My '82 First Gen Project: The Dirt Squirrel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-26-2009, 07:44 PM   #1 (permalink)
Member # 103621
Ok gentlemen, here we go. I am going to post my build on PBB so I can get some honest feedback. This is my first build of any kind so please tell me if I am doing anything wrong or seriously unsafe. This truck will see trails only and mostly muddy ones at that. Maybe one day I will be mature enough for the rocks, but not today. Anyways, here are the specs with pics to follow:
Up to date specs as of 11/8/2011
One genuine 1982 Toyota Longbed Pickup SR5 Package bobbed 16'', Round headlight Conversion, 2x4 .120 wall sliders
Engine: 1993 4.3L Vortec CPI on switches, snorkled inside the cab, rear mounted radiator & fuel cell in bed w/ Walbro pickups, FJ80 Master Cylinder, Ford Taurus E-Fan
Trans: Th350 w/ Downey Adapter, Lokar shifter, rear mounted trans cooler
T-case: Marlin 4.7s, single case, Longfield Output, flat Bud-Built crossmember
Axles: Fully rebuilt '82 front with all new seals, bearings, 4:37s, spool, 2'' wheel spacers, land cruiser vented discs, V6 calipers, IFS Hubs, 30-spline Longfields w/ chromo hub gears, lexus ARP wheel studs.
Stock '87 4-runner IFS rear w/ 4:37's and welded, Davez rear disc brackets, residual & proportioning valves, all SA toyota disc swap, 2" spacers.
Steering: Marlin arms, Full Hydro w/ Surplus Center Single ended 6" ram, eaton orbital, semi truck reservoir
Tires: 37x13.50x17 Mickey Thompson Baja Claw Comps
Rims: 17x8 Cragar Soft 8's w/ 4.5'' backspacing
Suspension: Front: Stock '82 RUF doubled and cut down with a second set from another '82. 12'' Fox Emulsions
Rear: Stock 2005 toyota rear leafs (2+overload) 57'' long, 15'' Poly Performance BBCS, Ballistic Mounts
Front Hanger: Sky's with boomerang shackles
Rear Hanger: Sky's chevy hangers and shackles
Now pics:
A 4 hour drive later, and I was the proud new owner of basically a cab and frame for $200. Great price from a great guy. Thanks again Eric. The truck had a rust free frame, and only had a quarter size hole in the driver's side floor. Overall, very straight.
The day I picked it up:
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 07:52 PM   #2 (permalink)
Member # 104110
Get to work and keep us posted.
rws83toy is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 07:58 PM   #3 (permalink)
Member # 103621
A few weeks later, I was driving some backroads and came across an '82 sitting in a field in pretty bad shape. Rust everywhere, kids kicked the shit out of it, but it was mainly complete. I talked to the guy and for $40 he said I could take anything off of the truck i wanted. So....
I got:
1. Front axle w. original BFG A/Ts
2. both drive shafts
3. top shift transfer case w/ shifters
4. All four stock steel wheels for rollers
5. Misc interior pieces
Old 03-26-2009, 08:02 PM   #4 (permalink)
Toyota Dismantlation
Erick561's Avatar
Member # 100293
Location: I ship from New London County Connecticut & Undercut
Send a message via AIM to Erick561
40$, what a steal
Erick561 is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 08:10 PM   #5 (permalink)
Member # 103621
After several weeks of sanding, painting, and collecting parts, I got the rear frame and top of the cab all painted. I picked up a 2wd longbed near Dallas for $50 with tailgate, and ZERO thru rust. I then bobbed it 16'' (not welded up yet). Alot harder than I thought, but i have made some progress on the bed. I also made a call to Sky Manufacturing and ordered their front and rear leaf spring hangers and shackles. I mounted the rear hanger 5.5 inches forward of the stock hangers, and moved the front up somewhere around 1.75 inches to get the front axle out of the firewall.
Old 03-26-2009, 08:19 PM   #6 (permalink)
Member # 103621
Next came the dirty part. I rebuilt my front axle. I have never taken apart a toy front axle before, and I think I went thru 7 rolls of paper towels. I bought a rebuild kit from Marlin, ansd replaced all the seals, and bearings. I rebuilt the hubs, removed all of the unecessary bracketry, sanded and painted. While it was apart, I upgraded to the landcruiser vented front discs and added 2'' wheel spacers. I also upgraded the steering with a mixture of Marlin arms with All Pro tie-rod and drag link. This was by far the nastiest shit I have ever messed with. 20+ years of mud, grease and rust. But I think It came out pretty good. THANK GOD for the FAQ at the top of the forum. It saved my life.
Pics:
Old 03-26-2009, 08:25 PM   #7 (permalink)
Member # 1823
Looks good so far. Going to have to get started on my 82 here before too long.
1982 SR5, ProZap F-Bumper Marlin L52HD 1994 SR5 4Runner DD, OME 1.5" lift 3.4l swap
Cycler is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 08:27 PM   #8 (permalink)
Member # 103621
I put the stock tacoma rears on the IFS axle i picked up from Steve here on the board and used the spare rims i had to roll it into position under the rear of the truck. I didnt have to move the rear spring hanger back any and like stated earlier, i moved the front up 5.5 inches. I got the rear springs for free. They are real soft, and I will just see how they work out. If not, I guess I will move on to the F150's in the future.
Its starting to take shape.
Old 03-26-2009, 08:41 PM   #9 (permalink)
Member # 69410
Send a message via AIM to 1stgenxxx
make sure to clean all the rust and paint off the frame before welding the spring hanger on
89 x-cab 40"s sbc/th350/205 RIP
01 Rattle box, 98 Cherocar
1stgenxxx is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 08:41 PM   #10 (permalink)
Member # 103621
And now for the good stuff, I got all the hangers welded on by a friend of mine, who welds for a living. He did a damn good job too. a few weeks earlier, I bought a set of near new 37'' Baja Claws for $400 and mounted them on set of cragar soft 8's i ordered from Summit. A couple days ago, i startied putting it all together when i got off of work. The truck sits a little to tall for my tastes. Its 29'' from the frame to the ground. The truck came with a 3'' body lift when i picked it up. I may keep it so i dont have to cut up the floor when I put the engine in. I am going to take out the blocks in the rear to try to get it a little lower. Once the engine is in, hopefully it will sit lower in the front to as well. I think my shackle angle look pretty good considering alot of the weight is not yet in the truck.
Here are the pics, let me know what you think....
Old 03-26-2009, 08:47 PM   #11 (permalink)
Member # 103621
A few more pics..
Old 03-26-2009, 08:50 PM   #12 (permalink)
Member # 103621
Dont worry, I grinded it smooth before it was welded on. It was fully welded on the sides and stitched welded across the front and back. Hopefully, its not going anywhere.
Old 03-26-2009, 09:35 PM   #13 (permalink)
warren's Avatar
Member # 4910
Send a message via AIM to warren
Looking good man I love the 1st gens wish I still had one. looking forward to seeing it done
warren is offline   Reply With Quote Quick reply to this message
Old 03-26-2009, 09:44 PM   #14 (permalink)
Member # 125447
long beds are not my fav. but you have done a really nice job on this truck lets see this bad boy in action and with all one color
wheelingyota is offline   Reply With Quote Quick reply to this message
Old 03-27-2009, 05:28 AM   #15 (permalink)
Kaptain's Avatar
Member # 31353
Send a message via AIM to Kaptain
Looking good - I give you props for finding such good deals
Rusted 93 X-cab on bald 37's
Kaptain is offline   Reply With Quote Quick reply to this message
Old 03-27-2009, 05:54 AM   #16 (permalink)
Member # 82366
Your truck's off to a great start. I'd have to agree with you on the height though. It looks a little tall in the front, but there's no motor yet...However as much as I don't like body lifts, I think I like cut up fenders even less. Keep it full-bodied and it'll look awesome.
[COLOR="SandyBrown"][B]
[/B][/COLOR]
CanTheWhales is offline   Reply With Quote Quick reply to this message
Old 03-27-2009, 06:08 AM   #17 (permalink)
Member # 103621
Definitely, paint and body work are on the list, but a ways down the page. I neeed a set of front fenders, if anybody has any just laying around.
Thanks, I just have been lucky i guess. But i have a feeling the engine swap wont be so cheap.
I agree, Im going to try to keep the body there. Im not a big fan of flat beds so the bed is staying for sure, but I am going to open the rear fenders up some.
Old 03-27-2009, 08:37 AM   #18 (permalink)
Alex123456's Avatar
Member # 52396
I like it. First gens are always my favorite
Alex123456 is offline   Reply With Quote Quick reply to this message
Old 03-27-2009, 07:48 PM   #19 (permalink)
Erick561's Avatar
Member # 100293
Whats your budget?
Old 03-28-2009, 07:44 AM   #20 (permalink)
B.C. 05's Avatar
Member # 14070
Looking good man!!! Glad to see it went to a good home and it will be brought back to life soon.
74 Dodge W100
85 Dodge W350 Crew Cab Cummins
B.C. 05 is offline   Reply With Quote Quick reply to this message
Old 03-28-2009, 08:02 AM   #21 (permalink)
Member # 103621
Originally Posted by Erick561 View Post
Whats your budget?
I wouldnt call this a budget build. I want to do it right the first time, so if that means spending more $$ up front then so be it. I am spending money as I save it up, and with whatever the wife lets me.
Slowly but surely its getting there. Brake upgrades are next.
Old 03-28-2009, 08:53 AM   #22 (permalink)
Member # 109586
Hey shadow,
I love the build, lookin good!
This would be a perfect canidate for a 4.3 running a stock harness and PCM, with a used, Marine port injected intake.
Kiwi
Kiwipushrod is offline   Reply With Quote Quick reply to this message
Old 03-28-2009, 02:30 PM   #23 (permalink)
Erick561's Avatar
Member # 100293
I hear ya. Since I started my first build, I've put thousands of dollars into tools and setting the shop up. I also wanted to do it right the first time Theres always room for upgrades, though.
Kiwi
x2 It'd be sick
Old 03-28-2009, 04:24 PM   #24 (permalink)
jpdunn101's Avatar
Member # 101743
x2 It'd be sick
Hmmm, looks familiar. Glad someone noticed!
Here's the build thread: http://www.yotatech.com/f163/swap-to...-chevy-156022/
BTW, It was worth it.
'85 4runner, 4.3 vortec/700r4, mpi intake, MSII, Marlin bumpers, m8000, Allpro x-over, MT 33's
jpdunn101 is offline   Reply With Quote Quick reply to this message
Old 03-28-2009, 04:30 PM   #25 (permalink)
jpdunn101's Avatar
Member # 101743
Hey shadow,
Kiwi
Buy a new intake it's cheaper!!
http://cgi.ebay.com/ebaymotors/Mercr...ssoriesQ5fGear
