my 85 JD toy build - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-14-2020, 08:10 PM   #101 (permalink)
JDWeeler's Avatar
Member # 170770
After talking to Danger Ranger about the strength of my cage and scoring a tubing bender for $400. Started cutting out all the center pieces and adding some triangulation.
I ain't stuck,I've stopped to grab another beer :flipoff2:
JDWeeler is offline   Reply With Quote Quick reply to this message
Old 01-14-2020, 08:15 PM   #102 (permalink)
JDWeeler's Avatar
Member # 170770
Old 01-15-2020, 10:14 AM   #103 (permalink)
Member # 140628
Nice work on the cage. Keep it going
hodgiemoto is offline   Reply With Quote Quick reply to this message
Old 01-15-2020, 12:21 PM   #104 (permalink)
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
x2, cage work looks great
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
2019 Tundra
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 01-15-2020, 02:09 PM   #105 (permalink)
OCD
Member # 341361
Cage is coming together nice. Curious what you did for the A & B pillar floor plates. Got any pics of those? Doing a cage right now myself, just looking for ideas...
OCD is offline   Reply With Quote Quick reply to this message
Old 01-16-2020, 01:08 PM   #106 (permalink)
JDWeeler's Avatar
Member # 170770
Just used 1/4” plate and over sized them over the body mounts. Then drilled a hole for a longer bolt to go through the plate and body mount. There is a 1 3/4” piece of tubing resting in the body mount to make up the space when the body mount bolt is tightened.
Might end up putting a plate under the body, sandwiching it with bolts and then a piece of tube to the frame
Old 01-16-2020, 01:21 PM   #107 (permalink)
JDWeeler's Avatar
Member # 170770
Bought some aluminum wheels awhile back and finally scored some larger iroks for them. Went from 37ís to 39.5ís. Amazingly the larger tire w/ aluminum wheel is 18lbs lighter than my h1 bead locks with 37ís.
Now I need to figure out larger, longer studs and bead lock spacers.
Old 01-16-2020, 06:10 PM   #108 (permalink)
JDWeeler's Avatar
Member # 170770
B Pilar
A Pilar
Old 01-16-2020, 06:15 PM   #109 (permalink)
JDWeeler's Avatar
Member # 170770
Some parts came in today. Steering cooler, PSC power steering pump for the hydro assist and my low max gears for the Dana 300.
Funny how the gears and output shaft where mailed at the same time in 2 different boxes from the same place and only one showed up. Other one says tomorrow
Old 01-17-2020, 08:31 AM   #110 (permalink)
JDWeeler's Avatar
Member # 170770
Put the wife on dimple Dieing the slider steps for the kids.
Floor tunnel figured out and welded up.
Center console with a rear heater in it mocked up. Waiting on heater Louvers and ducting to finalize it.
Old 01-18-2020, 01:25 PM   #111 (permalink)
OCD
Member # 341361
Like the way you did that little tube in the body mount. Actually gives me some ideas...Thanks!
