4runner rear 3links - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2010, 05:08 PM   #1 (permalink)
Member # 155685
4runner rear 3links
hi everybody
i do a lot of serch an i cant found thos enswers
i made a setup that loock like that on my 93 4runner
lower links are 43" 1/2 long and at ridehight thez are at 7* whit the horizontal
thez are bolted hunder the frem at around 14" from the t-case flange and on the center of the axel on the diff
the upper link is 41" long vetical separation on the diff is 8"7/8 and on the frem the vertical is 4"7/16
when the suspention is full down the lower links is at 20* whit the horizontal
when i cycle the suspension up and down i get 7* of axelwrap
when i cycle the suspension from down to up the diff go backweard 2"
my question is
7* of axel wrap is it too mutch
my uperlink is more than 70% of the lower is it bad
lower link 43"1/2 is it too short or too long
and the axel go backweard 2" is it too mutch (oversteer)
and maybe give my some advice for panhard
i made a lot of reserch and i cant found a post for a rear 3links that explain step by step how for a dum like my i am very comfuse whit all thos term (instant cg,rollcenter,rollaxis,cg,....) i know its important but maybe i can do a setup whit minimum instruction that whill do good job and after i will learn to tune this base setup
thankyou its realy appreciate
mart1030 is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 05:15 PM   #2 (permalink)
Member # 113217
i say play with the calculator and see what will work on your rig. you can always move the gas tank and 4 link it too.... 4 link might make you happier
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny)
ec2469 is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 05:27 PM   #3 (permalink)
Member # 155685
i dont know how the 3links calculator work
Old 03-15-2010, 05:51 PM   #4 (permalink)
Member # 86280
Apparently you don't know how spell check works either, or grammar for that matter.
David D is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 05:57 PM   #5 (permalink)
250f4life's Avatar
Member # 51984
Dammit man, thats hard to read,
250f4life is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 06:17 PM   #6 (permalink)
Member # 103621
I am going out on a limb and say that english is not his native language.
I would do some more searching and compare other peoples numbers to your numbers. I dont think there is a 'tell all' 3-link thread for 4runners, but you should be able to find numerous builds who have a 3-link in the rear.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 03-16-2010, 03:39 PM   #7 (permalink)
Member # 155685
i am sory thrust me i do my best
Old 03-16-2010, 03:49 PM   #8 (permalink)
dane's Avatar
Member # 21948
Nothing to add other than this brings funnay!!
Dane
I WILL TRY BEING NICER IF YOU TRY BEING SMARTER.
dane is offline   Reply With Quote Quick reply to this message
Old 03-16-2010, 04:41 PM   #9 (permalink)
Member # 155685
i will be happy if i get a answer for only one question
today i made somme math and found i have 3.5* of oversteer but i dont know if its a lot or its ok
Old 03-16-2010, 09:07 PM   #10 (permalink)
Hottrod81's Avatar
Member # 36464
I think that is pretty good for a 3 link. I think Booger Weldz posted on here at one time that the Trail Gear 3 link has 5 degrees of oversteer.
Hottrod81 is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 07:30 AM   #11 (permalink)
Taco-Runner's Avatar
Member # 110365
7*
"THE" Link System Specialist for your Toyota Truck, 4Runner, Tacoma and 80
Custom Tuned Shocks for Leaf Springs & Coilovers
Taco-Runner is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 07:59 AM   #12 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
My attempt to translate/clean up his post:
Hi everybody.
I did a lot of search and I cant find those answers now. I made a setup that looks like the one on my 93 4Runner.
The lower links are 43" 1/2 long, and at ride height they are at 7* from horizontal. They are mounted under the frame, approx. 14" behind the Tcase flange (single cases). They mount on the axle centerline.
The upper link is 41" long. Vertical separation on the diff is 8 7/8" and on the front the vertical separation is 4 7/16".
When the suspension is at full droop the lower links is at 20* from horizontal.
When I cycle the suspension up and down I get 7* of axle/pinion rotation.
When I cycle the suspension from down to up the diff goes backward 2".
My questions are:
-7* of axle wrap: is it too much?
-My upper link is more than 70% of the lower: is that bad?
-Lower link 43"1/2: is it too short or too long?
-The axle going backward 2": is it too much (oversteer)?
-Can anyone give my some advice for the panhard bar?
I did a lot of research and I can't find a post for a rear 3links that explain step by step how to build one for a dummy like me. I am very confused with all the terms (instant cg,roll center,roll axis,cg,....) I know its important but maybe I can do a setup with minimum instruction that will do good job and then afterwards I will learn to tune this basic setup
Thank you, your help is really appreciated
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 08:02 AM   #13 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
FTY, here is my 3 link rear: https://www.pirate4x4.com/articles/pr...iews/eor_3link
I can get you link length measurements this weekend if you would like.
>David
Old 03-17-2010, 10:57 AM   #14 (permalink)
Member # 61944
Send a message via AIM to 4runnerboy Send a message via MSN to 4runnerboy Send a message via Yahoo to 4runnerboy
The link above would be cooler if the pics worked, or is it my computer? if it's me then to me!
2001 Dodge Ram 2500 CTD Auto Tow rig.
1991 Toyota 4Runner 3VZ-E 5-Spd waiting to get cut up
4runnerboy is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 10:59 AM   #15 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
They worked for me in FF, guess they were cached. I'll see about getting them fixed.
>David
Old 03-17-2010, 02:22 PM   #16 (permalink)
Member # 155685
thankyou drm
long time ago i found your post but i dont know why i cant see the picture and its make me mad
Old 03-17-2010, 02:27 PM   #17 (permalink)
Member # 155685
i think its because my lower link are whay longer then the tg kit
i think
Old 03-17-2010, 03:58 PM   #18 (permalink)
Member # 155685
when i click on you picture thers a massege and it says (warning include failed to open stream)
Old 03-17-2010, 04:23 PM   #19 (permalink)
Member # 155685
yes i will be verry happy if you do that for me
thankyou
Old 03-19-2010, 09:44 AM   #20 (permalink)
Member # 2931
i think
somewhat, it would be different based on link angles at ride height
[B][U][I][COLOR="Red"]Www.4wheelunderground.com[/COLOR][/I][/U][/B]
Booger Weldz is offline   Reply With Quote Quick reply to this message
Old 03-19-2010, 08:29 PM   #21 (permalink)
Member # 147429
I'd also be interested in your link numbers.
Old Build: swollen-member-85 Toy-4-seater-linked-coilovers-diamonds...
YotaLay is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 03:25 PM   #22 (permalink)
Member # 155685
somebody can give me the link for the 3 links calculator
Old 03-21-2010, 06:01 PM   #23 (permalink)
Member # 155685
ok i found one
Old 03-23-2010, 04:29 PM   #24 (permalink)
Member # 155685
ok i put some number in the 3 links calculator
anti-squat 86%
roll axis slope .182"
roll axis angle 10.3*
roll center height 28.84"
instant center x-axis 100.57"
instant center z-axis 35.42"
tell me what you think about that
thankyou
Old 03-23-2010, 11:45 PM   #25 (permalink)
ErikB's Avatar
Member # 59
That roll axis angle is very steep.
[color=black].[/color]
