5th stud mod question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-22-2019, 06:16 AM   #1 (permalink)
Member # 181179
Does anyone make a kit for this. If I remember long field had a kit at one time but I canít find it anywhere. I know I can make it cheap but. Iím a lazy bastard and buying the thick steel then making templates and going to my buddies to plasma them out then welding ect....... it would rock to just buy them and drill the hole weld them on the arms and done
stereoguy is offline   Reply With Quote Quick reply to this message
Old 03-22-2019, 07:45 AM   #2 (permalink)
Member # 3886
The fifth stud mod became obsolete with the advent of arp studs. Then again with keyed arms.
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 03-22-2019, 04:13 PM   #3 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
5th stud is still the best budget option don't need thick plate, if you don't mind taking it in the ass price wise, i'm pretty sure home depot or lowes will sell you some 3/16" plate and nuts/bolts to get it done. a single cutoff wheel should last long enough to get through it.
make a small square, drill a hole it in it, drill a hole in the knuckle, clamp plate to knuckle using bolt, then put whatever shape fits between arm and plate. weld in place.
i'd love to have keyed arms, but $10 is $10
Old 03-22-2019, 04:29 PM   #4 (permalink)
Member # 79509
You should also martack the birfields.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 03-22-2019, 05:14 PM   #5 (permalink)
Member # 3132
Martacks were a joke. People who couldn't figure out how to remove and reinstall c clips. I have a nice example on my garage floor of why you do a "martack"
Old 03-22-2019, 05:16 PM   #6 (permalink)
Member # 777769
Troth
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 06:16 AM   #7 (permalink)
Hyde802's Avatar
Member # 181835
Send a message via AIM to Hyde802
Always thought these were a neat option. But you still have to buy the arms.
https://www.4x4labs.com/products/six-stud-blocks
5th stud is stronger than arps.. and you can always just add arps to your 5th stud.
The point of a 5th stud is to get it done cheap. If you have to buy anything but the bolts your doing it wrong.
92 Toyota Extracab; locked, caged, beat on 38s
Were all mad here
Hyde802 is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 06:55 AM   #8 (permalink)
Member # 181179
I already have all ARP studs and had 30 spline birfs. Iím just trying to add a bit more torsional strength to the steering. My hydro assist will loosen up my studs after a while of wheeling. This should do the trick. I was just trying to be lazy . I ordered RCV shafts and trunion eliminator kit,so when they come in Iím going to do the 5th stud mod too.
Old 03-23-2019, 04:06 PM   #9 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
One thing a lot of people make a mistake doing when they have HA is not limit the ram travel. If your ram still has travel after the knuckles it needs to be limited so it stops pushing right before the steering hits the stops. I have seen and witnessed, studs breaking, nuts coming loose and knuckles breaking. It happened on mine when I first put HA on. I fixed it by taking the ram apart and cutting limiting discs out of Delrin and installing on the inside of the ram.
May be something for you to check on your set-up!!
Old 03-23-2019, 05:05 PM   #10 (permalink)
Member # 724713
I did the 4lab block and cut up a stock steering arm.
Joey f is offline   Reply With Quote Quick reply to this message
Old 03-23-2019, 07:36 PM   #11 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
damn joey, that looks pretty solid
Old 03-23-2019, 09:00 PM   #12 (permalink)
Member # 703953
The best way imo is to tap the grease hole out to a big bolt and put a plate on an angle. Bolt it up tight and tack the plate to the high steer arm. Remove and fully weld.
It makes way more sense than throwing another stud in the same plane as the stock studs.
Did a bunch this way "back in the day". One set on a buddy's truck has been on for 12 years and never loosened
eat.sleep.wheel is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 09:42 AM   #13 (permalink)
clb 017's Avatar
Member # 166307
As a rookie to h.a. This sounds like a great tech thread for the bible (as I do not recall seeing it in the hydro threads) just thinking out loud, did I miss something in the bible?
@OOP'S
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 09:54 AM   #14 (permalink)
Member # 724713
5th stud is cheap and works great but never have run anything over 36 with it. This new rig is going to run full hydro and 4Ds, so I wanted to try something a little different that wouldn't break the bank.
Old 03-24-2019, 10:52 AM   #15 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
@OOP'S
It was something I came up with when I first did HA, I had the frontend on jackstands and the ram was not bolted to the tie rod, steering was at DS lock and I pulled on the ram and the ram still had more travel, I may have not had the ram mounted in the right place but since it was all welded up I did not want to change it.
It is just something I would look at, after I limited it the steering arms quit coming loose!!
Old 03-24-2019, 10:52 AM   #16 (permalink)
Member # 777769
@OOP'S
Thatís not new, and has been posted in quite a few threads. The search sucks so bad lately, and the Bible is badly needing a refresh.
https://
My dog will eat you
Old 03-24-2019, 05:38 PM   #17 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I know, I have posted it up quite a few times in the past!!
Old 03-24-2019, 05:49 PM   #18 (permalink)
Member # 777769
You have recommended it to everyone that has had questions too. Glad to have you back, didnít see you post for a while.
https://
My dog will eat you
Old 03-24-2019, 06:34 PM   #19 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I lurk everyday!!
Old 03-24-2019, 06:52 PM   #20 (permalink)
Member # 111580
I disagree, I have seen and broke my share of ARP studs. keyed/6 stud arms are nice, but on any budget build a 5th stud is a great and very cheap upgrade.
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 07:59 PM   #21 (permalink)
Member # 79509
If you're buying new, just do keyed arms. Stepping over dollars to pick up pennies.
Old 03-24-2019, 10:21 PM   #22 (permalink)
Member # 777769
I thought you can only brake a stud with a cone washer is if it is loose. Once itís loose it can be leveraged. ARPs with a higher tensile strength allowed a higher torque. Keying the arms is the big jump in strength.
I am regurgitating stuff Iíve read, point out where itís wrong or missing something.
https://
My dog will eat you
Old 03-24-2019, 11:02 PM   #23 (permalink)
clb 017's Avatar
Member # 166307
Thanx gents
Gunna see how bad the tg h a is as installed...
Phawk photofukkit.
Old 03-25-2019, 06:44 AM   #24 (permalink)
Member # 3132
At some point the clamping force is overcome. And apparently it happens with 37"s.
Old 03-25-2019, 07:15 PM   #25 (permalink)
Member # 111580
I never said anything about new, I can buy used HS arms for a hundred bucks, add a 5th stud and done. I am in no way saying keyed arms are a waste just suggesting that with a limited budget you can get away with a 5th stud and spend money on other things.
BUCK OFAMA
4 seater LS1 buggy
Similar Threads
Atlas stud issue? lil,yota General 4x4 Discussion 29 01-05-2015 04:51 PM
Toyota Tach Mod Questions 22RE to 3.4 Swap aztoyman Newbie General 4x4 Discussion 4 08-07-2013 10:12 PM
I need a barney style explanation on 5th wheeling Otto Man Tow Rigs and Trailers 12 08-01-2013 06:55 PM
Lucas Oil Regional Series AZ Presented by SDHQ Off-road "ROUND 3" May 5th Speedworld! JONES23 Competitions and Events 4 04-25-2012 03:09 PM
Lucas Oil Regional Series AZ Presented by SDHQ Off-road "ROUND 3" May 5th Speedworld! JONES23 Short Course 1 04-25-2012 12:37 PM
