Toys or 60s - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2018, 02:27 PM   #26 (permalink)
Member # 67357
Originally Posted by the_white_shadow View Post
Build you a set of 9s
what about 9s ????
KyTrash is offline   Reply With Quote Quick reply to this message
Old 05-29-2018, 02:30 PM   #27 (permalink)
Member # 103621
Originally Posted by KyTrash View Post
what about 9s ????
Just a 3rd option thats probably better than both a toy or a dana 60.
Fab'd 9 housing from his favorite vendor, ECGS third, 05+ Ford Dana 60 outers and 16-17+ 1580 factory ford D60 shafts for $300.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 07-26-2018, 10:45 AM   #28 (permalink)
Member # 67357
which axles did you choose to build ?
Old 02-08-2019, 10:44 PM   #29 (permalink)
Member # 79509
Restart the flaming. Truck is still in pieces, but next up. Shop has been tied up with work and other paying projects.
Originally Posted by GRMhick View Post
I went the diamond route 10 years ago on 35’s. Other than one pinion gear, I still haven’t broken them. I am extremely happy with these axles.
With that said, I couldn’t get an 05+ sd 60 for a reasonable price 10 years ago. All things being equal, I’d strongly consider a 60.
Really like the way your truck is set up. Kind of why i decided to go the route im going.
Toyota 8" decided just to build what i have and get going. Already way too much invested in the engine.
Dually full float Toyota rear. With BJ60 hubs its 61.5". Thought about starting a thread because theres a lot of misinformation out there on it.
Bought a couple axle sleeves (what cruiser guys call them). Theyre 2.650" long and meant to make a 40 housing 60 width. Itll make a mini housing 61.5" wide on stock hubs.
Yukon grizzly are $450 shipped each. RCVs are $775. Steering and such is $600. ARP 7/16" hubs studs all around.
I'll see what breaks and go from there. After seeing what rustynails truck has done (yes i know hes on 9.5s) and considering im NOT racing. It should hold.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 02-08-2019, 11:17 PM   #30 (permalink)
Member # 53528
have fun replacing r&p's
Old 02-09-2019, 09:06 AM   #31 (permalink)
GRMhick's Avatar
Member # 87
Send a message via AIM to GRMhick
$20 says he will break 75% less rear diffs becaise the dually axle is much stiffer, which will help with ring gear deflection.
The front end on the other hand... I worry about those extensions on a stock toyota mini axle. I bent 3 houings right under the spring perch in 6 months before I stepped up to the diamond. I’m at 10 years on the diamond with signifigantly more wheeling and still no issues.
And I had to add wheel spacers to my diamond to clear the 4.5” backspace wheels, making my truck 65” front and 64” rear.
. Diamonds. 35's.
. RestoMod.
GRMhick is offline   Reply With Quote Quick reply to this message
Old 02-09-2019, 10:27 AM   #32 (permalink)
Member # 79509
Did you just break the R&P teeth as per tradition? Or actually shear a pinion. And yes, the housing is definitely bigger than your typical mini rear. Hoping the grizzly/locker will add some rigidity as well.
Im not planning on it being a permanent solution. If I like the setup, then i can order a diamond and swap housing down the road. I also have a spare mini housing. If i need to be wider, i can add IFS hubs to the front and FJ80 hubs to the rear. Or just swap in an 80 rear. If i had a FJ60 front housing, id probably go 9.5s off the bat.
I just cant stomach spending $1000+ on a housing that i dont know 100% spec i want it built to. I wouldnt have thought FJ80 wheels would rub the springs.
Old 02-09-2019, 01:13 PM   #33 (permalink)
GRMhick's Avatar
Member # 87
The rear 8” elocker broke 9 of the pinion teeth. When it was in an FJ Cruiser, the same diff broke 3 ring gear teeth.
My guess is the 8” 4cyl housing didnt have enough oil volume and the axle overheated.
But no issues now that I have a diamond 9.5” rear axle
. Diamonds. 35's.
. RestoMod.
Old 02-09-2019, 01:46 PM   #34 (permalink)
Member # 53528
i think youre exaggerating there a little the stiffer housing might help but not no 75% if he put an ARB carrier in there and a solid pinion spacer then he might get up to that 75%
Old 02-09-2019, 02:00 PM   #35 (permalink)
GRMhick's Avatar
Member # 87
Everyone I have talked to who went to a diamond rear axle dramatically increased the life of 8” differentials. 75% seems correct to me.
. Diamonds. 35's.
. RestoMod.
Old 02-09-2019, 02:02 PM   #36 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
My gear guy says the same thing and he’s old and done a few Toyota diffs.
Old 02-09-2019, 02:45 PM   #37 (permalink)
Member # 79509
Is the ARB that much superior in strength/runout/flex versus another full case locker? Ive put in some cheap spools that the back lash varied depending on where on the ring gear i was measuring
GRM - still running an HP e locker on the front?
Old 02-09-2019, 03:48 PM   #38 (permalink)
Member # 53528
because people with diamonds say something doesnt mean its true, youre not gonna make a toy 8" 75% stronger with a better housing but i guess we will just have to agree to disagree
Old 02-09-2019, 06:51 PM   #39 (permalink)
Member # 156657
I will agree and disagree My thoughts are the third is only as strong as it can be . If you take that same third and put it in a housing that has some beef to it ,seems like it will take some stress out of the third. In a stock housing all the minor bends and tweaks seem like it will eventually play havoc on the third. My third is still good but on its third housing (all toyota and changed asap ) and this one is torque /collapsed from spring perch to brake backing plate. So I'm on the fence of which way to go.
cryptic toy is offline   Reply With Quote Quick reply to this message
Old 02-09-2019, 07:30 PM   #40 (permalink)
GRMhick's Avatar
Member # 87
Low pinion 8” elocker. Also out of an FJ Cruiser. Never an issue, even with early trail gear 5.29 gears.
. Diamonds. 35's.
. RestoMod.
Old 02-09-2019, 10:08 PM   #41 (permalink)
Member # 89362
I'm partial to toyota parts I have beat on 9.5" thirds pretty hard and they have held up pretty good. I would think that on 35's they would survive. I made a 60 series housing close to the same width as an 80 series rear using the spacer you talked about earlier. Trail gear makes a +5 short side that works when the spacer is added. Quite a lot wider but not quite full width. Allows me to turn 40's on my rig lock to lock and not touch the front leaves. I run a full gusset past the perches on a stock front housing and it seems to stay straight a bit better than others I have seen. I have a set of bigger axles (60/14 bolt) I could have put in a long time ago but these ones just stay together somehow?
too tall is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 12:47 AM   #42 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
Surely the Diamond housings are less prone to flex, but the biggest difference to me with the 8" gear sets was getting them cryo'd. I did all the other tweaks. buttonhead machine screws to replace the studs, solid crush, beefy anti-wrap link, etc., and still broke ring gears until I went cryo.
Originally Posted by Mustard Dog
Me and my co driver were running across the Lakebed on our way to pre run when we saw :gary: walking his dog.
We didn't stop to say hi cause he's a fucking douchebag.
Roc Doc is online now   Reply With Quote Quick reply to this message
Old 02-10-2019, 01:41 PM   #43 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
Here’s my bitch after 15 years of breaking, and building better. Name:  IMG_0556.jpg
Opinions are like assholes.Everybody has one,and most stink!
DEER TICK is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 09:07 PM   #44 (permalink)
tripleXJ's Avatar
Member # 67831
60s for me all day long. heavier, way more flex, overbuilt for most yota.
My old shit
97 TJ build:
My new Shit
buggy build:
tripleXJ is offline   Reply With Quote Quick reply to this message
Old 02-11-2019, 09:01 PM   #45 (permalink)
Member # 87116
60 up front
14-bolt out back
CRY ONCE orrrr cry twice.... your choice.
-Tow vehick: gen-2 24 valve 6-speed smoker
-mud toy496'd k30 D60/14b 4-speed 205 5.13's locked up
lilrick is offline   Reply With Quote Quick reply to this message
Old 02-24-2019, 03:18 PM   #46 (permalink)
Member # 208370
After reading threw this post ive got a few questions. I just picked up an 86 4runner. I'm debating swapping out the toys for d44 and a newer chevy rear with discs. I'm in Idaho, I dont think I will have any issues with narrow hard turn trails, this is my first "trail" rig build and I'd rather not build it multiple times, hence going full width and dual cases from the start before I build drivelines. Does anyone still run toyota leaf springs with full width axles? I also noticed someone mentioning Ford axles, isnt the diff on the wrong side?
BadRep is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 09:07 PM   #47 (permalink)
Member # 79509
Well, sold my FF 8" and spacers to a friend going under a much milder rig
I built a FZJ80 rear with a Grizzly and Nitro shafts. That should hold up to 35s all day.
On the front i have a couple of directions... I bent Brians ear over at FROR for a good hour awhile back. He seems to think that FJ80 vs Mini was a moot point, because at the end of the day its still 30 spline inners. Well, i have a 30 spline rear, so whatever.
I have a friend in Kangaroo land sourcing me a H233 HP front diff. (31 spline carrier). I have a SD D50, 84 mini axle, and a FJ80 front for donor outers... Or I found a Dodge KP D60 collecting dust, but the weight and clearance penalty doesnt seem worth it.
Given those options, and only those options, discuss. Back in the day my last rig was a F350 with D60s on 35s. The gas peddle was binary and i never broke an axle shaft, because it couldnt go anywhere without full throttle. so (in my mind) 30 spline will work. Money not an option, i already know im spending $3500+ on the front.
Old 08-09-2019, 05:40 PM   #48 (permalink)
Member # 5371
Send a message via MSN to rockota
I agree with this. ISsues with an older ARB I had ended up being hosing flex/bend.
rockota is online now   Reply With Quote Quick reply to this message
Old 08-09-2019, 06:34 PM   #49 (permalink)
YotaAtieToo's Avatar
Member # 25632
FJ80 front, yes they are the same 30 spline as the mini truck. But you still hear about broken chromo birfs every now and then, most likely from age and wear, but it still happens. The bigger advantage to me is the size of the balls and knuckles, especially if you go hellfire. Plus you get sharper steering.
Old 08-22-2019, 08:03 AM   #50 (permalink)
Member # 102813
I wish I could post picks easy. I would show the load bolt marks on the backside of my ring gear. Ring gear deflection is real.
Custom load bolt in 9.5 thirds is money. Shafts are not a issue since they are 35 spline.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
