Will it Bolt Up? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2019, 08:53 AM   #1 (permalink)
Member # 688202
Will it Bolt Up?
Will a A340F passenger side drop from a 3.4L bolt up to my 1981 22R? I've read so much about all the different trans and combos I'm not sure any more.
73-bronco is online now   Reply With Quote Quick reply to this message
Old 09-10-2019, 09:20 AM   #2 (permalink)
Member # 71136
No. The v6 and the 4cyl have different bellhousing bolt patterns
80toy2brc is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 09:51 AM   #3 (permalink)
Crisbee1's Avatar
Member # 133544
I was able to bolt a 2rz with a a34d 4 speed no puter auto to stacked mini truck tcases with an Inchworm prerunner adapter. The adapter has a 2 bolt patterns, one for a vertical tcase using the stock mounts, Toyota blew it here imo, tcases would get hung up on rocks. 10* clocking pattern gets the t cases up and a rear tcase mount ditching the low mounts can get you very close to a flat belly.
Crisbee1 is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 12:08 PM   #4 (permalink)
Member # 688202
So if I get a bell housing from a 22R or 22RE auto OR manual it will bolt up then?
Old 09-11-2019, 08:04 AM   #5 (permalink)
Boomtacoma01's Avatar
Member # 139434
yep.
Here is a little reading for you
https://www.pirate4x4.com/forum/toyo...sues-faqs.html
1985 Xtra Cab - 22RE, 39" Red Labels, D60, 14B, 3 Link/4-Link, A340F, Atlas II 4.3, Lone Star Light....
2017 Ram 2500 Crew Cab 4x4, 6.7 tow rig
IG: @boomtacoma01
-Chris
Boomtacoma01 is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 10:00 AM   #6 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
22R or 22RE bell housing from a A340.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 11:47 AM   #7 (permalink)
Member # 213125
What did that transmission come out of?
Aisin is offline   Reply With Quote Quick reply to this message
Old 09-12-2019, 11:07 AM   #8 (permalink)
Crisbee1's Avatar
Member # 133544
97 2 wheel drive pickup. no puter, 4 speed OD with a down shift cable on the throttle body.
Old 09-12-2019, 07:55 PM   #9 (permalink)
Member # 213125
Thanks. It sucks that inchworm is gone.
Old 09-13-2019, 02:38 PM   #10 (permalink)
Shift to the Best
Member # 68266
Pretty sure that the 2RZ Prerunner auto is the only setup the A34D was offered. So best to find what trans it is, ID plate on passenger side should have info.
Old 09-13-2019, 03:53 PM   #11 (permalink)
Member # 213125
Any options for adapter plates now that inchworm is gone?
Old 09-13-2019, 07:13 PM   #12 (permalink)
Crisbee1's Avatar
Member # 133544
The Inchworm pre runner housing replaces the tail housing on the a34d.
the a34d is 21 spline, so at the time this required a 21 spline input into the t case.
Anything stronger than a stock 3rz can kill the coupler quick imo,
Then the Trail Mart thing made the couplers unobtainable, never could get a straight story as to why the 21 spline coupler was not made anymore.
This was all 2007ish, That rig went to Nevada last year.
These days if I need mini truck axle parts I use cruiser outfitters and trail tough for sami junk.
Old 09-14-2019, 07:11 AM   #13 (permalink)
Member # 213125
Stuck between a rock and a hard place. I want a gear drive t case behind an auto but I doubt itís gonna happen. It looks like Iíll be using a T100 auto/t case combo.
Old 09-16-2019, 03:06 PM   #14 (permalink)
Shift to the Best
Member # 68266
You can run a gear drive case behind a T100 auto, but I think the chain drive cases are strong enough for 90% of people.
Old 09-16-2019, 04:07 PM   #15 (permalink)
Member # 213125
How do you get a gear drive case behind the T100 auto? Reason being I already have a gear drive case. I sold the truck I was going to build. It was a 4 cylinder. I bought a G54 and matching t case to use in my swap. I now have a V6 auto to build.
Old 09-16-2019, 05:56 PM   #16 (permalink)
Member # 777769
Use a gm transmission?
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 07:18 PM   #17 (permalink)
Member # 213125
Absolutely not
Old 09-16-2019, 07:31 PM   #18 (permalink)
Member # 777769
Absolutely not
Is that just a teq is life thing or gearing/strength reason? It seams people are completely against it or donít care. No middle ground.
I have a 4l60e and it works great. Ive never used a Toyota auto, do I not know what Iím missing?
https://
My dog will eat you
Old 09-16-2019, 08:09 PM   #19 (permalink)
Member # 213125
Not many options for a 3.0 V6. The only way I will use a GM transmission is if thereís a mullet motor in front of it. What are you running for engine?
Old 09-16-2019, 08:21 PM   #20 (permalink)
Member # 777769
My build is from early 2000s. Itís 4.3 vortec, 4l60e, dual gear drive cases 2.8/4.7 4:88s and ARBs in toy axles and 37s. Alcan leafs that I loved, broke a main leaf a week ago and thinking about replacing with atlas. My set up works great, so I donít really want to change it.
I am watching the builds with the new ecotec you can really make some power with these modern engines. Gm is all modular, the bell house is the same. AA makes an adapter or atlas bolts to it.
I like gm drivetrain with toy body. If I could afford it, 609s.
https://
My dog will eat you
Old 09-17-2019, 09:29 AM   #21 (permalink)
Member # 102813
Whatís wrong with using a AW4? Bolts right up to a D300 or Atlas.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 11:48 AM   #22 (permalink)
Member # 213125
Iím trying to use parts I already have.
Old 09-18-2019, 09:00 AM   #23 (permalink)
Shift to the Best
Member # 68266
I run an original passenger drop 4cyl A340F and used the V6 adapter to replace the chain drive case when I did my dual cases.
Old 09-18-2019, 10:38 AM   #24 (permalink)
Member # 213125
Cool. Iím trying to avoid using adapters. Looks like T100 trans and transfer case it is.
