22r sputters an dies - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2019, 09:02 AM   #1 (permalink)
Member # 870388
My trk idles and revs good when not moving.As soon as i put in gear an move it sputters an dies.Ive replace carb . igniter . coil. plug wires .distributor. fuel filter.I also cant get it to idle down lower.Screw is at end of adj.
coco976 is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 04:02 AM   #2 (permalink)
Member # 213125
Keep throwing parts at it. Youíll fix it eventually. If your grammar wasnít that of a fucking retard you might get more help.
Aisin is online now   Reply With Quote Quick reply to this message
Old 07-12-2019, 04:24 AM   #3 (permalink)
Member # 3886
Vacuum leak.
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 08:41 AM   #4 (permalink)
JDWeeler's Avatar
Member # 170770
Might be a vacuum leak. Take some carb and choke cleaner or starting fluid and mist the vacuum lines and see if the idle increases. Do not spray cap and rotor though Incase itís sparking.
Another odd one is start the truck when itís dark out side and open the hood see if any of the spark plug wires are arcing if so replace the cables.
I ain't stuck,I've stopped to grab another beer :flipoff2:
JDWeeler is offline   Reply With Quote Quick reply to this message
Old 07-17-2019, 08:30 AM   #5 (permalink)
Member # 870388
Thankyou kind sir
Old 07-17-2019, 08:40 AM   #6 (permalink)
Member # 870388
exhaust leak
New gaskets on egr tube to exhaust manifold connection and still leaks.
