Pull a leaf or two from TG pack or go RUF? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-03-2020, 11:28 AM   #1 (permalink)
Member # 199288
I've got the 4" front TG springs from about 8-9 years ago and it still just sits so damn high. I have an 84 4runner. The rear is on 5" to help compensate for the top/canopy of the 4runner. I'd honestly like to get it down to 35s or even 33s as it has to sit on 37s right now or it looks goofy as hell.
I've read the RUF thread on the spring lengths. It seems I could get an 84-88/89 rear spring pack and it should just about fit where my TG fronts are with the fact that it should move the axle forward about 2" from the TG setup, which may be a good thing.
What do you guys think? Are the RUF spring packs different from 2wd to 4wd and also from 4runner to pickups?
live4soccer7 is offline   Reply With Quote Quick reply to this message
Old 02-03-2020, 11:56 AM   #2 (permalink)
Member # 140628
I would start by taking out the bottom leaf of the TG pack. I've done that to almost every pack I've done.
hodgiemoto is online now   Reply With Quote Quick reply to this message
Old 02-03-2020, 12:20 PM   #3 (permalink)
Member # 199288
Thanks! I'll give that a shot. I know from reading around that there are particular leafs (leaves?) that serve specific purposes. I believe the front pack I have is 6 leaves and the rear may be 7.
Old 02-03-2020, 05:11 PM   #4 (permalink)
Member # 45798
You can definitely start pulling leaves to get those packs lower and softer. The main leaf needs to stay, as does the military wrap second leaf, but after that you can mix and match as much as you want.
yotota is offline   Reply With Quote Quick reply to this message
Old 02-03-2020, 06:11 PM   #5 (permalink)
Member # 199288
Thank you for the reply. I have about 4.5-5" between the pumpkin and the oil pan (1UZ swapped). I feel like I could easily drop 2.5" safely. In an attempt to perhaps save some time and not have to drop and disassemble everything multiple times, would you have any recommendations on the amount of leaves out of one these TG packs to pull to get me in the ballpark?
Old 02-04-2020, 11:56 AM   #6 (permalink)
Member # 140628
As stated I would start by pulling the bottom leaf out. With the weight of the 1uz that would be a good start. Setup up your bump stops to keep the axle out of the oil pan.
Old 02-04-2020, 12:04 PM   #7 (permalink)
Member # 199288
Thanks. I'll do that. When I get around to it, I'll come back and post up results so that others can go off of it. The 1UZ only weighs about 50 lbs or so more than the 22r.
Old 02-04-2020, 04:08 PM   #8 (permalink)
clb 017's Avatar
Member # 166307
The trailmart leaves on my taco are awful soft, dickhead p.o. Wanted to lower it so he pulled out 2-3??? (I fergot) of the leaves no bump stops, essed the remaining leaves!
Even with a fresh pack on all 4 corners they sag like a broham in the hood...
MY .02....Buy\build non chinamart springs!
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 02-04-2020, 04:15 PM   #9 (permalink)
Member # 199288
I think I'll probably pull 1-2 from the front/rear packs to get it where I want it and in the meantime look for some RUFs. This will at least get me in the ball park of where I'd like to be and see what kind of issues I'll run in to with clearance etc... I agree with you though. Wish I didn't have these damn springs under the truck. I didn't know any better 8-10 yrs ago.
Old 02-04-2020, 07:22 PM   #10 (permalink)
94toytruck's Avatar
Member # 18614
I removed leaves and replaced with flatter thin leaves and ran a shorter shackle. I had 3" springs and they were stupid stiff till I messed with them.
Eric
[B]
[/B] [B]
[/B] [B]
[/B] [B]
[/B] [B]
[/B]
[QUOTE=FLEXYSAMMY;13977957]Yes you are correct Eric.[/QUOTE]
94toytruck is offline   Reply With Quote Quick reply to this message
Old 02-05-2020, 08:40 PM   #11 (permalink)
Member # 96614
Send a message via Yahoo to redpim1
I have been running Old Man Emu CS010R rears on the front of my ‘85 with great results. Replaced my old RUF setup with them. They flex great and complement my 57” F150 rear springs well.
[QUOTE=cannoncrawler;13997361]A Clapped out 6k toy just showed them all![/QUOTE]
____________________________________________
||____________||____________||__TOYOTA ___||
||____________||____________||_____________||
redpim1 is offline   Reply With Quote Quick reply to this message
Old 02-05-2020, 10:14 PM   #12 (permalink)
clb 017's Avatar
Member # 166307
Yea once upon a time IN AMERICA...
Phawk photofukkit.
Old 02-06-2020, 09:15 AM   #13 (permalink)
YotaAtieToo's Avatar
Member # 25632
Huh, I thought it was 2020 not 2002.
Flat leaves suck. RUF suck, they bend 1st or 2nd trip out.
I can see pulling 1 leaf, any more than that and I'd look at lowering(raising) the mounts.
Old 02-06-2020, 05:22 PM   #14 (permalink)
Member # 874116
Trying to doo the same with OEM CS009R but those springs seems much shorter than my old RUF ... shackel angel is bad .
Did you install a front spring hanger or used the stock one ?
Fred La Bęte is offline   Reply With Quote Quick reply to this message
Old 02-07-2020, 11:44 AM   #15 (permalink)
Member # 96614
The CS009R springs are shorter than the CS010R springs. I am on a stock hanger with banana shackles.
Old 02-07-2020, 11:49 AM   #16 (permalink)
Member # 96614
Better setup than trailmart springs. Wheels great and still has some road manners.
Old 02-07-2020, 12:21 PM   #17 (permalink)
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
i replaced the two middle leafs in my TG pack with Toyota rears, definitely brought the truck down a bit but it's still not what i would consider low
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 02-07-2020, 04:03 PM   #18 (permalink)
Member # 874116
Thanks ! I know what is my problel now ... ( front gangner )
Old 02-09-2020, 07:01 AM   #19 (permalink)
Member # 98165
I've have RUF on my 88 with a D60 and 39 reds. I'm getting alot of axle wrap with this setup. Two guys we wheel with are running the same setup but both have 5" TG which aren't wrapping as much. Probably gonna try an after spring untill we do an auto ecobox D300 and 4 link swap.
FJ40Nightcrawler is offline   Reply With Quote Quick reply to this message
