Cheap twin stick for single case forward shift. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-15-2006, 04:57 PM   #1 (permalink)
2manyprojects's Avatar
Member # 39901
Cheap twin stick for single gear tcase forward shift only.
Made a twin stick for "free" out of the spare parts I had. Would only work for a single gear case with forward shift. Steal a top shift fork/rail from friend who did duals. Pull the interlock pin and run one forward shift for high/low and top shift for 2/4wd.
Some key stock still needs to be welded to the forward shift rail to keep the shifter engaged.
The rails would be switched if your getting leftovers from a friend who went duals.
"]my 90 project [/URL]
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Because there is no 2nd chances on Pirate!
2manyprojects is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 12:50 AM   #2 (permalink)
Big_Ern's Avatar
Member # 25661
thats a cool idea
4ws buggy on 404 mog diffs
'80 Toy - Longs, duals w/ D300, welded F&R w/ hydro assist, beadlocked & grooved 36" SX's
Big_Ern is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 04:44 AM   #3 (permalink)
Member # 3161
sounds cool,, but I need more pictures and information..
thanks
I would like to do that when I do the marlin gears, on the wifes truck.
missouriman is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 05:31 AM   #4 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
That's my kind of tech right there!!!
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 07:18 AM   #5 (permalink)
Member # 39901
Replacing the 4wd shift fork requires removing the case from truck. Remove the 4wd shift detent spring and ball and 4wd shift light switch. remove the output flange, speedo sender and the back two covers. Drive the roll pin out of the 4wd shift fork. Slide fork forward out the front of the case. In the hole where the detent spring and ball were, is a interlock pin. Use a magnet or tip case on it's siide to remove. Put top shif rail in and roll pins. Reassemble and install in truck. Cut new top shift shifter hole in floor and install both shifters. Don't forget OIL!
Old 06-16-2006, 07:30 AM   #6 (permalink)
Banned
Member # 3933
Oh I understand now....
This is for making a Twin Stick step for ONLY Single T-cases that use a forward shift T-case/Tranny Combination.
So your tranny has the regular 5 speed tanny shifter
And your Low and High Range shifter (forward shift rail).
Then your T-case has the 2wd & 4wd shifter (Top shift rail).
NICE!
4RnrRick is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 07:44 AM   #7 (permalink)
Banned
Member # 3933
Here I made a picture for you using a modified picture from Marlins Site....
OR
Old 06-16-2006, 09:18 AM   #8 (permalink)
ROCKILLER's Avatar
Member # 3273
We should have a cool new tech tip of the month, starting with this one.
Other than the ttc thread, this is probably the best one I've seen in a while.
[QUOTE=Alfred W.;10665950]When a man has the scent of pussy in his nose...... The best advice in the world bounces off the block formerly know as his head. :grinpimp:[/QUOTE]
ROCKILLER is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 09:42 AM   #9 (permalink)
Member # 38563
thats clever
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 09:51 AM   #10 (permalink)
ghettotoyota's Avatar
Member # 49759
Send a message via AIM to ghettotoyota
Brilliant!
Daily/Wheeling rig: 04 wj,6.5 inch iro long arm,35's, locked d44a,4.7
ghettotoyota is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 10:33 AM   #11 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
Welldone!
85 Toy Xtracab
"I DON'T want to understand !!"
"Wow this is unbelievable"
steveh is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 10:57 AM   #12 (permalink)
Member # 1852
Send a message via AIM to dcg9381 Send a message via Yahoo to dcg9381
And some people say everything has been discussed!
Love it!
dcg9381 is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 11:02 AM   #13 (permalink)
Roksamy's Avatar
Member # 752
Good to see a new (to me ) idea!!!!
Cheers!!!
I'm on a boat
Roksamy is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 11:32 AM   #14 (permalink)
Member # 3132
thats a great idea. my buddy installed one on his carbed 84, it's bling though from marlin, you would only see it if his cab fell of though. which the way he smashes into rocks, thats a possibility.
Old 06-16-2006, 11:41 AM   #15 (permalink)
Member # 3132
actually wouldn't it be less work to swap out the 2wd 4wd shift fork? you would only have to pull the top cover,speedo, detent ball, the rear 2 case pieces, remove roll pin, slide sift rail forward, magnet out the interlockhold the shifter piece into the front case half from the top hole, install 2wd 4wd shift rail, and then reassymble. that way you would be saving the parts you need for converting forward shift t-cases into top shift front cases on non forward shift trucks. sell the low range rods and fork. alos tip, make some shifters that just move forward and back, and sell those 2 you have on there now for 30 bucks a pop.
Old 06-16-2006, 12:19 PM   #16 (permalink)
Member # 39901
Thought I said that in post 5? Pics of shift forks are kinda backwards in application. Whatever top shift fork/rod you can find would work.
The high low rod/fork would be easiest to change. Wouldn't have to dissasseble t-case.
Old 06-16-2006, 12:50 PM   #17 (permalink)
Banned
Member # 3933
Fixed the post above with the pictures for you, so now they show both options....
OR
Old 06-16-2006, 01:45 PM   #18 (permalink)
Member # 3132
I don't like you I know I didn't even read yours.I actually didn't read anything after the first post.
Old 06-16-2006, 02:00 PM   #19 (permalink)
Member # 39901
I don't like me either. I'm guilty of the same offense, way too often.
Old 06-16-2006, 04:27 PM   #20 (permalink)
Member # 13924
Nice work man!
quadrunner is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 04:37 PM   #21 (permalink)
94toytruck's Avatar
Member # 18614
Nice I think I got a new mod to do
Eric
94toytruck is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 05:12 PM   #22 (permalink)
Member # 3886
this is a cool idea.
but just to be devils advocate, whats the point of twinsticking any case without front drive only...
if you want 2WD low dont lock the hubs
on another side note
MARLIN, HURRY UP WITH THE REAR DISCO CASES!!!
hold this...
gnob is offline   Reply With Quote Quick reply to this message
Old 06-16-2006, 05:53 PM   #23 (permalink)
Member # 39901
if you want front dig, pull the rear driveline
After you have 2 low at the flip of a lever, you'll never want to get out again. And alot of times you can use 2 low to pivot the rear. Front dig in reverse.
Old 06-17-2006, 08:36 PM   #24 (permalink)
TNToy's Avatar
Member # 5776
Just to be devils advocate, whats the point of twinsticking any case without front drive only...
Like the man said, roll up until the corner of the front bumper is against a rock or tree, and blip the throttle to break the rear end loose and swing it around. Usually helps you avoid backing waaay up to do 3 point turns, especially when the way you want to drift the rearend happens to be downhill.
Old 06-23-2006, 08:04 AM   #25 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Nice!!
So, you've got duals....this for Joe?
MT4Runner is offline   Reply With Quote Quick reply to this message
