Please post pics and dimensions of homemade front spring hangers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2004, 12:59 PM   #1 (permalink)
Krylon..'s Avatar
Member # 2042
SAS hanger pics and dimensions..... Ultimate SAS thread...
Ok, I was browsing through the FAQ and noticed there is only one link for the SAS hangers and writing about wanting a thread with alot of pics.. So lets start make one. Also there is mention of an Ultimate SAS thread.
I will be fabbing my own soon and have been wanting to post asking for what measurements you guys had used to make your own. SO why dont we kill two birds with one stone and make a good post with pics that can be added to the FAQ?
I know stock spring perch width is 29". But did you make your front spring eye hole in line with you stock front crossmember, or farther forward and why? I have seen some people use 2x2, 2x3, 2x4, 1x2, etc for the main crossmember. What did you use and why?
So lets see'em!
I'll start by adding the FAQ link and pics/info from that thread:
https://www.pirate4x4.com/forum/showt...threadid=76595
ErikB:
Erik has a great write up on a complete SAS swap including axle info and narrowing info on his site.
http://home.4x4wire.com/erik/4runner/sas/
From Erik's site:
"The dropped front spring hanger crossmember is made of 2 x 2 x .25" square tubing (probably overkill, but it was free). The hangers themselves were cut from 3.5 x 3.5 x .25" square tubing. I also built a receiver hitch into the center since my tow hook was removed to mount the crossmember..
The hangers are 27.5" on center to match the perches on the narrowed axle. Stock straight axle Toyota hangers and perches are 29" on center.
The hangers have a 2" drop built into them (4" from the bottom of the frame) compared to a stock straight axle Toyota, but the distance from the front of the frame is the same, about 2". I also drilled a second set of holes 1" forward of those for more mount options."
2Stroke:
If you want me to add details to anyone I have listed, post up or PM me and I will add info under your name. And if you wan tme to remove your stuff, I am sorry and would be happy to.
Mike
Krylon.. is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 01:45 PM   #2 (permalink)
HomeGrown's Avatar
Member # 23015
here are pics of mine "HomeGrown Style" the frame was bent in the front. So i cut it out. plated both sides of the frame and the top and bottom, drivers side and passanger side. added the front crossmember and then built some hangers for the leaf springs. this tied everything togther perfect. i ended up moving the front hanger hole 1.5" forward and 1.0" down.
It's HomeGrown Bitch
HomeGrown is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 01:53 PM   #3 (permalink)
Member # 23011
Here are mine in earliy stages:
1" drop
1/4" plated with another piece of 1/4" around the eye and lower portions.
I used 2x2x1/4" square tube to connect them about 1" forward of stock.
vikingsven is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 01:54 PM   #4 (permalink)
Member # 23011
2
Old 10-15-2004, 02:21 PM   #5 (permalink)
Member # 2133
Send a message via ICQ to 85TrailToy Send a message via AIM to 85TrailToy
I had 2 hangers made, this one and mine, which is still in the garage.
2x3x1/4wall, 2" drop, 1" forward. Hanger plates are 3/8". Gussets between and inside plates. Also have gussets for the back of the tube to the frame.
85 4Runner 4.88's 4.7's Lockers 35's Drivetrain/Gas tank lifted Dents all over
[b]9-11-01: REMEMBER DAMMIT![/b]
"Who's the fella owns this saloon?"
[QUOTE=4RnrRick]Whay would woul have poer to teh wheels if I'm in neutal![/QUOTE]
85TrailToy is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 02:53 PM   #6 (permalink)
Member # 21180
KC_JoNeS is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 03:18 PM   #7 (permalink)
Banned
Member # 3933
Here what we did on Project Blu: https://www.pirate4x4.com/forum/showthread.php?t=220649
4RnrRick is offline   Reply With Quote Quick reply to this message
Old 10-15-2004, 06:54 PM   #8 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
I made this drawing for a friend that wanted to make a similar hangar to what I made for my truck.
And here is the original on my truck
I want to go farther forward now, so I'm cutting it off and making a new one with the bolt 1 1/2" forward.
Here's another. This is on Formula Toy #020. I might clearance mine like this one as well.
Drive it like Tim!
Im4yotas is offline   Reply With Quote Quick reply to this message
Old 10-16-2004, 02:39 PM   #9 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
here is the one I built main piece is 2x3x3/16 tube and the rest is 3" x 1/4" flat bar. It is drilled for 1" forward and 2" drop (estimate)
Every day is better than the next.
Benny is online now   Reply With Quote Quick reply to this message
Old 10-16-2004, 05:42 PM   #10 (permalink)
Member # 20957
Send a message via Yahoo to Hyena
I made mine out of 2x6x.250. I used a chevy spring hanger for the front hanger. The spring bolt sits about the same spot but about 2 inches down. It wasn't an sas just a drop hanger. I can't post pictures though.
Old truck
Jimmy's 4X4
Hyena is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 11:17 AM   #11 (permalink)
300sniper's Avatar
Member # 26382
here is a drawing of my sas hanger for a full size chevy d44 swap. the x-member is made out of 2x4x.120 tube. the spring hangers are cut from 3-1/2x 3-1/2x .250 box tube with the hole drilled 2" down from the top.
It's time to switch to whiskey, we've been drinkin' beer all night.
300sniper is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 11:21 AM   #12 (permalink)
300sniper's Avatar
Member # 26382
side view of x-member/ hanger
Old 10-17-2004, 11:23 AM   #13 (permalink)
300sniper's Avatar
Member # 26382
front view
Old 10-17-2004, 12:16 PM   #14 (permalink)
914Runner's Avatar
Member # 23992
Is that Sky's Pitman arm?
1991 Toyota 4Runner, 1997 Toyota 4Runner, 2000 Toyota 4Runner
914Runner is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 12:20 PM   #15 (permalink)
300sniper's Avatar
Member # 26382
it is and i highly recomend tightening the nut before your first trip out of the shop (think i found the reason for my death woble )
Old 10-17-2004, 12:33 PM   #16 (permalink)
300sniper's Avatar
Member # 26382
i found the other drawing for my crossmember/ hanger.
<front---rear>
Old 10-17-2004, 05:59 PM   #17 (permalink)
LCOwner's Avatar
Member # 181
Question for all you full-width guys that have moved the the springs apart to fit the axle. What do your shackles look like?
LCOwner is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 09:55 PM   #18 (permalink)
300sniper's Avatar
Member # 26382
this is a crude drawing of how i did mine.
Old 10-17-2004, 09:57 PM   #19 (permalink)
300sniper's Avatar
Member # 26382
live in person
Old 10-17-2004, 10:05 PM   #20 (permalink)
AlaskaToy's Avatar
Member # 2982
Shackles are hung from allpro tubes originally placed for a regualr AP SAS job. They move the springpack outboard exactly 1.25".
Here's the hanger; all pro hanger cut in the center and spread 2.5", mounted to a 2x2 1/4" wall square tube sub frame protruding 3" beyond the factory crossmember.
AJ
93 ExCab on 1-tons
AlaskaToy is offline   Reply With Quote Quick reply to this message
Old 10-18-2004, 06:15 PM   #21 (permalink)
Member # 34945
So is 2 7/8" a good inside diameter for the hangers themselves when running toy rears? I see that some of the hangers are 3" ID. I guess what I'm asking is is the inside diameter super critical? I didn't mean to ask anything that has been covered; I'm just trying to figure out how I'm gonna make mine. Thanks
NathanBuchanan is offline   Reply With Quote Quick reply to this message
Old 10-18-2004, 07:28 PM   #22 (permalink)
AlaskaToy's Avatar
Member # 2982
toy springs are narowwer than the american 2.5" springs so the 2 7/8" hanger is optimal for them, but you couldn't use wider 2.5" springs. If you make the hanger 3" wide you can use eith 2.36" toy springs or 2.5" leafs; you'll just have to shim the busshings with a couple fender washers if you run toy springs.
AJ
93 ExCab on 1-tons
Old 10-18-2004, 08:54 PM   #23 (permalink)
Member # 34945
thanks man
Old 10-19-2004, 06:39 AM   #24 (permalink)
Kajo4x4toy's Avatar
Member # 2537
Here is mine. I guess the measurements are about the same as everyone elses. the tube is 2" X 1/4" wall square and the hangers are 3/8" X 3" flat stock. The front crossmember and hanger are covered with 1/4" plate to support the winch witch has the rear mounting bolts going through the crossmember
Kajo
SFC, US Army (Retired)
Cancer Survivor since 01/2002
Kajo4x4toy is offline   Reply With Quote Quick reply to this message
Old 10-19-2004, 07:27 AM   #25 (permalink)
Member # 28992
Ok, so it seems like we have the crossmember/spring mounts covered, any other aspects of the swap that you could post would be helpful.
Choices of axle, frame prep after cutting off the ifs, shackles thru the frame or under? and why, shock hoops or ford towers, anything else you can think of would help this become a true knowledge base. Thanks
4x4RunnerSD is offline   Reply With Quote Quick reply to this message
