Race truck! - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 05-16-2019, 07:46 PM   #51 (permalink)
Member # 523289
Can't wait to see the V8 4Runner get beat by this one too.
1990 FJ62 - Driveway Ornament.
cruisermattfj62 is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:26 AM   #52 (permalink)
pitbullcruiser's Avatar
Member # 193971
Working on getting all the shiny stuff in position. Fox 2.5 shocks and fox 2.0 air bumps. The bumps still need landing pads front and rear.
ECORS Toyota #779
pitbullcruiser is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:30 AM   #53 (permalink)
Member # 79509
Looks like the shocks will bottom out long before the bumps come close to touching anything.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:44 AM   #54 (permalink)
Member # 143737
Hopefully the landing pads solve that
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 03:16 PM   #55 (permalink)
Member # 193971
Itís a roller again! The truck still need a few little things here and there before itís done.
ECORS Toyota #779
Old 05-22-2019, 08:28 PM   #56 (permalink)
Member # 226216
Bad ass! Keep it up, looking forward to seeing you kick some ass.
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 08:46 PM   #57 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
now get to beating it
Old 05-24-2019, 08:39 AM   #58 (permalink)
Member # 193971
I got the landing pads for the bumps done.
ECORS Toyota #779
Old 05-24-2019, 09:46 AM   #59 (permalink)
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
no offense... but did you cycle the suspension at all to set up those bumps?
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
2019 Tundra
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 05-24-2019, 11:29 AM   #60 (permalink)
Member # 193971
None taken. They will get reassessed once the springs break in. Anyone got any links or recommendations for setting up air bumps?
ECORS Toyota #779
Old 05-24-2019, 02:52 PM   #61 (permalink)
Member # 45812
the proper way to do it is to break down your springs to the main leaf, use some sort of spacer in place of the other leafs, and put your axle to full bump (either shock travel, springs going flat, or clearance to frame, oil pan, etc). from there, you can locate and mount your air bumps. i would leave at least an inch of shock shaft showing if your shocks are outboard of the bumps to account for some articulation. hope that helps.
-Mikey-
Party Wagon
2019 Tundra
Old 05-24-2019, 03:06 PM   #62 (permalink)
Member # 193971
Awesome, thanks man.
ECORS Toyota #779
Old 05-24-2019, 04:50 PM   #63 (permalink)
Member # 193971
Ok, letís try that again. I use a ratchet strap to suck the suspension down instead of taking the leaf springs apart. Proper bump pads coming shortly.
ECORS Toyota #779
Old 05-24-2019, 06:46 PM   #64 (permalink)
dfowlkes's Avatar
Member # 231443
Nice work man, way to take direction and not get offended. Knowladge will come with time. I think it's cool what you're doing.
85 Toyota fruggy
dfowlkes is offline   Reply With Quote Quick reply to this message
Old 05-24-2019, 08:23 PM   #65 (permalink)
Member # 193971
Thanks, you going to make it to the Reiter Rock Crawl this year?
ECORS Toyota #779
Old 05-31-2019, 06:59 PM   #66 (permalink)
Member # 193971
Nothing too exciting, harnesses showed up. Still waiting on seats and window nets.
ECORS Toyota #779
Old 06-02-2019, 05:30 PM   #67 (permalink)
jones518's Avatar
Member # 152143
THIS IS AWESOME. You truly have the right idea. Cut, weld, Race. kudos!
Only thing I have for you (besides mild concerns over bobbed bed, but you have time to unbob it if need be), are the open tube ends. Ultra4 will make you cap those, you probably already know that. keep up the good work! Lets go pre run JV this fall!
jones518 is offline   Reply With Quote Quick reply to this message
Old 06-02-2019, 09:28 PM   #68 (permalink)
Member # 193971
Thanks man, just trying to keep it classy. All the ends of the cage are capped. The front and rear bumper still need to be finished. I think I am going with another piece of vertical tube and caps to close the ends off. Safety triangles!
ECORS Toyota #779
Old 06-03-2019, 06:35 PM   #69 (permalink)
Member # 193971
I got seats.
ECORS Toyota #779
Old 06-03-2019, 06:43 PM   #70 (permalink)
Member # 40301
Love the build. Been meaning to post up here. I moved up to the Fredrickson area about a year ago. I have been to every KOH but 2 and i am a toyota guy. I have a decent set of machines in my garage (mill, lathe, MIG, TIG, tubing bender etc). From the looks of it you are basically done but if you need a hand either up here or down at KOH I will be down there. And if I ever get my 1UZ 1st gen done I need to find some local trails.
You can't believe everything you read on the internet. That is how WWI got started.
trialsintrigger is offline   Reply With Quote Quick reply to this message
Old 06-03-2019, 07:29 PM   #71 (permalink)
Member # 193971
Nice! Thanks man, I will definitely be needing a few bends to finish my bumpers. I will shoot you a PM when I get to that part.
ECORS Toyota #779
Old 06-06-2019, 06:37 AM   #72 (permalink)
Member # 502649
I would make sure the pads are really beefy and try to get as much uptravel as possible. A friend of mine had a similar setup with only a inch or so before contacting the bump and the truck would pogo badly at any real speed. Food for thought. Otherwise I like the build a lot.!
Twmdodge99 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 02:26 PM   #73 (permalink)
Member # 213125
Front axle already looks bent.
Aisin is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 04:14 PM   #74 (permalink)
Member # 193971
LOL, itís good. With the ease in which the shafts and birfs went in, it seems pretty straight. It will have to do for now. Saving my pennies for a aftermarket housing.
Got a seat in.
ECORS Toyota #779
Old 06-07-2019, 09:55 AM   #75 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
Good, then you can get it the width you need and ditch those wheel spacers.
(If class legal, didn't look that up.)
I get adds for ghey cruises.....
Anyone else????
Roc Doc is offline   Reply With Quote Quick reply to this message
Similar Threads
fawk it! i think i`m building a vintage truck RoosterBooster Tow Rigs and Trailers 3607 02-04-2019 06:19 AM
1975 712m 6x6 ex-Racing Pnzgauer aka The Warn Pinz RMP&O Vehicles and Trailers For Sale 12 09-30-2013 11:34 AM
The Bomber - Ultra4 Race Car napsta Vehicles and Trailers For Sale 18 04-26-2013 03:25 AM
Race timing software review: Racesplitter mark99tj Competitions and Events 28 04-24-2013 08:22 PM
Multi Motorsports Mexican Racer Finishes The Gorm 24Hr Race * Offroad Nurburgring! WorldRallyTeam Competitions and Events 25 10-26-2012 01:20 AM
