86 4runner Build - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-20-2016, 09:55 PM   #26 (permalink)
Member # 3132
I am just fucking with you. Reading the shit you type reminds me of any toothless tweaking fuckstick from Georgetown ca.
Build a crossmember between the mounts for the backs of the control arms and bolt in a skid plate to hold the front suspension together. Or you will be sorry with a broken front differential and a paperweight ARB. Maybe even support it from impacts by running stiffeners from the trans crossmember to the bottom of the control arm brackets.
Old 04-20-2016, 10:02 PM   #27 (permalink)
Member # 622161
Figured you were. Not a toothless tweaker. I did put a brace on the back side of those a arms. I think the skid plate is probably a good idea.
Beastmode is offline   Reply With Quote Quick reply to this message
Old 04-20-2016, 10:08 PM   #28 (permalink)
Member # 3132
Trust. It is. Unless you want a front suspension that fucks up your tires and is not able to be aligned after your first drop into a ditch.
Old 04-20-2016, 10:23 PM   #29 (permalink)
Member # 622161
So that skid plate would span between the front and back a arm mounts?
Old 04-20-2016, 10:36 PM   #30 (permalink)
Member # 3132
Yes. Make it cover bottom of diff. Make a hole so you can get to the drain plug if you want.
Old 04-22-2016, 01:20 PM   #31 (permalink)
Member # 102813
Originally Posted by Beastmode View Post
I'm starting a desert truck build. Hybrid crawler/racer on my 86 4runner.
Originally Posted by Mr Stubs View Post
Are you worried about the weight of the runner while trying to make a pre runner?
I'm not trying to build a pre runner. This thing is more hybrid all purpose. 5.29s and a duce duce RE keep it slow and low power. In regards to weight, there is plenty of suspension to take it. I also had deaver custom build those rear leafs with and added 500lb mod.
The reason I brought up the weight question was because of the first post. In my mind a "desert" truck labeled as a "hybrid crawler/racer" is going to see some speed in the wide open whoops. Weight is a killer in this department and the 1st gen runner is a bit of a top heavy pig with its fiberglass top.
IMOP this just isnt the best platform to start with. I gutted Krunch https://www.pirate4x4.com/forum/toyot...ry-krunch.html and got it down to 3650lbs. I understand this is what you have and your plans revolve around it. If it was me, and I was using this to go as fast as I could in the desert with it, I would ditch the hard top and gut the hell out of it.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 04-22-2016, 01:30 PM   #32 (permalink)
Member # 140628
I would totally bomb this fucker in the stock EMC class at KOH.
hodgiemoto is offline   Reply With Quote Quick reply to this message
Old 04-22-2016, 07:26 PM   #33 (permalink)
Member # 622161
The track width is 7 1/2 wider than stock. Shouldn't that offset a quite a lot of top heavyness?
Old 04-22-2016, 08:28 PM   #34 (permalink)
Member # 102813
Sway yes, overall weight, no.
[/COLOR]
Old 04-27-2016, 08:26 AM   #35 (permalink)
Member # 622161
Thanks... I'll let u know how it works.
Old 04-27-2016, 09:33 AM   #36 (permalink)
gosurfn's Avatar
Member # 108994
Yeah the rear shackle will make contact with the bumper mount. Guess that bumper is gonna have to go. Any of you guys got any good ideas about front and back fender modifications? I want to make it totally clear but not look all hacked up...nice and clean. I've been looking at glass for the front but most of them look like shit. I saw a guy on here that fabbed up a set out of his stock fenders and another pair. think that's what I'm going to do. Ideas for the back would be great!
Rear pickup glass and front Hanneman Ivan clip
What's your location?
-Chris
mcleanmetalworksmfg.com
gosurfn is offline   Reply With Quote Quick reply to this message
Old 04-28-2016, 08:26 AM   #37 (permalink)
Member # 622161
Bend Oregon
Old 04-29-2016, 07:45 AM   #38 (permalink)
Member # 102813
Have you stopped by G Fab Motorsports?
[/COLOR]
Old 08-28-2017, 04:08 PM   #39 (permalink)
Member # 622161
I'm almost done. ? been a while but thought you guys would like to see it now.
Old 08-29-2017, 12:19 AM   #40 (permalink)
1990GT50's Avatar
Member # 109423
Pretty sweet actually although id hate losing the sleeping spsce by running through the bed area.
Is it on 33" mtr's?
If you try to fight me I'm simply going to interpret it as an attempt to kill me.
Go back to riding your Fag Dog Brokeback or whatever the fuck its called.
1990GT50 is offline   Reply With Quote Quick reply to this message
Old 08-29-2017, 01:44 PM   #41 (permalink)
Member # 66955
nice snorkel... Where in the desert bomber/rockcrawler world does that belong? I ask everyone I see with one why and have never herd a valid answer from anyone other than an Australian guy.
So, why the snorkel? Do you plan on some 5+ foot water crossings? Are your difs sealed with vents that high? How about the trans and tcase?
sherm$ is offline   Reply With Quote Quick reply to this message
Old 08-29-2017, 08:18 PM   #42 (permalink)
Member # 401657
Nice to see something different brought to the table! I've always thought a long travel IFS rig would be great for expo type stuff, running around on dirt roads, and the occasional rock crawling. A master at nothing, but does everything well.. Looks like you did a great job.
Ignore all the typical Pirate hate..
Dwill817 is offline   Reply With Quote Quick reply to this message
Old 08-31-2017, 11:08 AM   #43 (permalink)
rugburn's Avatar
Member # 45
Other than the cool factor, I ran a snorkel on my FJ60 for dust control as well as deep water crossings.
All my vents were above door sill height and had one way check valves installed.
This guy has a cool as build
Mad props to OP
John Runberg
Swedish American :usa:
rugburn is online now   Reply With Quote Quick reply to this message
Old 09-01-2017, 09:04 AM   #44 (permalink)
Member # 66955
I'm not hating on the build at all, most of it is very cool.
Old 12-21-2018, 10:50 AM   #45 (permalink)
Member # 622161
Just cut the rear fenders and front fire wall. Snorkel ?... don't plan on doing any 5' + crossings but you never know what you will run into so it's there if needed. All vents are one way check. The point is to come against no obstacles that can't be past. BEASTMODE!
Old 12-21-2018, 10:51 AM   #46 (permalink)
Member # 622161
Will add pics of fender progress soon
Old 10-10-2019, 12:50 PM   #47 (permalink)
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
any updates?
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
2019 Tundra
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
