Cranky Moderator
Project "Stroker Smoker", My DOA Engine Build for my 85
Tim is building me a Motor. It was not an easy decision to go this route, it ain't cheap! I always figured I'd go 4.3
Deep down inside, I want my truck to stay 22re. I know I could do many other options for the same or less money, but it would not be what I really want. I like Tim's engines, and I have talked to enough people who have his engines and install his engines to know I am getting a great product. What I have asked Tim to build for me is almost turnkey. It will include the late model TB, Plenum, and intake. All are port matched and polished. Larger Fuel Injectors to compensate for the increased flow capability, IE, to avoid it leaning out. The Larger Injectors allow the use of the stock ECU ![]() What Tim is building me is an engine that will perform well in a heavy truck ~4700lbs, and last year after year. Tim worked on the head today. Here are some pics he sent me showing the work on the exhaust ports and the chamber. After the head is done, Tim will provide me the flow #'s I'll track the build in this thread. I will make some 1/4 mile passes rather than do the Dyno thing. It's just way more fun, and I still get valid data to compare the before and after to. Exhaust Port Before Porting: ![]() Exhaust Port After Porting: ![]() Chamber: ![]()
85 Toy Xtracab "I DON'T want to understand !!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Wow this is unbelievable" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Member # 82696
I'm really curious about the numbers that will come out of this engine.
I can certianly understand needing more fuel with the kind of porting Tim does, but figuing out exactly how much will be a bit of a task. Upping the injector size the exact amount I could see being a real juggling act. Have you thought about an aftermarket ECU? I know it wouldn't save any money, but it would take a lot of the guess work out of matching parts. And you could tune it to take full advantage of the changes.
It's call "Tourist Season", so why can't we shoot them? |
Sponsored Links |
Tim really does do beautiful port work...
What injectors are you going to run that will keep you sufficiently rich, but not impact the stock ECU? I'm curious why you chose that over adjusting the AFM a few clicks? The stock injectors are close to max, true enough.. I've just never experimented with running alternate injectors with the stock ECU. Hit me up for a turn-key megasquirt demo one of these days when I get some spare time.. I'd be curious to what you can do on a dyno vs the stock ECU on a modified naturally aspriated engine. Any other major mods on the motor other than port work? |
Cranky Moderator
I all honesty, I am not concerned with numbers, As long as it runs well, and pulls my truck up the hills into the mountains, I will be happy.
I will post what #'s I can for you guys. I will even dyno it it if someone foots the bill!!! My best estimate from my discussions with Tim are around 150 solid at the flywheel. With my Dual cases and driveline setup it will lose around 30%, so right around 105 give or take at the rear wheels. Again, it's just estimates, I'm not asking Tim to build a race motor, I have asked him to build me a drivable and reliable motor. Here is the formula I found for taking 1/4 mile data and getting a rough estimate of HP Trap speed in mph, squared, divided by ET in seconds, times car weight in pounds, divided by 1000, divided by 9.1
#7 (permalink) | |
Cranky Moderator
![]() It makes sense to me what Tim said, IE, the stock ECU in my year according to Tim is what he called a constant learning ECU. I know it takes inputs for temp and O2, and works with those. My old brain says the O2 sensor is what the ECU uses to adjust the Injectors with. So, If I increase the ability of an 4engine to breath, I need to also increase the ability of the ECU to feed fuel at high r's. As long as the ECU is satisfied by the O2 readings, it should be happy. Make no mistake, I will not compare a 1985 basic Narrow band system to a sophisticated Wideband system such as a Megasquirt. I would expect that a wideband system could certainly help pull every bit of potential from any engine provided the tuner knew what they were doing. I have already moved my O2 past the header collector, and re-fitted it with a heated ND sensor. So at least in my setup, it reads all 4.
85 Toy Xtracab "I DON'T want to understand !!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Wow this is unbelievable" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by steveh; 01-08-2007 at 06:21 PM. |
#8 (permalink) | |
Cranky Moderator
![]() I will school Tim on taking better Pictures!
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
I hate to be nosey.... but I gotta ask about the cost. I know he makes a very reputable engine and puts very good craftsmanship and knowledge into his work.
You don't have to say what the $ figures are, but for sure your gonna get every mile out of it. ![]()
I R A REVOLUTION LEADER! |
#10 (permalink) | |
This will be a cool documented build up for people to follow and know what kind of hp there getting. I like the fact that you stuck with the toy motor too. One question though. Why not step up to a 2rz or 3rz? You would still have solid reliable motor with more power and torque for less I would think.
Link to my 85 yota build: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Blue MT. SnowRunner; 01-08-2007 at 07:29 PM. |
#12 (permalink) | |
Cranky Moderator
I like the 22r/re engines. I don't have to deal with the Cali BAR Smog Referee. Did I already say I like the 22r/re engines? ![]()
#13 (permalink) | |
Cranky Moderator
[email protected] and cheap do not belong in the same sentence. ![]()
#14 (permalink) |
A man of classics thats respectible. My dad kept his flat head in his 51 ford for the same reason. On with the build!
Link to my 85 yota build: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#15 (permalink) |
Steve, It's no mystery that I like megasquirt, but it's quirks aren't for everyone and I haven't found the time to really provide a plug in solution for all the variations in Toyota ECU... I'm totally curious about what the limitations of the stock ECU are.. Most modern ECS that use a closed loop operation (02 feedback) would accept some form of injector size change.. I just have no idea what the limitations of that change are! My understanding of EFI says at warm up you're not in closed loop, so the cc/min on the injectors have to be close.. just let us know!
#16 (permalink) | |||
Member # 4677
gNARLS. Last edited by Gnarly4X; 01-09-2007 at 04:45 AM. |
#17 (permalink) | |
Member # 4677
gNARLS. |
#18 (permalink) | |
Member # 23744
True.... but you do get what you pay for. So far as your opinion on the 22r/e's, I like the series too. They are a well proven platform for reliability, simplicity and an overall good powerplant choice for what we drive. I understand the desire people have for wanting to swap a newer series motor in, I do. My opinion on that is why mess w/ something that has a good track record like the 22r/e? And is the power gain worth the significant increase in cost.... I bet it doesn't outweigh the cost of what Steveh is gonna get ![]()
#19 (permalink) | |
Member # 4677
Thanks. gNARLS. Last edited by Gnarly4X; 01-09-2007 at 05:04 AM. |
#20 (permalink) | |
Member # 4677
This is really what I'm looking to figure out. What is the cost vs performance gain for any given engine build, or swap? DOA is telling Steve that he can build a 22RE with 150HP at the flywheel. I am very confident I can have a turn-key 22RE built by a Toyota expert engine builder, AND installed and tuned, in my truck (1986 Xtracab, 5-speed) for $5,000, plus the cost of a header/exhaust (approx. $600). If I add the cost of extras, let's round it up to $6,000 (not including sales tax). This engine will produce about 135 HP at the flywheel on an engine dyno, GOBS of torque, will burn 87 octane, very driveable and reliable, and is bored and stroked to 2.6L, ported head, larger valves, and uses the stock ECU/FI. Any comments? gNARLS. Last edited by Gnarly4X; 01-09-2007 at 05:20 AM. |
#21 (permalink) |
Member # 1305
[QUOTE=Gnarly4X;6330499]DOA is telling Steve that he can build a 22RE with 150HP at the flywheel.
(DOA) 155HP @ sea level is the quote. (G)I am very confident I can have a turn-key 22RE built by a Toyota expert engine builder, AND installed and tuned, in my truck (1986 Xtracab, 5-speed) for $5,000, plus the cost of a header/exhaust (approx. $600). If I add the cost of extras, let's round it up to $6,000 (not including sales tax). This engine will produce about 135 HP at the flywheel on an engine dyno, GOBS of torque, will burn 87 octane, very driveable and reliable, and is bored and stroked to 2.6L, ported head, larger valves, and uses the stock ECU/FI. Any comments? gNARLS. (DOA) I'll take that bet / challenge. We can look at HP. per cube vs. public pricing vs. what is actually seen at the crank. Stock ecu struggles at 2.6 with stock injectors (you did write stock ECU-FI). We'll also do the "Gobbs of TQ" comparo, dollars vs. LB FT. I'll make 155, you'll see a best of 160, a best. Both engines will need to also pass cali. smog tests, afterall, these are "real" street engines....... Tell me how you want to do this, it's time to put up, or shut up. I think I'm gonna name steveh's motor "The stroker smoker". NOODLES, the head was flopped for the first pic, upside down for lighting on the ported pic, real pics either way, but for you my friend, I'll shoot steveh the pic of the ports shown prior. |
#22 (permalink) |
Member # 26382
when is the estimated complete date? mine should be motor should be in by this weekend. maybe we can meet up at a dyno shop and compare for shits and giggles.
link to my 2 year motor build
It's time to switch to whiskey, we've been drinkin' beer all night. |
#23 (permalink) | |
Member # 24389
[QUOTE=crash]Your not ignorant---your an idiot [/QUOTE] |
#24 (permalink) | |
Member # 1305
Also, I went to toyota today, asked them why there were'nt any dyno sheets on the vehicles that were on the lot.....salesman looked at me qwizickly and said "what?" I again asked why there were no dyno sheets to back the manufactuer's claim of TQ. & HP.? Billion dollar company, no dyno sheets, what gives? He told me I could buy the truck, and do my own test if I like.....funny how that panned out ;-) I guess gallop would have claimed their customer service sucked at that point ![]() |
#25 (permalink) | |
Cranky Moderator
Thread Tools | |
Display Modes | |
