Who can remove 90's toyota rear wheel bearings near Nashville, TN? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-19-2019, 10:32 AM   #26 (permalink)
Member # 124269
Pretty saturday morning, grind, chisel, pb blaster, slam....bearings come right off.
Thanks guys.
Flipper1938 is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 07:41 PM   #27 (permalink)
TNToy's Avatar
Member # 5776
Originally Posted by SLOWPOKE693 View Post
Slice the lock rings with a die grinder, smack slice with blunt chisel, ring will crack and slide off easily. Bearings will basically fall off with a few more taps on the block of wood. I've done dozens of rust belt Yotas using that method.
This. Grind ‘em thin with an angle grinder on opposite sides. Split with a cold chisel.
Bearings now drive out with a few much gentler blows of the shaft end on concrete. Leave all the drum brake components on the end, shoes and all. You want the weight.
