Toyota frame shackle bushing 63" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2017, 11:57 AM   #1 (permalink)
Member # 190138
I've searched all over and can't find out what bushing I need to get so I can build my own rear shackle mount for a Chevy 63" swap. I'm not worried about replacing the leaf spring bushing. Does anybody have a NAPA part number for the bushing and metal sleeve? Also what size of pipe will fit the bushing?
jeepfc170 is offline   Reply With Quote Quick reply to this message
Old 04-27-2017, 12:02 PM   #2 (permalink)
Member # 225201
Ruffstuff to make it easy.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 04-27-2017, 12:17 PM   #3 (permalink)
TOYOTAPARTS's Avatar
Member # 61493
you need a 3" long sleeve 9/16 id to match the chevy spring.
Shackle Sleeves
If you are trying to use your old stock shackle hanger tube they are not wide enough.
Shackle Hanger
these are the bushings we use
Bushings
Great deals on Toyota Parts: :
RCV 30 Spline axles FREE shipping.
Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs
TOYOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 04-27-2017, 12:20 PM   #4 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
"Energy Suspension 3.2106G Rear Spring Bush for 2 and 4WD" set of 6 bushings off amazon for $44. These are for a 1.5" ID tube, so i've got some of that as well.
Manufacturer Part Number ENE-3.2106G
OEM Part Number BDVQ3.2106G
these are the bushings I'm using for all my frame side stuff, they are set up for 3" over all length and a 9/16" dia bolt.
edit: fuuuuck, davez bushings are essentially the same thing but cheaper should have checked there
Old 04-29-2017, 07:31 AM   #5 (permalink)
Member # 190138
Awesome! Thanks guys
Old 05-21-2017, 11:16 AM   #6 (permalink)
Member # 61493
Yukon parts on SALE
Old 05-21-2017, 02:33 PM   #7 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
You know a lot of us do not choose the easier, softer way, some of us do like to fab-bro-cate!! When I started building my truck in 97 there were very few vendors so you made it!!
Old 05-21-2017, 04:43 PM   #8 (permalink)
ADD
Member # 22080
Can you hand us all a butterscotch candy and tell us about how the Rubicon used to be all orange groves grandpa .....
Got custom cab?
ADD is offline   Reply With Quote Quick reply to this message
Old 05-21-2017, 05:41 PM   #9 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
Old 05-21-2017, 09:01 PM   #10 (permalink)
Member # 3132
You know they sell 18mm drill bits and 18mm bolts to use stock bushings on the frame side of the shackle.....right? Grind welds, knock off factory shackle hanger, front of hanger will be welded back on right behind where the original shackle hanger was welded
Old 05-21-2017, 09:03 PM   #11 (permalink)
Member # 3132
Walked to and from school 10 miles with 10 feet of snow. Uphill both ways.
Old 05-21-2017, 09:25 PM   #12 (permalink)
YotaAtieToo's Avatar
Member # 25632
First of all using a sleeve and smaller bolt is the right way to do it.
Second, for a little more that the price of a stupid 18mm drill bit, you could just buy a bushing kit, weld it on and spend more time on the trail.
Funny how some people can waste more time and money trying to be cheap.
I'm all for doing stuff myself, but stupid shackle hangers are so time consuming to build. Especially if you want to source your own bushings , then go try to buy 5" of tubing, finding the right bolts, ect.
Old 05-21-2017, 09:33 PM   #13 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
kind of sort of, but it is still a good bit cheaper to build your own. if that is all you are doing, then yeah just buy the kit, but if you are going to make more than one set or are doing other things in general than buying the raw materials and using them in multiple spots makes more sense.
Old 05-21-2017, 09:42 PM   #14 (permalink)
Member # 3132
Some of that could be true. But the rear shackle bushing do not get the stress that the front shackle bushings do. The fronts actually need the sleeves. And lets not act like that 18mm drill bit for 8 dollars is not going to only drill one pair of shackles in it's life.
I like to reuse the factory hanger, drill one end of the shackle with one of the 2 18mm drill bits i have owned since oops was building his rig in 1997.
Old 05-21-2017, 09:44 PM   #15 (permalink)
Member # 25632
I'm not talking about the whole kit, I mean just the shackle hangers.
Shackle Hanger - RuffStuff Specialties
$48 - 10% with code pbb10
How fast are you going to eat that up driving from store to store trying to get the materials? A lot of metal places don't like selling small amounts of material. My local metal supplier is pretty good, but is closed on the weekends and is 45 mins away. If that's to expensive for you, just use the Chevy shackle on the frame and have your normal shackle come down from that, like 2002!
Old 05-21-2017, 09:46 PM   #16 (permalink)
Member # 25632
Where are you getting drill bits like that for $8? I usually pay $40 for large bits like that.
Old 05-21-2017, 09:50 PM   #17 (permalink)
Member # 3132
I don't remember. But i am not going to act like I don't take them to the bench grinder to sharpen them before every use.
Old 05-21-2017, 09:51 PM   #18 (permalink)
Member # 3132
It actually makes me wish i spent 40 for one.
Old 05-21-2017, 10:01 PM   #19 (permalink)
Member # 61493
stock shackle hangers are thinner steal, and are too narrow for Chebie springs. Worth the $42 to buy with bushings and just install. :2cents:
Yukon parts on SALE
Old 05-22-2017, 08:15 AM   #20 (permalink)
KacksterK5's Avatar
Member # 5851
Built mine from some 2"dom and bought the bushings cheap. Sleeves cane with.
Pro tip. Box in the frame for the shackle mounts. It will collapse over time if not.
02 Chevy 2500 HD Tow Rig
KacksterK5 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 06:40 PM   #21 (permalink)
Member # 147603
I Left the stock shackle mount on the frame, bolted the stock chevy shackles to them... laid back they're 4" rear of the stock mount which is where they need to be for stock axle location. Then use whatever length shackle plates you want from there. I drill out the 63 spring and shackle bushings leaving the outter sleeve in the spring. then I mill down a set of rear Toyota spring bushings, the larger diameter ones, to fit all the way into the 63 springs and chevy shackles making them the same width as Toyota springs. This way there's no spring/bushing width issues with the stock Toyota shackle mounts. And you can still use all 18mm hardware. Cheap and easy plus the double-shackle gives more axle drop.
"Is there a such thing as a comfortable jeep ride?" Alan Alda (MASH)
chevota5.0 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 06:52 PM   #22 (permalink)
Member # 25632
Ya, double shackles are awesome
Old 05-22-2017, 07:22 PM   #23 (permalink)
Member # 102813
The cats meow when they invert.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 05-23-2017, 09:54 AM   #24 (permalink)
Member # 147603
You two have personally ran this set up the way I explained with the parts I listed and had trouble?
I've never ran into any issues running this set up in the past 8-10 years. Just bought a ruff stuff anti wrap unit to help with wheel hop caused by the 63s but have never inverted a shackle. They don't even open up enough to straighten out.
Hell they didn't even open up when I lost control, went off the freeway, and over corrected twice at 70 mph sliding sideways and fishtailing until I slowed enough to get straightened out. Thought I was dead and probably owe my life to a set of bald 14.5 12ply thornbirds
Old 05-23-2017, 11:30 AM   #25 (permalink)
Member # 3132
I have personally ran that setup 17 years ago. Have fun breaking the chevy shackle. It was stupid. Didn't last 1 season.
