Solid axle strength question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-14-2017, 08:34 AM   #1 (permalink)
Member # 685938
I'm in the planning and part collecting phase of sas'ing my xterra. One option iv been considering is going to a tacoma width ruffstuff or diomand axle and using the toyota 8 inch diff and outers.
The xterra is on the heavier side at 5k lb will be running 33s and I wheel it fairly tame amd have been able to make the ifs hold up so far so I'm not to worried about the diff.
My question is on the outers (king pin bearings and wheel bearings n such ) how will those things handle the weight? The rig sees about 15k miles a year or so. will I be replacing bearings every 6 months or will it survive?
Christopher.h is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 08:55 AM   #2 (permalink)
Member # 102813
It wont be a issue as long as you keep the part properly maintained.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 09:52 AM   #3 (permalink)
Member # 685938
Do you think it would be worth going to trunion elemators for more reliability or properly kept trunions are ok? Iv only delt with bearings on my last truck but I wanna build this one the most reliable as I can on a budget
Old 02-14-2017, 09:58 AM   #4 (permalink)
Member # 84361
I would stick with bearings for your application.
I also think that for your use I wouldn't even give strength a second thought with a toyota based axle, especially with an aftermarket housing.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
JHF GB Chassis in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 10:32 AM   #5 (permalink)
Member # 53528
your trunions will be fine as long as youre not running 2" back spaced rims with 3" wheel spacers and youre not daily driving down miles of rough dirt road
Old 02-14-2017, 10:37 AM   #6 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
word up hommie G
Provience is online now   Reply With Quote Quick reply to this message
Old 02-14-2017, 10:49 AM   #7 (permalink)
Member # 685938
Awesome. Thanks guys
Old 02-14-2017, 03:01 PM   #8 (permalink)
Brian Ellinger's Avatar
Member # 1088
I would absolutely stick with bearings in the knuckles. We can upgrade you into higher load rated 25mm bearings with our Keyed Steering as well if you really want to be sure!
We can certainly build with the 8" center, or we can do a housing with the 9.375 Nissan h233b diff as well, and since we do shafts, can get those setup to match to a 30 spline RCV joint and the nissan diff should you decide to go that way.
Brake upgrades, and steering we also handle in house as well! So much more than just a housing!
Now on FACEBOOK!
Thank you to our loyal customers!
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
NEW BUILD FTOY #44
Brian Ellinger is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 06:15 AM   #9 (permalink)
Member # 685938
Just an update since I know everyone likes photos. Ended up going woth an diomand housing xterra 3rd arb rcvs amd 5th gen 4runner brakes with mini truck outers
Old 06-05-2017, 11:33 AM   #10 (permalink)
Member # 213125
What size ring gear is in the xterra 3rd?
Aisin is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 11:52 AM   #11 (permalink)
Member # 79509
Badass axle! You'll never have an issue. I just wish the HP 233 wasn't unobtanium in the states.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 12:13 PM   #12 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
wow, sounds like budget minded went out the window
edit: pimp setup
Old 06-05-2017, 12:53 PM   #13 (permalink)
Member # 147603
A little overkill for 33s don't you think?
"Is there a such thing as a comfortable jeep ride?" Alan Alda (MASH)
chevota5.0 is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 12:56 PM   #14 (permalink)
Member # 213125
It's nice to be able to beat things like a circus monkey and not have to worry about them.
Old 06-05-2017, 01:53 PM   #15 (permalink)
Member # 685938
edit: pimp setup
Price wise wasn't too bad. I'm at about 4k as it sits.
The xterra is drivers side drop and 6 lug so the only dana 44 that would work is from a wagoneer and I had no luck finding one plus I would have had to regear it. In the end the price wold have been about the same ether way but this way I feel is a much better set up
Old 06-05-2017, 01:58 PM   #16 (permalink)
Alex123456's Avatar
Member # 52396
Where I'm from 4k is a lot for a front axle
Really nice setup though, you got your moneys worth and wont ever have to worry about it.
Alex123456 is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 03:40 PM   #17 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I have got about that much in my front Toyota 8"!
Old 06-06-2017, 08:01 AM   #18 (permalink)
Alex123456's Avatar
Member # 52396
I refuse to add up my receipts, but yeah it gets out of hand
Old 06-06-2017, 08:10 AM   #19 (permalink)
Member # 503194
Awesome, so glad you went with a h233B front. I love the h233 man they are such under-rated axles.
Are you doing leafs or links?
93 Nissan D21 3.0L 5-speed, leafs, HP44, Locked on 35" MT/R's.
synbiotic12 is offline   Reply With Quote Quick reply to this message
Old 06-06-2017, 08:32 AM   #20 (permalink)
Member # 685938
I agree. Here is a toy 8 inch ring gear laid over the h33 ring gear. Size is impressive even the carrier is noticeably bigger
Plan is leafs with front shackles and spring under. Springs are 4 inch tg lift springs.
Old 06-06-2017, 08:39 AM   #21 (permalink)
Member # 503194
Front swing shackles, you're just doing everything different aren't you?
Love seeing more Nissans around, What are your plans for steering and have you decided to do anything about a lower crawl range, or is your rig an auto?
Old 06-06-2017, 09:00 AM   #22 (permalink)
Member # 685938
Steering is a ruffstuff universal kit with marlin high steer arms and an fj80 forward swing box
Stock 5 speed and single case for now. Looking for ether a dana 300 so I can go duals or save more and get a 4sp atlas
Old 06-06-2017, 10:32 AM   #23 (permalink)
Renaud33's Avatar
Member # 23389
Send a message via AIM to Renaud33
When I do that and divide by the 10 years I have used and abused my front axle, it doesn't seem all that bad.
85' 4Runner - AP extreme lift, 37" PB Rockers, duals
TLCA Member# 16265
Renaud33 is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 06:41 AM   #24 (permalink)
Member # 685938
Final update for anyone who cares. Still needs a bit of tuning but it drives and wheels way better then the ifs did
Old 06-12-2017, 10:01 PM   #25 (permalink)
Member # 3886
Looks good man.
hold this...
gnob is offline   Reply With Quote Quick reply to this message
