809 (permalink)
Member # 235434
Thanks man, I read that too, those puppies are like $300 bucks though. I'm gonna search junk yards again, as they didn't have any a couple weeks ago. The junk yards out here in Reno are toyota specific they pull the part for u.
Front 60 cover has seen better days. This blue torch fab DIY cover I TIGíd back when I built the axles has been worn down by my inability to avoid rocks. Hardware gets ground down every run, and leaks.
Got an old OX cover off eBay (apparently theyíre still a company) had to clearance the top for the tie rod, and of course needed the pipe plug again.
Sealed up with ďthe right stuffĒ again, and hope for the best!
That cover with the recessed bolts should hold up, I need me one, that thing looks beef !
Old 06-27-2018, 02:43 PM   #1810 (permalink)
Member # 182242
Originally Posted by KyTrash View Post
Awesome Thread.
Thanks!
Certainly hope so. Gotta be a reason why Crane went with that design. OX was just a bit cheaper.
-'06 Tacoma 6-spd
Old 07-19-2018, 06:50 PM   #1811 (permalink)
Member # 182242
Moved down to NC, been driving Bones almost daily
-'06 Tacoma 6-spd
Old 07-22-2018, 08:41 AM   #1812 (permalink)
Member # 26856
Where in NC are you? Just curious so I can keep an eye out for this awesome rig.
98 4runner 33's, gathering parts for a sas
80 pickup, locked, bobbed, my 5 year old sons truck
toyota231 is offline   Reply With Quote Quick reply to this message
Old 08-01-2018, 10:11 PM   #1813 (permalink)
Josh40601's Avatar
Member # 171332
Ugh. Sorry to hear man. Cherry point?
Sent from my Pixel 2 XL using Tapatalk
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 08-02-2018, 12:47 PM   #1814 (permalink)
Member # 853718
What part of of Nc
884runner 4.8 d44 rear 60 on 37pbr soon to be on 9s
Tired22 is offline   Reply With Quote Quick reply to this message
Old 08-03-2018, 06:53 PM   #1815 (permalink)
Member # 182242
3 1/2 hours south east of you. I probably wonít venture that far from home outside the toy hauler.
Nah J-no action-ville
Originally Posted by Tired22 View Post
What part of of Nc
Jacksonville. Armpit of the Marine Corps, and home to no good wheeling.
-'06 Tacoma 6-spd
Old 08-03-2018, 08:27 PM   #1816 (permalink)
Josh40601's Avatar
Member # 171332
You are a true American hero sir. I hope you make it back out to the left coast on your next tour
Old 08-04-2018, 10:30 PM   #1817 (permalink)
Member # 727817
my brother is stationed in Jacksonville nc
88 4.8 4runner duals d44/d60 on 37 PBR
bigarms24 is offline   Reply With Quote Quick reply to this message
Old 09-22-2018, 01:27 PM   #1818 (permalink)
Chkn's Avatar
Member # 228921
How did Florence treat you? Flooded out?
Cool story Hansel.
Chkn is offline   Reply With Quote Quick reply to this message
Old 12-15-2018, 07:59 PM   #1819 (permalink)
Member # 182242
Lots of us out here. Whatís your brother do?
Florence knocked us around a bit, but the week before, my twin boy and girl were born prematurely, and only got to live a few hours. While trying to deal with that, Florence hit. house and shop faired ok, the wife and I loaded up and tools off west to hide out and see some old friends in the Knoxville, TN area. We lived in Tortoise and loaded up Bones inside. September was a rough month, ready for 2018 to be over honestly.
-'06 Tacoma 6-spd
Old 12-15-2018, 08:14 PM   #1820 (permalink)
Member # 182242
Tennessee was a good break from reality. We were about 30 min from windrock, hoping to wheel there someday soon. Made the most of our time there by working out and paying our rent by dragging driftwood out of the Tennessee river for the locals.
Old 12-15-2018, 08:37 PM   #1821 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
Your family has been in our hearts and minds over the last couple months.
I don't know if there is anything really to say.
on a totally unrelated note, what is going on with the steering dana 80 thingamabob that you were showcasing on book of face? bringing another build thread over this-a-way?
Provience is online now   Reply With Quote Quick reply to this message
Old 12-16-2018, 08:07 AM   #1822 (permalink)
Member # 182242
Thanks Brother that means a lot.
Yeah Iím building a buggy. 4seater Tube chassis, LQ4/4L80E/Atlas 05+SD 60 front, offset SD D80 rear steer. The front clip I have for it is off an Ď89 S10 Blazer, so Iím not really sure where Iím going to put its thread yet.
-'06 Tacoma 6-spd
Old 12-16-2018, 10:55 PM   #1823 (permalink)
Member # 727817
hes a medic in the navy or marines I forget what branch hes in
Old 12-17-2018, 09:25 AM   #1824 (permalink)
Member # 83301
Sorry the hear about your children. As a father of 2, i cannot imagine the pain of that. Are you planning on doing a thread for the buggy? I love the high end build, but love your thread for the average joe tech that makes me feel like I can build something similar.
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
pennsylvaniaboy is online now   Reply With Quote Quick reply to this message
Old 12-22-2018, 08:05 PM   #1825 (permalink)
Member # 182242
Medics are In the army and Air Force. Navy has Corpsman, and they work for the Marines.
Thankyou.
I suppose I will make a thread for it, I appreciate the encouragement. Seeing these KOH rigs get thrown together in a matter of weeks is intimidating for sure. This buggyís a schlow buildas Iím not using parts from Bones to make it happen.
-'06 Tacoma 6-spd
