Redneck bumpstops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-11-2015, 10:58 PM   #1 (permalink)
duneburner's Avatar
Member # 104582
Redneck bumpstops
Decided to rebuild my knuckles and snapped a pic of my hokey bumpstops. The little poly things on the shock shaft slow down the movement so that the hard rubber stops dont hit so hard. It works WAY better than just the rubber ones alone. [IMG][/IMG]
I'm OHV POSITIVE are you?
duneburner is offline   Reply With Quote Quick reply to this message
Old 09-12-2015, 03:29 AM   #2 (permalink)
Member # 213125
And then? How about a little tech to go along with your one picture. Who did you buy them from? If you got them in a junkyard what vehicle did they come off of? Shock bumps aren't anything new to offroaders.
Aisin is offline   Reply With Quote Quick reply to this message
Old 09-12-2015, 04:52 AM   #3 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Those appear to be Daystar EVS bump stops. There are a joke and they do diddly squat. Search.
& Blaine
:tank:
Old 09-12-2015, 11:37 AM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I have something like that on the shocks that I got from Poly Performance, they came on a shock called BBCS (Big Black Cock Shocks) and they seem to help a lot.
Old 09-12-2015, 12:17 PM   #5 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Those are real bumpstops from basf Germany. They aren't hollow like the Eva bumps (done so they can be pushed over the eyelet)
& Blaine
:tank:
Old 09-12-2015, 01:23 PM   #6 (permalink)
duneburner's Avatar
Member # 104582
Yup Daystar EVS bumpstops they are. I had to use two on each shock seperated by a washer that I put a split in to fit over the shock shaft. They do make a difference but nothing close to an air bump. Hey Beat Duhh I did call them redneck. Search for what? I didnt ask any questions.
Old 09-12-2015, 02:02 PM   #7 (permalink)
Member # 129425
Isnt this a good way to rip off a shock tower?
toyotatime is offline   Reply With Quote Quick reply to this message
Old 09-12-2015, 02:38 PM   #8 (permalink)
Member # 53528
if you do that most likely means your shock mount was not strong and needs to be strengthened
Old 09-12-2015, 04:04 PM   #9 (permalink)
Member # 205767
Heres mine…..
ambitious1 is offline   Reply With Quote Quick reply to this message
Old 09-12-2015, 04:13 PM   #10 (permalink)
Member # 3132
Originally Posted by ambitious1 View Post
Heres mine…..
Nice brake line. You know what happens when the metal fatigues?
Old 09-12-2015, 04:18 PM   #11 (permalink)
duneburner's Avatar
Member # 104582
the shock never bottoms out. the hard rubber bumpstop takes care of that
Old 09-12-2015, 04:48 PM   #12 (permalink)
Member # 205767
Dafuq are you talking about? They're braided stainless lines…
Old 09-12-2015, 11:39 PM   #13 (permalink)
Member # 111580
look again, the shock is "upside down".. the shock body (and the braided line attached to it) droop with the axle...
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 09-13-2015, 06:00 AM   #14 (permalink)
Member # 205767
The shocks are mounted correctly in their proper, intended orientation.
Old 09-13-2015, 07:42 AM   #15 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
This is the line he is talking about. Vibration work hardens the metal and it can break.
Should do something like the bottom picture.
Old 09-13-2015, 10:40 AM   #16 (permalink)
Member # 3132
Hey nummers...I am talking about the hard metal line to the caliper.
Old 09-13-2015, 04:55 PM   #17 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
You only get rear brakes for a day or so until it gets replaced
Old 09-13-2015, 06:20 PM   #18 (permalink)
Member # 111580
I agree its not perfect, but that line will be fine for a very long time, there is enough braded line there that the hard line wont have to flex...
BUCK OFAMA
4 seater LS1 buggy
Old 09-14-2015, 12:23 PM   #19 (permalink)
Member # 67823
Mine are even more redneck. No pics but I just split leaf spring bushings and hose clamped em over the shock shafts.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
Old 09-15-2015, 07:07 AM   #20 (permalink)
Member # 514042
i have come to the conclusion that anything the the words day-star and bumpstop should be avoided, this thread seems to be an example of what not to do...........
offset442 is offline   Reply With Quote Quick reply to this message
Old 09-15-2015, 08:10 AM   #21 (permalink)
GRMhick's Avatar
Member # 87
Send a message via AIM to GRMhick
Mine lasted about 1 year like that before they broke off driving down a rural county road. The rear brakes locked up and the truck did a 360. I'm happy no one was around, and that I didn't hit a center divide. It could have been very, very bad.
Don't be an idiot, and get that fixed ASAP.
. Diamonds. 35's.
. RestoMod.
GRMhick is offline   Reply With Quote Quick reply to this message
Old 09-15-2015, 08:25 AM   #22 (permalink)
Member # 67823
Your brakes locked up as a result of a broken brake line
Old 09-15-2015, 08:56 PM   #23 (permalink)
Member # 3132
umm.......no. I know for a fact this isn't true.
Old 09-15-2015, 08:58 PM   #24 (permalink)
Member # 3132
That will be the only half of the master cylinder that may work. one part does both fronts, the other port does both rears. At least on this style master. Some will do one front and opposing rear.
Old 09-15-2015, 09:25 PM   #25 (permalink)
Member # 111580
When he turns the braided line is gonna move before the hard line
BUCK OFAMA
4 seater LS1 buggy
