Help needed on fluctuating throttle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2019, 09:54 AM   #1 (permalink)
Member # 825442
All right here's the situation, 91 3.0 285K miles, after initial start up and the engine has been running for 3 to 5 minutes, The idle fluctuates up-and-down. I think it may be a vacuum leak but I cannot find any. I have cleaned intake, added new Throttle Position Sensor. Can anyone point me into a different direction?
Thanks for your time
Mike
welchdog is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 10:09 AM   #2 (permalink)
Member # 858714
Mike
Low on coolant or bad cold start sensor.
Murder Yota is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 10:18 AM   #3 (permalink)
Member # 825442
Coolant level good, I'll check sensor
Old 04-09-2019, 10:33 AM   #4 (permalink)
Member # 3886
Is tps adjusted properly?
Are your IAC hoses clear?
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 10:39 AM   #5 (permalink)
Member # 825442
Help me understand how the TPS could be adjusted. Will check the IAC hoses
Thanks!
Old 04-09-2019, 08:25 PM   #6 (permalink)
Bob Williams's Avatar
Member # 4421
IAC hoses, and check for crack in the intake hose - if you're still running the factory set up. They're sometimes hard to see.
Bob Williams is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 08:27 PM   #7 (permalink)
Member # 825442
Thanks Bob, it came with a KnN intake will check IAC hoses
Old 04-09-2019, 09:03 PM   #8 (permalink)
Member # 825442
Where would I find the IAC, I'm very handy under the hood but WTH is it
Old 04-09-2019, 09:23 PM   #9 (permalink)
dfowlkes's Avatar
Member # 231443
Have you checked for leaks with some sort of accelerant?
85 Toyota fruggy
dfowlkes is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 09:25 PM   #10 (permalink)
Member # 825442
No, I'll put that on the list too
Old 04-17-2019, 07:53 AM   #11 (permalink)
Member # 825442
Update: there is NOT an IAC on these vehicles, so I cleaned the cold start valve and let the engine run for 5 minutes, idle was a little high, but from my research this is normal. Will update after I run the engine longer.
Old 04-17-2019, 08:50 AM   #12 (permalink)
Member # 3886
Idk where you are getting your information. There is in fact an IAC. Its what the coolant hoses on the TB attach to.
hold this...
Old 04-17-2019, 01:33 PM   #13 (permalink)
Member # 825442
Since you are the only one to state that, and I am NOT doubting you, do you have a diagram or link to a diagram that shows it?
Old 04-18-2019, 06:44 AM   #14 (permalink)
Member # 3886
Do yourself a favor and find an FSM
https://www.yotatech.com/forums/f116...-valve-292172/
hold this...
Old 04-20-2019, 03:20 PM   #15 (permalink)
Member # 825442
Update:
Found a link to a FSM, pulled the throttle body today, NO WHERE in the FSM does it mention an IAC (not one that can be purchased from a parts store and replaced), the coolant hoses running to the TB were not clogged. I adjusted the TPS (didnt think it was possible) per the FSM.
Bottom line: clean cold start valve, adjusted TPS, cleaned intake and TB, seems to have solved my issue.
Similar Threads
Poison Spyder 2012 KOH Modified Class Build Dusty General 4x4 Discussion 993 04-13-2018 08:04 AM
YJ to LS motor throttle cable solution jeepbonehead Jeep - Hardcore Tech 9 01-04-2017 04:12 AM
Help with a GM Throttle Body Question ski1491 Chevy 0 04-17-2013 05:40 PM
99 Duramax accelerates hard with just a light touch of the throttle??? Honky Lips Newbie General 4x4 Discussion 5 12-13-2012 10:14 PM
New TBI: Adjusting Throttle Cable JamSezzion Chevy 3 09-13-2012 08:14 PM
