Would you use this? (broken pinion) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-09-2010, 09:54 AM   #1 (permalink)
tunaboat's Avatar
Member # 101816
Would you run this? It was dropped, just that one tooth broke. I was thinking about maybe running it in the front. What do you think?
I used to be sane, then I got better.
tunaboat is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 10:05 AM   #2 (permalink)
Member # 85302
did you drop it from an airplane?
Will.The.Thrill is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 10:10 AM   #3 (permalink)
Member # 127409
I would maybe keep it as a spare but to use no.
limitedunlimited is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 12:44 PM   #4 (permalink)
Member # 74697
run it
85 pickup 7mgte dana 60&70 RCV 44s duals etc.
81 RustBox 98 supercharged taco
Calibre is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 01:21 PM   #5 (permalink)
298
Member # 147678
I would definately run that. I've seen much worse in 3rds that work perfectly
298 is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 01:54 PM   #6 (permalink)
Member # 129345
Send a message via MSN to Tw1st3d Up
Originally Posted by Calibre View Post
run it
WHY? If he dropped it and it broke I wouldn't trust it to drive me around? Maybe it's just me but it seems like you would be asking for trouble to drive with any kind of a broken gear.
:flipoff2:
[QUOTE=leben_sie_gut;11466494] There are some big ass steps so he and his orca-queen can flop up in it though.[/QUOTE]
I want
Tw1st3d Up is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 01:57 PM   #7 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Id set it up and keep it on the trailer as a spare third for getting off the trail purposes, definitely would not daily drive it.
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
88 4Runner Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 02:13 PM   #8 (permalink)
ErikB's Avatar
Member # 59
I just did some wheeling and drove 30 miles on mine with an entire pinion tooth missing. It makes noise under load and obviously is going to self destruct eventually but its working and got me home to where I could troubeshoot it.
A friend of mine had 2 or 3 teeth missing on the ring gear that would make noise under load sometimes and we couldn't figure it out. After some wheeling and about 60 miles of road driving we ended up tearing it apart and found the missing teeth.
I would say that tiny fragment out at the tip isn't going to make huge difference, just like shaving down a ring gear doesn't make a huge difference. Obviously its not ideal, but it will work just fine for most stuff. Just depends how hard you are on stuff and what your plans are.
[color=black].[/color]
Old 06-09-2010, 03:06 PM   #9 (permalink)
GloNDark's Avatar
Member # 2482
If it's going in the front, i'd run it. Hell i've seen WAY worse than that being put back into a 3rd member. Will it last forever? Probably not. But if you're short on build funds and can put it in the front, I'd go for it.
BUILD THAT FUCKING WALL!!!
GloNDark is offline   Reply With Quote Quick reply to this message
Old 06-15-2010, 12:53 AM   #10 (permalink)
Member # 98886
im running worse in my front diff... im not as hard core as alot of ppl here but its nothing but a little noisy....
plus i carry a spare third in my tow rig..
84 4runr 22r, Weber rotated 180*, duals,4"? RUF, 5.29s lockrite F, welded R, 40's....
Slimer 79 is offline   Reply With Quote Quick reply to this message
Old 06-15-2010, 01:27 AM   #11 (permalink)
Member # 103610
Send a message via AIM to jeep937
I've seen worse on my own Jeep front and rear. They worked fine and I caught them before the blew. If I was building an axle with new install kit, joints and bearings I try to get a new free one. I've got free and severely discounted parts with just a simple phone call from even supposed "bad" vendors, years out of warranty and no questions.
If you can't get it for free, R&P's can be found as low as $130. Just get a new set.
jeep937 is offline   Reply With Quote Quick reply to this message
