Odd noise after replacing rcv s and 3rd member - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2019, 05:49 PM   #1 (permalink)
Member # 181179
I replaced my birfields and 3rd member recently. Now I have a odd squeaking noise when I lock my hubs. If I turn hubs to free no noise. Itís hard to tell where itís coming from. It sounds like the birfield maybe binding up a bit. Anyone have any ideas what could be going on ?
stereoguy is offline   Reply With Quote Quick reply to this message
Old 05-25-2019, 05:59 PM   #2 (permalink)
Member # 53528
dust shield on pinion flange
Old 05-25-2019, 06:10 PM   #3 (permalink)
Member # 181179
Is it anything to be worried about or will it go away after a bit. I tried loading a video to phototbucket but they suck. The 3rd member is a trail gear one with 5.29 and Detroit locker.
Old 05-25-2019, 06:39 PM   #4 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Does it do it in 4wd with the hubs unlocked?
Old 05-25-2019, 07:07 PM   #5 (permalink)
Member # 79509
Originally Posted by stereoguy View Post
Is it anything to be worried about or will it go away after a bit. I tried loading a video to phototbucket but they suck. The 3rd member is a trail gearone with 5.29 and Detroit locker.
Theres definitely a correlation with all the issues you've been having.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 05-25-2019, 07:41 PM   #6 (permalink)
Member # 181179
I havenít tried that yet.
Old 05-25-2019, 08:10 PM   #7 (permalink)
Member # 181179
I just tried unlocking the hubs and putting the truck in fwd and it does make the same sound.
Old 05-25-2019, 08:14 PM   #8 (permalink)
Member # 181179
I donít see one. I broke a pass side birfield that was a decade old and just bought the new versions. The diff had a few small chips in the pinion from the abuse it has taken also a decade old. I just havenít had much time lately to put this back together and now itís all together and I heard a small squeak like sound from up front.
Old 05-25-2019, 08:17 PM   #9 (permalink)
Member # 841585
Second the dust shield. Pute the front end up on stands and rotate pinion by hand and see/hear if the shield is kissing the third member. A little tweaking with a screw driver usaully gets it to stop. Both mine squeeked after rebuild.
Purpledecember is offline   Reply With Quote Quick reply to this message
Old 05-25-2019, 09:43 PM   #10 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Dust shield, or birf rubbing to hard on the spindle/housing.
Some axle shafts need a scoch ground off the ends to fit right.
Old 05-25-2019, 10:47 PM   #11 (permalink)
Member # 53528
you dont need to put the axle on jack stands if you have locking hubs, just unlock the hubs then the pinion and drive line will spin by hand(if the transfer case is in 2x4)
Old 05-26-2019, 05:57 AM   #12 (permalink)
Member # 181179
I think this is the ticket. The dr side was a touch tight going in. Do I grind both ends a touch or just the diff side?
Old 05-26-2019, 06:44 AM   #13 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Birfield rubbing on the inside of the ball, may need to clearance the ball a bit with a die grinder. Take the Birfield off, clean the grease up, spray paint the inside of the ball, reassemble and turn the front end with the hubs locked, take apart and see were the paint is rubbed off and grind there. May take a bit of assembly and disassembly. Had to do it to mine down at the Hammers on the lakebed floor!!
Old 05-26-2019, 07:25 AM   #14 (permalink)
clb 017's Avatar
Member # 166307
Just trailmart, most likley dust sheild, or could be much more!
Best of luck!!!
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 05-26-2019, 08:15 AM   #15 (permalink)
Member # 181179
Would it self clearance itself.
Old 05-26-2019, 08:15 AM   #16 (permalink)
Member # 181179
Best of luck!!!
I hope not. But ?
Old 05-26-2019, 08:24 PM   #17 (permalink)
clb 017's Avatar
Member # 166307
Ummmmm
Just like a preggers girlfriend
Jump onto either one of the posts by ....
Boby aka longfeild...
Or the host of yota guys here.
Re read oops info, look fer cammos quick change, and mr stubbs notebook
For starters
Phawk photofukkit.
Old 05-27-2019, 07:39 AM   #18 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Eventually. your Birifield's and trunnion bearing's and seals would love all the metal scrapings
