THAT OLD ATF KEEPS EM RINGS NICE AND LOOSE!! AND CLEAN!!!
A Old Mecha NIK once told me It has high detergents in it,, keeps the motor clean and in our colder climates the oil a bit thinner..
here in CANADA i wouldnt not do it...
Huge Differnce ATF and Diesel I wouldnt put diesel fuel in my crank case no thanks..
probly wouldnbt hurt it just dont like the thought of what that deisel could do to seals over time that is..
its how you clean out a gummed up motor, you dont leave the diesel fuel in there for more then 30 minutes or so, and you should change the oil again 500 miles or so later
oh ya i heard this years ago from the coast for old boat marine engines from REAL PIRATES... But i do think it was use on deisel engines mostly..
at first then folkz tryed it out on gas..And ya it works but again i dont like what diesel can do to seals.. But ATF doesnt hurt a thing left in there but no more than half liter..!!! it seems to help even the oil pressure too!
amazing how nice and clean some of these old engines i ripped apart and looked clean..
So true.
I converted this go kart to propane 18 years ago when the kids were small. The motor was a new Briggs. I take it to workshops and displays now. It still has the same oil in it from 18 years ago and is still clean. I left it in there just to see how long it can last.
Anyone know how the detergents in say Mobil 1 high mileage compare to ATF? I wonder if it would do me any good to run ATF before an oil change. Just haven't tried it because I'm running full synth that is supposed to be cleaning.
I used to add a quart to my amc heep 360 when one of the lifters would clatter. It would only take a day of driving (30 miles) to clear it up. I always changed my oil after one day also. I have used it in a pinch to have enough oil to get home after a flop also.
ATF is terrible for an engine... ATF is designed to create friction, if you want the detergent effects of ATF there are FAR better ways, diesel being one of them, but ATF is not a good "lubricant"
Our autoshop teacher taught us this trick way back when. However, he said to drain 1 qt oil, add 1 qt atf run for about 10 min then drain all out. As a means to clean out the engine. I have not done this since auto shop class in the 80s.
About 20 years ago, the oil distributor I was using provided me with a drum of 5w30 oil that had a red tint as a few oils do. He said a small amount of ATF had been dumped in the bulk tank by accident but it was trace amounts, just enough to change the tint. I PM'ed one of my customer pickup fleets and got a phone call the next day that one of the engines had locked up. I quickly changed the oil in all the other trucks to a different brand. My insurance company had to pay for a replacement engine for that truck and then went after the oil distributor. I had the oil analyzed by a lab in Houston and found it was 30% ATF. That lab explained to me that ATF does not have any of the proper lubricating properties for an engine but works fine for its intended use and the distributor should have never allowed any of that oil to be sold. It was explained to me by that lab that ATF is slightly better than water for lubricating an engine.
Ya ya ya ya u know like i said been doing this fer years yes running a half liter or more in my oil no problems at all..
And every engine i have is clean as whislte why??
I heard ATF has a higher detergents in the oil ...
BUT BUT I NEVER HAD ONE ENGINE LOCK UP ON ME YET~~ over 500 K on all my toyotas
If you run a good, quality oil and change it every 5,000 miles (3,000 if it is a AC-VW). The inside of your engine will be clean enough to eat off of.:flipoff2:
mobile 1 clean 5000 keeps engines clean as it gets i have broken a few down that where running that oil and found no real deposits beyond films in areas that did not get good wetting...............
I've heard ATF, Brake fluid, Marvel Mystery Oil, Diesel, various solvents and cocktails used, always just before an oil change, or when buying a used car.
My thought is all of them may do some good at knocking loose sludge or crude from a mistreated engine, I've also heard about clearing stuck lifters.
But once done. Go to good oils, and regular changes. and the problem will not come back.
My number is every 5k, just because it is easy to remember on the odometer.
Just my .02.
and no real science to back it.
But I have driven two cars over 300k that I bought new with no failures.
Just my .02.
Finally Some Sound Good advise however a half liter doesnt hurt anything at all..AND YES i Agree ATF Yes It will loosen gunked up and sticky lifters but even that takes time.. I Had a Jeep Chero which had a sticky lifter added about 3/4 liter ATF to the old oil and with in a week she had oil pressure again,,,So i left it alone the oil and ran it for another couple weeks dropped the oil added new oil with just a tad of ATF in new oil and now motor runs well again...
anyhow yes everyones right running ATF before a oil change helps clean er out abit but dont worry about running it for a while It wont hurt your engine at all...
even week.... but dont run like a full liter maybe to 1/4 to half what i like to also do is if im low on oil add a lil ATF instead of oil...just a tad....:smokin:
