22 re alternator help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2017, 04:11 PM   #1 (permalink)
Member # 783393
Hey I have a 22re buggy on a tube frame. My problem is the alternator is not charging... I'm trying to set it up on a Toyota one wire design. I have my sensor wire ran to my cable stud on top or the alt, and a hot wire from my key to the back of the alt. The wire that is for ignition, the one for a light or bolt meter has nothing. Still running my battery dead. I've tried two tried and trusted alternators thanks
84toyotacrawler is offline   Reply With Quote Quick reply to this message
Old 09-26-2017, 05:00 PM   #2 (permalink)
Member # 783393
My alternator is a 86 btw with a built in voltage regulator
Old 09-26-2017, 06:29 PM   #3 (permalink)
Member # 221653
Ive only ever ran toyota alternators wired to a factory harness, but I know with gm 3 wire alternators that the 3rd wire has to be ran through a dummy light in order for them to work. You said yours goes to nothing. Try that.
Burn it in!
thebonds is offline   Reply With Quote Quick reply to this message
Old 09-26-2017, 07:13 PM   #4 (permalink)
clb 017's Avatar
Member # 166307
I may be wrong , but I think the ic needs an exciter circuit
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 09-27-2017, 11:47 AM   #5 (permalink)
Member # 783393
I never thought about the light, please explain the exciter circuit. I have a ignition wire ran to the ignition plug on the back of the alternator
Old 09-27-2017, 11:59 AM   #6 (permalink)
Member # 257954
Here is the wiring diagram if you don't have it. I never tried to run without the charge fuse. I think that's what you are trying to do, right?
tacoray4x4 is offline   Reply With Quote Quick reply to this message
Old 09-27-2017, 06:59 PM   #7 (permalink)
clb 017's Avatar
Member # 166307
IF I recall
The charge light comes on when you hit the key to ignition when you hit the starter button that pulls power through the ic and turns it on somehow or another been a long time since I read the specs.
Ic needs to see a drain of power.
Phawk photofukkit.
Old 09-27-2017, 07:04 PM   #8 (permalink)
TOYOTAPARTS's Avatar
Member # 61493
yes, you guys are right. Must have charge light to work.
Great deals on Toyota Parts: :
RCV 30 Spline axles FREE shipping.
Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs
TOYOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 09-27-2017, 08:35 PM   #9 (permalink)
Member # 102813
Check my Timber Tiger build in Gen 4x4. I believe I documented how I dealt with this same issue in my crawler.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
