Flat towing options - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-17-2019, 08:38 PM   #1 (permalink)
Member # 3607
Flat towing options
Need to flat tow a vehicle behind the RV for weekend and cross country trips. Looks like options for a 4x4 with a removable top are a Zuk (a bit too small with 2 big dogs)or Heep - but have a perfectly good 85 4Runner in the fleet. Done lots of searching and the general advice is pull the rear driveline - but no way the wife is gonna go for that. Nor is dragging around the car trailer.
1 - Looked at FROR full floater- but not able to figure out a park brake w/o $$ for the drotor kit.
2 - Looked at TrailTough rear disconnect- but how do they do at road speed (65+)?
3 - Marlin has a Tacobox (basically a dual case set up) that advertised a true neutral and tow capability- but when I called the story changed.
So without pulling the driveline or trailer what are the real world experience with any of the above 3?
NWOffroad.net
85 4Rnr - 35s/histeer/488s/ARB & Detroit/ 22re/
BlueCoyote3 is offline   Reply With Quote Quick reply to this message
Old 07-17-2019, 08:50 PM   #2 (permalink)
Member # 79509
Because undoing 4 bolts is hardcore.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 07-17-2019, 11:11 PM   #3 (permalink)
gregj50's Avatar
Member # 151818
gregj50 is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 04:13 AM   #4 (permalink)
Member # 213125
Shut the fuck up Greg! Pull the driveline bolts. It literally takes 2 minutes unless you are a window licking fag like Greg.
Aisin is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 06:30 AM   #5 (permalink)
Member # 3607
When itís 10pm and pouring rain, the wife is not gone reconnect the driveline. Age & injuries catch up to all of us - looking at the above 3 options to avoid going to a Heep.
NWOffroad.net
Old 07-18-2019, 07:09 AM   #6 (permalink)
gregj50's Avatar
Member # 151818
Why not a Heep?? If thatís the easiest option why limit yourself??
Old 07-18-2019, 07:29 AM   #7 (permalink)
Member # 3886
This comment does not make sense. Regardless of what/how you tow, there is going to be rigging and unrigging to do.
If you seriously would have your wife working on your rig, you need said rig confiscated.
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 07:42 AM   #8 (permalink)
arickvan's Avatar
Member # 188882
get out of the toyoter section ya jeep feg!!
arickvan is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 08:04 AM   #9 (permalink)
Sand Pounder
Willis_racing's Avatar
Member # 850944
Full floater sounds like a good bet for what you want to do. Sounds like you have the funds for it. Is the e-brake super necessary for you? I thought that's what 1st gear was for
'93 Pickup Crawler "Rosie"
'99 Honda VFR800
'83 Honda VF750
'08 Yamaha YZ450 desert boi
'85 Honda ATC350x
'90 D150 Tow Rig (yeah its a bit scary)
Willis_racing is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 08:59 AM   #10 (permalink)
Member # 140628
I've talked to a couple people that use the trail tough disconnect to flat tow their rigs. No problems. I have one on my truck although I've never flat towed with it. It's a solid unit.
hodgiemoto is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 10:03 AM   #11 (permalink)
Member # 79509
Wife does all your wrenching?
A call to FROR is somehow more expensive than buying a Jeep?
Spend the grand and call it a day.
Old 07-18-2019, 10:30 AM   #12 (permalink)
Member # 213125
If you carry a bunch of stuff in the back of the 4runner donít go full float. Semi float Toyota housings are not meant to support the weight of the vehicle. There is a reason factory Toyota full float housings are thicker than the semi float housings.
Old 07-18-2019, 11:02 AM   #13 (permalink)
gladman's Avatar
Member # 152210
we need pic of wife.
"Be polite to everyone you meet, but always have a plan to kill them"
-Bubba Ray Boudreaux
gladman is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 12:06 PM   #14 (permalink)
Cruiser Driver
JB Cruiser's Avatar
Member # 190268
Talking
Flat tow my '85 4runner around all the time. I leave the T/C in 2H and the 5 Speed in neutral. The T/C get oiled because the output shaft is spinning. The front drive is not engaged, if you put the T/C in Neutral, you lock the front & rear drive together, which is what you don't want. When I stop to refuel the motorhome (about 300 miles) I get into the 4runner and put the T/C in neutral and run the transmission thru the gears to keep the trans lubed for another 300 miles! I do not take the drive shaft off. According to Marlin, he said towing is hard on the u-joints, that's why he advises the removal of the drive shaft.
Just My .02$
JB
JB Cruiser is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 12:43 PM   #15 (permalink)
Member # 3007
Just My .02$
JB
This. FWIW on my 2WD Tacoma I tow dolly'd it over 500 miles without any issues. Trans in N and that was it.
Bones is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 10:08 AM   #16 (permalink)
Member # 140628
Maybe we don't. Maybe she won't fit under the truck
Old 07-19-2019, 10:53 AM   #17 (permalink)
Sand Pounder
Member # 850944
I have no idea how that would work. the placement of moment on the axle may be moved outward a few inches but that wouldn't really add a ridiculous amount of force to the housing. The housing still supports the weight of the truck no matter what the bearing setup is.
It's the tcase that risks getting burnt up, not the trans, so you're safe, but he's a different story.
'99 Honda VFR800
'83 Honda VF750
'85 Honda ATC350x
Old 07-19-2019, 11:04 AM   #18 (permalink)
Member # 213125
The semi float housing supports some of the weight as do the cup bearings. Asking the paper thin semi float housing to support 100% of the weight is asking for trouble.
Old 07-19-2019, 11:38 AM   #19 (permalink)
Member # 228875
I don't see the difference either, 100% of the semi-float axle weight is supported by the flange on the end of the axle housing. The 3rd member will only carry a downward load transferred through the wheel bearing acting as a cantilever pivot. A full-float loads the axle in basically the same spot, the inner end of the spindle. FF housings are thicker because they are designed as 3/4 or 1 Ton axles instead of 1/2 Ton.
What are you calling "cup" bearings ( I guess the axle bearing in the backing plate ) ?
stephen wilson is online now   Reply With Quote Quick reply to this message
Old 07-19-2019, 01:43 PM   #20 (permalink)
coyote's Avatar
Member # 170
If he has a problem with any of it just get a simple dolly....but shoot my dads 85 and flat tows his 1980 toyota to Florida every year just putting it in neutral..over 20 years, no transmission issues or case issues...only issue to date is one rear shoe that still isn't fixed...
Red Racer I
Toyota Prerunner
coyote is offline   Reply With Quote Quick reply to this message
Old 07-22-2019, 06:06 AM   #21 (permalink)
Member # 13460
If ebrake is the hold up with the FROR kit why not put a line locking valve switch in the brake line for an ebrake. Done it on my buggies. Basically you simply pump the brake, while holding the brake pedal down you turn the valve, this locks the pressure on the caliper and works great. A $17 valve would solve that problem.
coilcj is offline   Reply With Quote Quick reply to this message
Old 07-22-2019, 06:36 AM   #22 (permalink)
Member # 69633
Location: I live in my body: On the land near Paradise Township, Jefferson State, not by choice.
Locking hubs on rear axle.
No crawling under, no unbolting of driveline.
https://forum.ih8mud.com/threads/loc...wheels.277846/
This space for rent, cheap!
ParadiseAutoElectric is offline   Reply With Quote Quick reply to this message
