Race truck! - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-28-2019, 10:00 PM   #26 (permalink)
Member # 53528
and bridge over the diff armor so your truss is full length, im not sold on the diff armor doing the job of a truss
and save up for ARB's the ARB carrier is huge and greatly reduces the carrier deflection. once i went to a HP 3rd with arb 5.29s and solid pinion spacer i no longer broke gear sets several times a year , weak link became chromo birfs
rockyota83 is online now   Reply With Quote Quick reply to this message
Old 04-28-2019, 10:04 PM   #27 (permalink)
Member # 53528
honestly though, just build it the best you can and go have fun, try to win, but make sure its fun too
Old 04-29-2019, 03:07 AM   #28 (permalink)
Newbie
Member # 215338
Itís almost sad to see the truggy that lived many lives get cut up, letís just hope you do a better job of keeping this truck rubber side down then you did the last one.....
lulatacoma is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 07:23 AM   #29 (permalink)
Corey Young's Avatar
Member # 21622
Is the bobbed bed legal?
Old 04-29-2019, 07:24 AM   #30 (permalink)
pitbullcruiser's Avatar
Member # 193971
This guy gets it!
ECORS Toyota #779
pitbullcruiser is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 08:01 AM   #31 (permalink)
Member # 95025
Nice build indeed.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 12:57 PM   #32 (permalink)
Rooster831's Avatar
Member # 361841
I dont think so
"2) Stock body (body is considered to be the full cab, including all interior and exterior
sheet metal, bed, doors, hood, fenders, grill, etc.) required. The body must be
complete and unmodified, with the following limitations and exceptions: Holes may
be cut in any part of the body for the single and exclusive purpose of allowing roll
cage tubes and transmission/transfer case linkage to pass-through the body. Open
holes must be kept to within .5"(12.5mm) of the diameter of any tube or linkage that
passes through the body, with further restrictions related to holes in firewalls
specified in Section 8.2.12, Subsection 4. The exception to this rule is the allowance
for rocker panel protection limited to the area between the wheel wells. You may
cut into the body and/or reinforce this area. You may not interfere with the mating
surface of the stock door and doorsill. The stock doorsill must be retained and
unaltered."
Spending thousands of dollars on a vehicle for the sole purpose of driving over shit in the woods.
Rooster831 is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 01:47 PM   #33 (permalink)
Member # 140628
Awesome! I think after Justins win last year we're gonna see alot more Yotas back on the line. I hope so anyway.
hodgiemoto is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 02:20 PM   #34 (permalink)
Member # 523289
10 months to go and you're already 70% done, you should get a ton of testing time. Looking forwards to seeing this beat a V8 4Runner
1990 FJ62 - Driveway Ornament.
cruisermattfj62 is offline   Reply With Quote Quick reply to this message
Old 04-29-2019, 02:52 PM   #35 (permalink)
Member # 21622
Is the back of the frame shortened? Is that allowed?
Old 04-29-2019, 04:20 PM   #36 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
Subbed for updates, cool to see another garage build going on.
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
88 4Runner Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 04:18 PM   #37 (permalink)
Member # 861336
I think that if it's a long bed bobbed to a short bed length it would be within the class rules since it was an offering in that model year.
tyson84runner is offline   Reply With Quote Quick reply to this message
Old 05-02-2019, 05:23 PM   #38 (permalink)
Member # 193971
35Ē DOT Krawlers on 15Ē DIY bead locks.
ECORS Toyota #779
Old 05-02-2019, 05:27 PM   #39 (permalink)
Member # 193971
I started painting the rear of the cage today.
ECORS Toyota #779
Old 05-03-2019, 11:47 AM   #40 (permalink)
Member # 193971
I got the radiator shroud and e-fan knocked out.
ECORS Toyota #779
Old 05-04-2019, 04:14 PM   #41 (permalink)
Member # 193971
Filling up the bed some more.
ECORS Toyota #779
Old 05-04-2019, 05:19 PM   #42 (permalink)
Member # 193971
Painted 3 of the 4 number plates.
ECORS Toyota #779
Old 05-09-2019, 08:07 PM   #43 (permalink)
Member # 193971
Started working on the traction bar axle mount. I recycled the trac bar from my old truck. I also started getting the hydro assist steering going.
Cardboard template.
Draw it out.
Cut it out.
Weld it together.
Tapped IFS steering box.
Hydro assist ram and ram stuff.
Cooler and reservoir.
IFS box in place.
ECORS Toyota #779
Old 05-09-2019, 08:39 PM   #44 (permalink)
Member # 136471
Looking real good! May want to add some additional braces to the shock hoops. They like to rip off the stock frame without plating.
Now we just need some events in the PNW!
boardbysled is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 08:36 AM   #45 (permalink)
Member # 193971
Shock hoops will definitely get some braces after I get the air bumps mounted. The first event for this truck will be the ReiterRockCrawl in July.
https://m.facebook.com/ReiterRockCrawl
ECORS Toyota #779
Old 05-10-2019, 06:54 PM   #46 (permalink)
Fab Junky
bark beetle's Avatar
Member # 147257
Nice build!
Sent from my iPad using Tapatalk Pro
bark beetle is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 07:51 PM   #47 (permalink)
Member # 136471
Figured you had a plan!
Old 05-14-2019, 07:09 PM   #48 (permalink)
Member # 193971
Working on the steering and stuffing shocks in position.
ECORS Toyota #779
Old 05-14-2019, 08:30 PM   #49 (permalink)
Member # 136471
Do the drag-link heims bind without high-misalignment spacers?
Old 05-14-2019, 09:34 PM   #50 (permalink)
Member # 193971
Yes and the pitman arm is too long also. I ordered a shorter pitman arm and the hardware to fix the heim joint issues.
ECORS Toyota #779
Similar Threads
fawk it! i think i`m building a vintage truck RoosterBooster Tow Rigs and Trailers 3607 02-04-2019 06:19 AM
1975 712m 6x6 ex-Racing Pnzgauer aka The Warn Pinz RMP&O Vehicles and Trailers For Sale 12 09-30-2013 11:34 AM
The Bomber - Ultra4 Race Car napsta Vehicles and Trailers For Sale 18 04-26-2013 03:25 AM
Race timing software review: Racesplitter mark99tj Competitions and Events 28 04-24-2013 08:22 PM
Multi Motorsports Mexican Racer Finishes The Gorm 24Hr Race * Offroad Nurburgring! WorldRallyTeam Competitions and Events 25 10-26-2012 01:20 AM
