22RE Noise/Knock - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-05-2019, 06:07 PM   #1 (permalink)
Member # 866656
Unhappy 22RE Noise/Knock
I know there is some old info on this site from about 8 years ago but am wondering if anyone might have fresh ideas. Looking for some cheap/easy ways to narrow down what I might be facing with my 91 Toyota 4x4 22re. there is a noise/knock in the motor. From low RPM to high RPM it changes. Low to mid RPM is noisy mid to high it goes away. When you drive it's louder starting out, but when at cruising speed, RPM's up, really can't hear it. When you let the engine do a compression brake upon stopping it gets really loud....any ideas?
1LGXman is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 08:58 PM   #2 (permalink)
Member # 13786
Wrist pin?
how's the oil pressure?
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 09:56 PM   #3 (permalink)
ADD
Member # 22080
Broken timing chain guides...?
Chain gets tight upon higher rpms, and isn't hitting the cover
Got custom cab?
ADD is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 12:58 AM   #4 (permalink)
Member # 866656
It has the metal chain guides so would hope it didn't break one of those. Last August toyota did the oil pump seal, valves and cam because the cam ate itself. I'm hoping that whatever this is will be related to the warranty on that work. It sounds like it could be related to valves or something in that area but I'm not very familiar with that type of engine work so am just guessing.
Old 04-06-2019, 07:20 AM   #5 (permalink)
ferg's Avatar
Member # 33169
T/C chain tensioner stuck? Drop in a qt of atf and drive around the block a couple times. Drain and refill oil and repeat.
Do you [I]really[/I] care what I drive?
ferg is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 02:39 PM   #6 (permalink)
Member # 67823
Did you use RTV doing the work last summer? I once had a tiny piece of RTV clog the tensioner and cause my timing chain to slap.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
Similar Threads
Toyota 22RE engine parts- performance and stock GreatLakesGuy Engines/Trannys/T-Cases For Sale 12 06-16-2016 11:02 AM
chinese 22re cylinder heads- check them before installing!! sjracer Toyota - Truck and 4Runner 9 05-20-2014 08:55 AM
NorCal Toyota Parts Lot, 22RE, 22R Carb Wiring harness, Sub, W56, Tcase uniman Misc. Stuff For Sale 10 03-18-2012 02:18 PM
