Some Horn Tech *Attn: Newbies* - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-09-2005, 06:10 PM   #1 (permalink)
Member # 1301
Figured out why the horn wasn't working. The pic below is a severely worn out horn contact pin. Next to the short worn-out pin is a newer pin that illustrates how long it should be. If your horn isn't working, or only works at certin points in the wheel rotation this will probably be the culprit.
You have to pull the column plastic housing and the steering wheel. Then for ease of installation I would reccommend that you pull the four bolts that hold the wiper and turn signal assembly and then disconnect the wiring harness at the column and pull the whole assembly off the column to work on it. The reason is because there is a REALLY small "e" clip on the brass pin that you have to remove. I managed to only lose 1 during the swap. Be careful when removing or installing the clip cause the dang thing likes to fly. There is also a small clip with a wire attached that goes on the end of the brass pin (horn wire) Piece of cake. A new pin from toyota complete with spring and "e" clip runs about $5.00 at the local stealership.
1985 Toyota 4x4
Part #84312-20011
Your SUV hates its life as a minivan!
Wheelie_Pete is offline   Reply With Quote Quick reply to this message
Old 01-10-2005, 08:15 AM   #2 (permalink)
Banned
Member # 3933
Thanks for posting this info!
4RnrRick is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 09:53 AM   #3 (permalink)
RcBro's Avatar
Member # 78101
Thank you. I was always curious why more horn only worked at full tilt. I think this is why. I'll take a look soon. Thanks
RcBro is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 10:19 AM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Good to know, should go in the FAQ sticky. You can post it up there!!!!
Old 08-21-2006, 10:21 AM   #5 (permalink)
Member # 38170
Already there old man, post 83
EvlDodge is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 01:00 PM   #6 (permalink)
Member # 41789
I had the same problem. To fix it I put a dab of solder on the top of the pin to make it contact. Didnt cost a dime.
alk1174 is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 01:50 PM   #7 (permalink)
JWS
Member # 23023
This is on the *to do* list. haha. I ended up putting spacers (washers) underneath the contact ring to bring it closer to my worn out contact pin. Been working for over a year now.
JWS is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 04:07 PM   #8 (permalink)
FrankenToy's Avatar
Member # 36822
I knew I saw it there already (that's how I knew what to replace).
Dr Floyd: Don't suppose you have any idea what the damn thing is, huh?
FrankenToy is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 07:30 PM   #9 (permalink)
Member # 463
My wheel has been half torn apart for weeks, I figured it was that but the pic is a good illustration....cause mine looks like the one on the left
how much were they?
Nick
A bunch of Toyotas...who wants to know
Torchmate Racing
ToyFamily is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 07:30 PM   #10 (permalink)
Member # 77667
forget the stock horn. i got tired of mine and installed a train horn from hornblasters.com. it rocks. comes with a compressor and a tank. also it is a lot of fun honking at people, especially when they cut me off or they are passing me because my truck is so slow.
Ffootball607 is offline   Reply With Quote Quick reply to this message
Old 08-21-2006, 07:56 PM   #11 (permalink)
Member # 5333
Send a message via Yahoo to 5spd
You can snag them off junkyard Toyotas also. I got 6 for 50 cents so I have extras.
5spd is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 11:11 AM   #12 (permalink)
Member # 158670
Yes I know this is an old thread, but I found it while following the newb rules by reading the FAQ.
Anyway you can also fix the worn out contact pin without much effort by slipping a spent 22LR casing over it. The thickness of the primer end of the casing extends the pin enough to make it contact the ring on the steering wheel. 5 min fix tops.
mtmartin2005 is offline   Reply With Quote Quick reply to this message
Old 10-30-2014, 07:28 PM   #13 (permalink)
toyotastew's Avatar
Member # 475329
22 cal shell casing
another way too fix this is to use a .22 cal shell casing. it will fit right over the lil brass piece but you might have to squeeze it closed a lil bit on the end to keep it in place. i have fixed 3 of my trucks this way and never had to mess with it again.
toyotastew is offline   Reply With Quote Quick reply to this message
Old 10-30-2014, 07:31 PM   #14 (permalink)
toyotastew's Avatar
Member # 475329
just noticed this
