Pics of your 22re fuel lines - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2019, 01:52 PM   #1 (permalink)
chd
chd's Avatar
Member # 268842
If someone could post pictures of the stock fuel lines (EVAP, all of it) of your 22re pickup you'd save me a ton of time and money making my own. I can't figure out how the f they are supposed to go back in. It might be a little tricky considering I have a carbereuted cab.
chd is offline   Reply With Quote Quick reply to this message
Old 04-21-2019, 02:57 PM   #2 (permalink)
clb 017's Avatar
Member # 166307
Details be damned...
Anyhoo
I re routed my 83 alongside the carb routing, and up to the fuel reg\ rail gizmo...
What's the issue?
You can use truck\runner lines from the wreckin yard and cut\paste them to fit.
But nothing is impossible, read up in the re swap threads.
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 04-22-2019, 07:23 AM   #3 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Hope this is what you need!!
Old 04-22-2019, 08:39 AM   #4 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
i agree with OOPS, it is pretty straight forward.
i used the same 3/16 (pretty sure?) brake line for my fuel rail that i used for my brakes. Fuel runs about 45 psi and brakes run about 50x that.
Old 04-22-2019, 11:18 AM   #5 (permalink)
chd
chd's Avatar
Member # 268842
Damn. Was really hoping for someone who could slide under their truck for 5 minutes and take a couple pics.
Old 04-22-2019, 12:11 PM   #6 (permalink)
Member # 225201
Send me your email I’ll see what I can do when I get home.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 04-22-2019, 12:29 PM   #7 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
I'm not sure what you are looking for on account of your limited info, but i'm pretty sure i've got pictures in my build thread
https://www.pirate4x4.com/forum/toyo...-colors-9.html
probably somewhere around post 200? I dunno but i when i did the EFI swap i redid a bunch of the lines
Old 04-22-2019, 05:08 PM   #8 (permalink)
Member # 225201
Pics inbound via email.
Old 04-22-2019, 05:11 PM   #9 (permalink)
chd
chd's Avatar
Member # 268842
Awesome, thank you!
Old 04-23-2019, 06:16 AM   #10 (permalink)
chd
chd's Avatar
Member # 268842
Those were great! The more the better!
Old 04-23-2019, 07:25 AM   #11 (permalink)
Member # 225201
That’s all there is, 2 lines under the passenger side from fuel tank to engine. Not much else to show.
Old 04-23-2019, 08:53 PM   #12 (permalink)
chd
chd's Avatar
Member # 268842
And the actual fuel line that runs to the fuel filter is bolted to the frame, correct?
Thatís all there is, 2 lines under the passenger side from fuel tank to engine. Not much else to show.
Old 04-24-2019, 09:33 AM   #13 (permalink)
Member # 225201
I'll look tonight.
Old 04-24-2019, 08:03 PM   #14 (permalink)
chd
chd's Avatar
Member # 268842
You're awesome man.
I'll look tonight.
Old 04-25-2019, 07:08 PM   #15 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Actually there are 3 that go to the tank, feed, return and vent line to charcoal cannister!!
Similar Threads
TJ/LJ 19 Gallon Fuel Cell by Motobilt MotoBilt Miscellaneous 4 06-19-2019 10:01 AM
22re fuel pressure Crawlin1stgen Toyota - Truck and 4Runner 13 10-17-2018 08:12 AM
22re loses fuel pressure Stevie123 Toyota - Truck and 4Runner 2 04-24-2018 07:38 AM
What is wrong with my fuel system? Dookey General 4x4 Discussion 272 01-26-2015 02:28 PM
while devot roopsys Desert Racing 1 10-08-2014 01:25 PM
