Member # 187059
Best shock setup for 63s
Im currently running RUFs and 63s on my rig with the basic 14" 5100s ran through the bed pretty close to vertical, no overload or blocks and a slip/twist traction bar. truck sits pretty low , ride is real stable and it flexes quite well.
Im happy with the the setup when I am crawling, but going from trail to trail at speeds its real stiff in the rear. I know theres only so much leaf springs will do, but before i mounted the shocks the springs felt real soft. Would better shocks drastically improve the ride of the 63s? If so what brand and shock would you recommend?
1984 Xtracab 1999 Dodge 2500 CTD 4x4 |
Rolling Mod
Member # 22176
Shocks are only as good as who tunes them. The best shock will suck if tuned poorly. Call Ryan at Accutune.
I can break a steel ball in a rubber room! Companies helping me get dirty: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Blaine :tank: |
Sponsored Links |
Custom User Title
Member # 138976
also, 4wheelunderground has some supposedly damn good pre tuned shock packages for leaf springs
up is difficult, down is dangerous freedom of choice is what you have, freedom from choice is what you want keep your head down, go to sleep to the rhythm of the war drums |
Member # 8286
Bilstein shocks are too stiff on rebound and too light on compression. Custom tuned fox 2.0 remote reservoir smoothies are your best bet. We've done tons of Toyota from street to pre-run. Everything is custom to your rig and your terrain and includes tons of support to make sure you get the most from your shocks.
Ryan Phone: 424-377-0808 Email: [email protected][websiteURL] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Shop To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Custom Spring and Valving Specialists See what we're up to: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock Now Hiring - Technical Sales Rep |
Thread Tools | |
Display Modes | |
