Ok guys I snagged a 94 Toyota pick real cheap. Super nice truck and runs great untill you put it in gear. The truck idles perfect and will drive smooth as glass and shift just fine. When you stop with the truck in gear the damn thing will shake the teeth out of your head. Things I have replaced are motor mounts and trans mount. I have also checked for vacuum leaks and everything seems to be fine on that side of the house.
Any Ideas? This is the first Toyota I have owned.
