Box Rocket 1980 build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2019, 11:54 AM   #1 (permalink)
Box Rocket's Avatar
Member # 6754
Been a while since I've been on Pirate but I'm back and looking for some info from the yota gurus. I'm in the process of building a 1980 pickup with my son and we're making some good progress.
Current state is later 22R with Weber carb. L trans.
V6 4Runner rear axle
Trussed 1983 front axle with disc brake upgrade.
3" TG front springs
Chevy 63' rears.
35's on FZJ80 wheels (for now)
I picked up a wrecked '96 Tacoma with a good drivetrain and we'll be doing a 3RZ swap hopefully this summer. Planning to use the 3RZ and the W59 with an adapter to dual gear drive tcases
But.....current dilemma is that the clutch on the L trans is toast and I don't want to throw any more money at that setup. Been searching for info and haven't found what I'm looking for, so, will the W59 mate up to the 22R? I know the W59 bellhousing can be used with a W56 trans. It would help keep the truck rolling for a bit if I can swap in the W59 behind the 22R until we're ready to swap the motor. Any insight?
Here's the truck. This is how we bought it.
Profile2 by Adam Tolman, on Flickr
This is how it sits currently
KSWU5176 by Adam Tolman, on Flickr
Here's the donor Taco
Untitled by Adam Tolman, on Flickr
Adam
1995 FJZ80 - 1980 Toyota Pickup
Box Rocket is offline   Reply With Quote Quick reply to this message
Old 07-15-2019, 12:54 PM   #2 (permalink)
Member # 3886
Assuming you are still 4 speed?
The W will bolt up with the early bell. However ykure meft with DS drop case and it's 4" longer, so DSs etc
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 07-15-2019, 01:11 PM   #3 (permalink)
Box Rocket's Avatar
Member # 6754
Yeah original trans is a L50 from what I can tell, so 4-speed. With that bell housing work with the w59? or would I need a w56 bell?
Using the taco t-case I know I'd have a driverside drop, but the plan would be to run an adapter between the trans/tcase to maintain the PS drop gear driven case.
Adam
Old 07-15-2019, 01:31 PM   #4 (permalink)
Member # 3886
AFAIK all 22R bells except turbo are the same.
hold this...
Old 07-15-2019, 01:40 PM   #5 (permalink)
Box Rocket's Avatar
Member # 6754
And if I'm not mistaken all W series trans will mate to any R series motor?
Adam
Old 07-15-2019, 01:42 PM   #6 (permalink)
Member # 3886
With the correct bell
hold this...
