A340 Transmission issues and FAQs - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-01-2019, 10:04 AM   #126 (permalink)
Boomtacoma01's Avatar
Member # 139434
Another question. Is there a difference in the input spline counts between an A340 and Aw4? I know a lot of the stuff interchanges. I'm just unsure if the TCs can be swapped.
1985 Xtra Cab - 22RE, 39" Red Labels, D60, 14B, 3 Link/4-Link, A340F, Atlas II 4.3, Lone Star Light....
2017 Ram 2500 Crew Cab 4x4, 6.7 tow rig
IG: @boomtacoma01
-Chris
Boomtacoma01 is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 04:40 PM   #127 (permalink)
Member # 166413
Both are 23 spline but they're different sizes
Sent from my Pixel XL using Tapatalk
downpour11 is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 12:44 PM   #128 (permalink)
Member # 139434
It's the outputs that are 23 spline. I have the AA adapter to use my Atlas and it comes with the spud shaft to change the toyota 23 to the Jeep 23 spl.
The input on the AW4 is 26 from what I have read. Anyone know if the A340 is also 26?
IG: @boomtacoma01
-Chris
Old 04-08-2019, 06:07 PM   #129 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
Depends on year of trans. I fit up a AW4 converter to my 92 A340f, but my RZ converter was a different spline count and didn't fit. So I used a 3VZ converter to fit the RZ motor and the RE A340f. Simple.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 07:07 AM   #130 (permalink)
Member # 139434
I figure its going to be a bit of trial and error. I currently have an 02 A340F, 3.4 converter, 22re Bell Housing and Flex plate to my 85 22re. The 22re TC did not fit on my particular trans. I had to enlarge the holes on the 22re flexplate to align with the 3.4 TC.
The reason for all of the questions is that I intend to use a Novak 374-3 adapter and flexplate, an AW4 bell, AW4 TC with my a340F in order to run a GM 5.3
I just may rip all this out and run a 4l65 and change the inputs on my Atlas..
IG: @boomtacoma01
-Chris
Old 04-11-2019, 01:50 PM   #131 (permalink)
Mall Crawler
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
Run the 4l65
I run the spud shaft and think about it all the time. Im running a SC 3.4 A340 atlas 4spd
1994 Toyota Extra cab, Exo, SAS, Linked, Kings, Air Bumps, 60s, 5.38, Detroit/Detroit, 40"Maxxis Comp Trepadors, Supercharged 3.4 5vz V6, A340F Auto Trans Manual shift, Atlas 4.3 4spd, Winch front and rear. CA smog legal and DD
2018 Colorado ZR2 Duramax
2005 Dodge 2500HD Cummins 4x4 35s
Edisonsteve is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 11:55 AM   #132 (permalink)
Member # 139434
Pretty much decided not to run the A340. Might as well mitigate any potential issue now rather than later.
IG: @boomtacoma01
-Chris
Old 04-16-2019, 06:45 AM   #133 (permalink)
Member # 67823
Pretty basic stuff, but my 500,000km 4runner with a 22re and an auto a340f was down for a month or so. When I started driving it again, the speedometer was working intermittently. I went for a drive, spent the day in the bush a long way from reception or civilization, and on my way home, I took off from a light and the trans was barely engaging, had to rev to 5000rpm to move, just to get off the road. Shut it down, restarted it, and it worked. Turns out the computer needs a speedo signal for the trans to work properly. My electric sender on the Tcase was still good, it was the dash cluster that had died. New cluster and it works properly again.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
