Different Toyota Carriers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2019, 02:49 PM   #1 (permalink)
Member # 166653
I have searched and searched and have not found an answer.
Does Toyota (like other manufacturers) use a high gear carrier and low gear carrier in their differentials? I know there are different 3rd members for V6 and I4 trucks, that is not what I am asking. I know if I want to regear a Chevy from 3.07 to 4.89 I have to use a different carrier.
But I can't find if a 4.10 and 5.71 Toyota use the same carrier.
4seasons is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 03:14 PM   #2 (permalink)
Member # 3886
The V6 and HP carriers are the same. Toyota uses the same carrier regardless of gear ratio.
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 03:15 PM   #3 (permalink)
Member # 6170
No. I have never seen different carrier offsets for toyotas.
Kevin
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 07:08 PM   #4 (permalink)
Newbie
Member # 850254
Toyota carriers are the same regardless of ratio. I would avoid the 5.71 gears if at all possible, they have a reputation for being weak
mkyhmltn is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 09:25 PM   #5 (permalink)
clb 017's Avatar
Member # 166307
Search button newb
Hit the bible
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 07:23 AM   #6 (permalink)
Member # 213125
Stop spreading bullshit.
571 gear strength
Aisin is online now   Reply With Quote Quick reply to this message
Old 06-08-2019, 07:38 AM   #7 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
The only 8" carrier that has a different offset is the factory 4:88!!
Old 06-08-2019, 08:30 AM   #8 (permalink)
Member # 213125
I’m pretty sure that 3rd member I have with 3.07s has a different carrier.
Old 06-09-2019, 12:45 PM   #9 (permalink)
Member # 166653
Originally Posted by clb 017 View Post
Search button newb
Hit the bible
Not a Newb, my post count won't go up.
And if you could read you would see that I have searched and searched and could not find it
Old 06-09-2019, 01:01 PM   #10 (permalink)
Member # 166653
571 gear strength
I find that those who think 5.71 gears are weak have never ran them. Sure if you run lot's of torque thru them while running 44" Boggers, you can strip the pinion, but you will do this with 4.10 as well. If you are breaking the ring and pinion, you need to go to one tons.
I have ran 5.71 with a locker and Lincoln spool while hauling 1.5 ton of rock up a steep and rocky hill several times a week for over a year. I broke a hub and motor mount and wore the tie rod ends out, but never hurt anything inside either axle. I was running Chevy spings with add-a-leaf on 31s.
Old 06-09-2019, 01:04 PM   #11 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
There is a lot of info right here compiled over many years.
https://www.pirate4x4.com/forum/toyo...faq-2-0-a.html
Old 06-09-2019, 01:08 PM   #12 (permalink)
Member # 166653
Iím pretty sure that 3rd member I have with 3.07s has a different carrier.
I didn't know there was a 3.07 Toyota. I have only seen as high as 3.90 before. I guess that 3.07 would have to have a different carrier as the 4.10 gear is getting pretty thin.
Old 06-09-2019, 01:09 PM   #13 (permalink)
Member # 213125
Yes. 89 carbed 4 speed.
Old 06-10-2019, 03:51 PM   #14 (permalink)
wentz912's Avatar
Member # 73194
In the 4wd or 2wd flavor? I've seen them in the 2wd (I've owned three separate ones), but never seen one in a 4wd housing.
it's worth noting that the 3.07 third member housing is also SIGNIFICANTLY different than your typical 4wd 8inch housing also.
85 X Cab.....Thing
wentz912 is offline   Reply With Quote Quick reply to this message
Old 06-10-2019, 08:34 PM   #15 (permalink)
clb 017's Avatar
Member # 166307
Whatever
F=phawk
U= you
C= can you believe the net???
K= kanadasyrupsuckers...
Serch button here???=fuckkit
Phawk photofukkit.
Old 06-11-2019, 01:06 PM   #16 (permalink)
Member # 19077
The carrier in the factory 4.88 is normal and not offset. The diff housing however is offset and will not accept any gearset other than the 4.88 that came in them. The bearings and carrier are normal V6.
OP. The only Toyota diff that I am aware of that has a carrier break is the 8" clamshell front found in the front of the 03+ 4R, 05+ Tacoma, FJ cruiser, GX470, etc. Those are 3.73 and down, or 3.91 and up.
yotamasters.com
Max Volume is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 10:15 AM   #17 (permalink)
Pat
Member # 120
The carriers are still the same OOPS, Just housing and ring gear are different.
Try out a AppleSeed...
Pat is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 10:16 AM   #18 (permalink)
Pat
Member # 120
beat me to it
