Issue Bleeding Brakes (Wilwood dual piston) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-06-2019, 06:24 PM   #1 (permalink)
Bob Williams's Avatar
Member # 4421
I'm using the Toyota power brake setup on my 94 4runner, 22re.
Running one ton axles, and while the brakes worked ok previously, after finishing my four link project on the front, I can't get the front brakes to bleed.
The rear brakes did fine. I can loosen every fitting from the master cylinder to the caliper and I get fluid when the brake pedal is depressed. When I open the bleeders on the caliper and the brake pedal is depressed, nothing. What gives?
Tried each side about 15 min each with no success.
Bob Williams is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 07:17 PM   #2 (permalink)
lil,yota's Avatar
Member # 102395
Pull the brake lines off the calipers as well as the bleeder vents...Use a paper clip and make sure all the ports are drilled.
I changed a slave cylinder one time and it turned out the bleeder hole hadn't been drilled out.
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 08:24 PM   #3 (permalink)
Member # 4421
Thanks, but the brakes have been on the truck since '02 and previously bled a hand full of times. That's why I'm scratching my head about this time.
Old 04-07-2019, 06:08 AM   #4 (permalink)
Member # 3886
Failed master?
Why were the brakes open?
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 04-07-2019, 06:08 AM   #5 (permalink)
Member # 3886
Failed master?
hold this...
Old 04-07-2019, 08:41 AM   #6 (permalink)
dfowlkes's Avatar
Member # 231443
Stupid question but the blenders are on top of the the calipers right? My buddy had his on wrong one time and couldn't figure out why they wouldn't bleed all the air out
85 Toyota fruggy
dfowlkes is offline   Reply With Quote Quick reply to this message
Old 04-07-2019, 07:58 PM   #7 (permalink)
Member # 4421
So, got frustrated and pulled the bleeders out all the way and looked right on top of the piston. Told my wife to slowly push the pedal and hold it down. Brake fluid drizzled out and I put the bleeder in and fastened it down - repeated on the other side. Brakes work fine. ???
Old 04-07-2019, 08:19 PM   #8 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
whatever it takes
I just want to build cars, collect watches and get tattoos.
The largest tax modification in 30 years, check it out!
Old 04-08-2019, 07:35 AM   #9 (permalink)
Member # 6170
The inline wilwood masters have to be bench bled for whatever reason. I usually just make up some brake lines that run from the ports back into the resivior. Then just pump the pedal a bunch to get the fluid to start moving. Immediately reconnect the brake lines and bleed as usual. If it runs dry you will probably have to bench bleed it again.
Kevin
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 11:59 AM   #10 (permalink)
Member # 1889
If you can bleed them by removing the bleeders, oozing fluid out, and then put the bleeders back, and that works, but loosening up the bleeders gets you nothing, the bleeders themselves are bad (plugged). Probably got rust or something in them over the years. I've had it happen on multiple different vehicles, I assume it's why Toyota put those little covers on their bleeders from the factory.
Scott@Rockstomper is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 09:01 PM   #11 (permalink)
Member # 3132
That really is not a stupid question. It does happen. Not very often, buy we get some fucking yards around here.
Similar Threads
'79 ford front d60 caliper mount questions knucklehead 61 General 4x4 Discussion 36 05-04-2019 07:06 AM
Dakota/durango: are 02+ dual piston calipers a worthy upgrade? montrose818 Dodge 3 09-04-2018 01:09 PM
How Do You Turn Off the Fawkin Quote Notification? rugger General Chit-Chat 106 08-21-2015 08:56 PM
Brake bleeding issue HeavyMetalXJ Jeep - Non Hardcore 15 08-18-2012 09:25 AM
99-04 D60 front brakes 14" wilwood bawz Axles/Tires/Wheels For Sale 0 03-07-2012 04:14 PM
