Wiring a GM Altenator - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-15-2002, 11:14 AM   #1 (permalink)
SPR
Member # 2932
I've dropped in a Buick 3.8 into my 85 PU. Can someone tell me which factory Toyota wire to hook up the a GM alternator? The Toyota alternator wiring harness has a red, black, yellow, and two white wires. One white wire is larger than the other and bolts onto small post located on the driver's fender.
TIA.
It's still a Toyota... but just barely
SPR is offline   Reply With Quote Quick reply to this message
Old 04-15-2002, 12:04 PM   #2 (permalink)
Member # 3493
The alternator is very simple to wire. Do a search in the Toy and General 4x4 sections. There is a very good write up on it but I don't have the link anymore. I used those instructions when I did my swap.
Bigguy is offline   Reply With Quote Quick reply to this message
Old 04-15-2002, 12:35 PM   #3 (permalink)
Member # 4842
The magical SEARCH button has found these
https://www.pirate4x4.com/forum/showt...tor+AND+wiring
'80's Toy P/U-Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH350 L/U w/700R4 1st gear, dual tanks, dual batts, ...
84 4Runner SR5-ARBed 5.29's F&R, 4.7 t-case, AP x-over, Chevy's, 2" drv trn lift, 36" TSLs, 30 spl Longs
fourwd1 is offline   Reply With Quote Quick reply to this message
Old 04-16-2002, 12:53 PM   #4 (permalink)
SPR
Member # 2932
BTT,
I search the net for wiring the GM alternator to the 85 Toy. There is a lot of variation and some conflicting information.
My GM Alternator has the large bat. post, a two small male posts. A plug with two female connectors attaches to the two small male posts. Out of the clip runs a red jumper wire routed to the large bat. post and a brown wire which is attached to nothing.
Can someone with experience please tell me were to route the following Toyota from the original Toyota alternator wires:
16 gauge white wire - ??
16 gauge yellow wire Charge indicator
18 gauge red wire Hot when engine is running
I figure the 10 gauge white wire connects to the battery lead, and the 16 gauge black wire connects to the housing of the alternator - however it seem like the alternator should be sufficiently grounded through the mounting bracket.
TIA,
SPR
