my 85 JD toy build - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-01-2019, 03:45 PM   #76 (permalink)
JDWeeler's Avatar
Member # 170770
dissembled the steering reservoir and used a piece of the drive line to extend it 4"s taller.
relocated the fuel door for the rear ford tank
worked out pretty good cut the door out made a template and moved it back behind the fender after lots of measuring. had to move it a little forward to avoid the body mount on the inside which made my fenders a little smaller.
I ain't stuck,I've stopped to grab another beer :flipoff2:
JDWeeler is offline   Reply With Quote Quick reply to this message
Old 04-02-2019, 09:23 AM   #77 (permalink)
JDWeeler's Avatar
Member # 170770
moving along. got some templates form a runner on 46s was a good start but ended up making my own since my fenders are smaller
extended the inner fender 6"
Old 04-05-2019, 10:03 PM   #78 (permalink)
Member # 777769
Thatís looking like itís turning out nice. How did you prep the inner fender? (Clean and remove coatings) that looks
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 04-12-2019, 12:22 PM   #79 (permalink)
JDWeeler's Avatar
Member # 170770
just used a chisel and a hammer to get most of the rubber coating off then a scotch brite pad on a air grinder
Old 04-12-2019, 12:27 PM   #80 (permalink)
JDWeeler's Avatar
Member # 170770
well the time has come. finally got my new housing so out with the old in with the new
i will be getting this in hopefully tonight
Old 04-12-2019, 12:30 PM   #81 (permalink)
JDWeeler's Avatar
Member # 170770
starting to wonder if its going to fit out of the garage?
Old 04-28-2019, 10:56 AM   #82 (permalink)
JDWeeler's Avatar
Member # 170770
So what degree do you guys tilt the rear third at? I ended up having to re-due the rear axle perched and am trying to figure out a good degree to set it at
And of course I forgot to check it before cutting the old ones off
This is what I got at full droop right now. Yoke tilted up 10į at full droop
