Bucking 4 runner - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2011, 06:53 PM   #1 (permalink)
Member # 154512
Bucking 4 runner
I am 17 and building my first wheeler. I have an 86 4runner with a SAS and 35s. It used to run great, but now in the morning it wont idle when its cold, and when its warm it bucks off the line, and REALLY bucks and surges going uphill in 1st gear.
I have replaced the cap and rotor, checked the timing, and replaced the o2 sensor and fuel filter and it still sucks. HELP!
4runnerchris is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 07:15 PM   #2 (permalink)
Member # 159654
Uphill makes it sounds like a fuel pump.
Have you looked into that?
RossGo is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 07:51 PM   #3 (permalink)
Member # 154512
thanks ill look into that!
any other suggestion?
Old 01-06-2011, 06:41 AM   #4 (permalink)
Member # 144923
Send a message via Yahoo to Full Throttle ORC
Fuel filter, or coolant temp. Just another place to look.
Full Throttle
Northwest Ohio
Full Throttle ORC is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 07:59 AM   #5 (permalink)
Member # 154512
radiator and fuel filter are both new. but thanks
Old 01-06-2011, 08:12 AM   #6 (permalink)
cdub350's Avatar
Member # 35949
Check the rubber intake boot very closely.
cdub350 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 08:51 AM   #7 (permalink)
Member # 152600
Tell us about the motor. Stock? Mods or anything? And how long you've had it. Is it very cold out when the problem occurs? And I take it the motor is fuel injected.
4Runner006 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 09:29 AM   #8 (permalink)
Member # 144923
Not radiator. Coolant temp sensor. If that's out of range, it can throw it off.
Full Throttle
Northwest Ohio
Old 01-06-2011, 05:55 PM   #9 (permalink)
Member # 154512
the motor is a 22re fuel injected stock with 235000 miles on it.
Old 01-06-2011, 08:15 PM   #10 (permalink)
Member # 111426
Vacuum lines came off somewhere?
turbohaulic is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 08:57 PM   #11 (permalink)
Member # 137944
How are the RPM's? Do the surge up or down or both? Vacume is a good one like turbohaulic said or maybe intake gasket? Use starting fluid or carb cleaner to test the lines and intake.
85 toyota is offline   Reply With Quote Quick reply to this message
Old 01-07-2011, 12:31 PM   #12 (permalink)
vigilantejustice's Avatar
Member # 54804
Send a message via MSN to vigilantejustice
I had the same thing, check my previous posts for everything I tried and start there, it ended up being my ecu. Could be a lot of things, get ready to get your multimeter out to test stuff. Is it throwing codes?
87 runner - SOLD
82 4x4 lifted and locker - RIP
85 4 Runner - Beater-saurus-rex
vigilantejustice is offline   Reply With Quote Quick reply to this message
Old 01-11-2011, 10:28 PM   #13 (permalink)
Member # 154512
I checked all the vaccume lines and thier all good and I ajusted my throttle cable because it was loose but none of that changed anything it seems like when i start the truck that it electrically wants to keep staring even tho its already running. just another related problem that might help with figure out whats making the bucking and surging when going up hill or shifting into first.
thanks for the help
Old 01-12-2011, 02:57 PM   #14 (permalink)
Member # 39740
Had the same kinda problems with my 91 crawler....would idle fine and rev but when under any load it would surge and bog. I never did pin point the problem before I said F it and went to propane but I'm sure it was the fuel pump. Everything checked out and no change when I soaked the thing in starting fluid.
I would try another pump even if your connection seems good, the sock could be gummed up as well.
3rd gen X-cab, pane, SAS, 4link rear SAW airs, flatbelly duals, locked n geared on IROKS.......
yota-tota is offline   Reply With Quote Quick reply to this message
Old 01-12-2011, 03:19 PM   #15 (permalink)
SLC97SR5's Avatar
Member # 98713
Igniter/coil. You can ohm them out per the FSM but mine was BAD and had resistance values within spec.
SLC97SR5 is offline   Reply With Quote Quick reply to this message
Old 01-12-2011, 04:02 PM   #16 (permalink)
Dirty Doof's Avatar
Member # 138419
Tps could be bad. I've had funky shit happen when those go bad and its night and day difference with a new one
Dirty Doof is offline   Reply With Quote Quick reply to this message
Old 01-12-2011, 04:16 PM   #17 (permalink)
Member # 140752
I say check the AFM. The non idle when cold sounds like Cold start Injector is not coming on, and bucking in 1st, sounds like lack of fuel delivery.
81NorCalYota is offline   Reply With Quote Quick reply to this message
Old 01-12-2011, 06:01 PM   #18 (permalink)
Member # 154512
I just got some injector cleaner and a new coolant temp sencor ill see if that works and if not ill try some of the other options you guys gave me.
thanks.
Old 01-12-2011, 06:11 PM   #19 (permalink)
88mitsu's Avatar
Member # 125523
I had a truck(not toyota, but 4cyl. carb) do that, my uncle told me to change the PCV valve and fuel filter and it worked great after that.
START UP THE ROTORS
88mitsu is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 06:34 PM   #20 (permalink)
Member # 154512
I found out my problem, might be helpfull to others. All it was was a crack in the air intake boot just patched the crack and solved all the problems. very simple but very succesfull
Old 02-01-2011, 07:53 PM   #21 (permalink)
Member # 181990
post #6
mudjunky13 is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 08:33 AM   #22 (permalink)
cdub350's Avatar
Member # 35949
What do I win?
