All Toyota - 4 Seat Tube Buggy w/Locktup Fab - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-09-2016, 02:54 AM   #26 (permalink)
Member # 53528
Originally Posted by dirtyjed View Post
I've broken more r&p's than birfs with my stickies. Just try not to get to bound up.
Buggy is looking sweet. I love the swoopy look you get with rolled tubes.
i broke 6 chromo birfs to one gear set
i think its great people are starting to recommend bigger birfs instead of a 9.5 diff with mini birfs like you used to see everyone suggest
rockyota83 is online now   Reply With Quote Quick reply to this message
Old 09-09-2016, 07:15 AM   #27 (permalink)
lostbuckaroo's Avatar
Member # 416682
Thanks man!
lostbuckaroo is offline   Reply With Quote Quick reply to this message
Old 09-09-2016, 07:58 AM   #28 (permalink)
Member # 416682
Rear Housing Truss Design by Locktup
Custom Motor Mounts by Loctkup
Old 09-15-2016, 07:04 AM   #29 (permalink)
Member # 416682
Rear Link Setup
T-Case Mount
Old 09-15-2016, 10:47 AM   #30 (permalink)
dfowlkes's Avatar
Member # 231443
Nice work!
85 Toyota fruggy
dfowlkes is offline   Reply With Quote Quick reply to this message
Old 09-15-2016, 11:49 AM   #31 (permalink)
Member # 83301
Looks like the seats are super low...how is visibility, the kids in back wont see much but the sky
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 09-15-2016, 12:32 PM   #32 (permalink)
dfowlkes's Avatar
Member # 231443
Well it sure beats the tip of their head being above the cage . Compare the transition to a 1st Gen runner. It's about the same. Not to many options as I've explored them myself
85 Toyota fruggy
Old 09-15-2016, 01:40 PM   #33 (permalink)
Member # 416682
Well seat hight hasn't been set 100% yet for the front but I don't see there being any visibility issues up front.. As for the rear seat visibility is not gonna be great but that's secondary to safety.. My girl will be able to pretty much sit in the middle of the bench, as most times it'll be just her in the back.. The back seat will be tight but it's built more or less for the kiddo..
Old 09-20-2016, 09:15 AM   #34 (permalink)
Member # 416682
Front Housing built out for mockup with FROR Keyed Steer Arms, ARP Studs, and TG Studiess hubs
Griffin Rad - Arrived.. to be fitted with a 16" Spaul Fan
Rear Seat Mount Done
Old 11-05-2016, 08:25 PM   #35 (permalink)
Member # 114156
Sub'd....Whats the height of the subframe?
ftirish86 is offline   Reply With Quote Quick reply to this message
Old 11-07-2016, 10:58 AM   #36 (permalink)
Member # 416682
It'll be 20/21" at ride height.
Old 11-07-2016, 11:03 AM   #37 (permalink)
Member # 416682
Back to work on the buggy..
Got a wheel and tire mounted up and mocked up. Installed 2" spacers in the rear.. Tacked in some rear support tubes getting ready to mount shocks.. and locate air bump cans, sway bar links, limit strap packaging.. Kinda tight in there but the 2" spacers help a bunch..
Old 11-07-2016, 11:42 AM   #38 (permalink)
Member # 199301
Sweet build. Really like how clean it looks.
A buddy of mine built a rig with rolled tube last year. Makes it look smooth.
Im doing a full body build right now with a 3.4 swap and I elected to stick with the auto instead of the manual as well with the duals and 4.7's. Hoping I made the right choice also.
I should have mine moving on its own in a week or 2. Will let you know how slow it is...and I hear it will power through the brakes in low low.
CarportMechanic is offline   Reply With Quote Quick reply to this message
Old 11-07-2016, 11:51 AM   #39 (permalink)
Member # 416682
Very nice! Yeah sounds good let me know, thanks!
Old 11-07-2016, 03:49 PM   #40 (permalink)
Member # 114156
sorry... maybe wrong wording. What's the height (the bottom of the subframe to the floor of the buggy) so how much does the subframe hang below the floor. Im also curious about frame side vertical between your uppers and lowers. If you dont mind me asking sorry. Im currently building a Ranger truggy in my 2 car garage
Old 11-11-2016, 11:46 AM   #41 (permalink)
Member # 416682
Got some more structural tubes notched and tacked in .. and mocked up the rear shocks/mounts
Old 11-14-2016, 12:56 PM   #42 (permalink)
Suzuki/Toyota Parts
Low Range's Avatar
Member # 80948
sweet build!
Order online at
Check us out on Facebook
Follow us on instagram:
#lowrangeoffroad @Lowrangeoffroad
YOUR Suzuki and Toyota Parts SUPER SHOP. Over 7800 Products and Counting.
We ship WORLDWIDE.
Why buy from Low Range Off Road?
We keep records of sales from the day you buy your product. Need a product warranty? Lost your receipt? Yep, we have it.
Low Range is offline   Reply With Quote Quick reply to this message
Old 11-14-2016, 05:18 PM   #43 (permalink)
Member # 416682
Originally Posted by Low Range View Post
sweet build!
Thanks! Jason's got a couple other builds in the works including an 85' 4runner build, and a 2" - 2 Seat U4 Spec Buggy Chassis.
Old 11-22-2016, 08:29 AM   #44 (permalink)
Member # 416682
More structural tubes mocked and tacked in back in prep for upper shock mounts, and rear seat belt mounts.
Lower rear shock mount tabs by Locktup
More structural tubes mocked and tacked in front prepping for front suspension, winch and rad mount
Old 12-05-2016, 12:34 PM   #45 (permalink)
Member # 416682
DIY/Weld on Bead locks completed
Old 12-05-2016, 12:40 PM   #46 (permalink)
Member # 416682
Front Axle placement set and first look with two tires bolted up!
Old 12-05-2016, 01:01 PM   #47 (permalink)
Member # 208566
Why the rearward mounting coilovers? It looks like you would have room to flop them forwards the same degrees and gain a little more travel at the same time?
85 22re Extra cab.. Never ending project
Parting out 3x 4Runners, a 1997, 2000 Limited, and 1987
bigbadyoda is offline   Reply With Quote Quick reply to this message
Old 12-05-2016, 01:26 PM   #48 (permalink)
Member # 416682
Agreed we've discussed this and it's still not set in stone.. Sill trying to figure out packaging with the bump stops, and sway bar.. plus mounting the shocks in the opposite direction will make make skinning in the sides of the rear seat a little more challenging.. (wanna keep the kiddos hands way away from the shocks)
Old 12-05-2016, 01:55 PM   #49 (permalink)
Member # 103621
Nice work. Love the lines. No overly complicated looking, which is a good thing.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 12-05-2016, 03:53 PM   #50 (permalink)
Member # 208566
The potential to have body parts pinched by a vehicle rocking and the coils compressing on that side was my negative comment on moving them forward based on the rear seat location. However, if you had enough room to put skins inbetween the coilover and seats that should eliminate that problem.
Judging by those wheel spacers, you could probably move the axle side coilover mounts out a little bit without the tire hitting the coils on the compression side. Depending on your flex/wheel travel you may also be able to get a little more inward lean of the coilovers or move the upper mounts out the same as you move the lower mounts out. I just set up my rear 4 link and was suprised how much I could push out the axle side mounts without any real negative impacts other than putting the coilover at about a 17* inward angle at ride height.
