Northeast forsale wanted and trade!!-POST ONLY HERE - Page 19 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northeast
Old 03-16-2017, 02:14 PM   #451 (permalink)
Member # 89364
37 1250 15 tires and wheels
4
37 1250 15 parnelli jones dirt gripz
Somewhere around half tread.
Work good off-road. And run down the road fine. On my daily driver.
Also have a spare old style Goodyear Mtr 37 1250 15
All 5 on black wagon wheels "d window" style
5 x 4.5 bolt pattern.
3.75 back spacing.
Would like to sell all 5 together. Tires rims and all.
They are all balanced.
1 tire has a small tear in the bead. Not visible.
Has plugs in it and bead sealer.
Has leaked when I've run them at single digit pressures and bulged it on rocks.
Otherwise it's perfectly fine.
As I said before. They are driven daily with no problems at all.
Looking for $700 for all 5 tires and wheels.
I will take offers.
Would also split up. But the price goes up.
Best way is call or text.
570 nine seven seven 3743
In stroudsburg pa 18360.
Thanks
Paul.
Trying to figure out how to add pictures
three is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 06:19 PM   #452 (permalink)
Member # 493553
Selling a bunch of stuff...
Four brand new never mounted TSL SX's 38/12.5/16.5 with used Trailworthy Fab H1 double beadlocks. Brand new unused PVC inserts and O-rings from Trailworthy Fab as well as the old O-rings.
Wheels are 8x6.5
$2600
GM Dana 60 front axle with....
TMR simple truss and panhard mount
TMR diff cover
Stock shafts
Stock cover
Stock knuckles
Stock brake brackets
Stock tie rod
Stock carrier
Stock gears (3.73 I believe)
Stock spindles
Superwinch lockout hubs
No hub/bearing assemblies
Housing is stripped, cleaned and straight...no brackets as it was going in my Jeep.
$900
GM 205 transfer case
Around 36k original miles
Tail housing converted to newer VSS electronic style
Clocking ring
Tail support with bushing
Yoke rear
Flange front
32 spline input
Case was completely disassembled, cleaned and reassembled with new seals, new gaskets and painted with POR15
$550
16.5x10 steel wheels
8x6.5
Need paint
$200
Everything located in East Haven, VT
showjyr is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 01:05 PM   #453 (permalink)
badlarry's Avatar
Member # 118892
1993 SAS Suburban, Wiscasset Maine
1993 SAS Suburban,
350 Chevy crate engine with 85,000 miles. Body has 171,000 miles. This is a southern truck with no rust on body or frame except for some small patches of surface rust where paint has chipped. There are some dents. 9" lift, King Pin D60 front, 14 bolt rear. (LS in the rear/open front) Crossover steering. Automatic with overdrive and shift kit. Glass is tinted. Great stereo with 2 10" subs, 2 amps, and 4 speakers. 37/12.5/16.5 MTRs on 24 bolts. Front tires are brand new. Rear about half tread. Also have 2 others mounted and balanced for spares with about 25% tread. Pretty sure the gears are 4.56 or 4.88. Goes down the road great. 7 passenger seating in great shape. Third seat is removable. Custom stainless rear bumper, push bar, and steps. Towing mirrors. Train horn. Power windows and locks. Rear defrost. A/C does not work. $5600.
I listed this for a buddy so PM me if your serious, have cash, and I'll put you in touch with him. Thanks.
badlarry is offline   Reply With Quote Quick reply to this message
Old 03-30-2017, 04:44 AM   #454 (permalink)
dr_dobro's Avatar
Member # 165312
WTB 14 bolt with 5.38 gears and selectable locker
Long shot to this. Locker Preferably ARB
TLC owner.
dr_dobro is offline   Reply With Quote Quick reply to this message
Old 05-02-2017, 09:40 AM   #455 (permalink)
xjcutter's Avatar
Member # 44242
86 4Runner part out
https://www.pirate4x4.com/forum/misc-...l#post40636281
xjcutter is offline   Reply With Quote Quick reply to this message
Old 05-05-2017, 08:12 AM   #456 (permalink)
Member # 96278
Found a new project...
Need to make room. Selling Phred.
https://www.pirate4x4.com/forum/ford/...7-phred-2.html
One ton 351 4 speed. Needs finishing.
$3700 w/ (5) 37" Boggers in new condition
$3200 w/ (4) 38" TSLs in decent condtion
$2000 on rollers.
And selling Franklin.
46ish CJ2A no engine, lots of bondo. And rust. $600.
Franklin is sold. Good luck, dude who's name isn't Aaron
Drink to the dead all you still alive
We shall join them in good time
cj5.5 is offline   Reply With Quote Quick reply to this message
Old 05-08-2017, 07:24 AM   #457 (permalink)
Member # 114810
http://rc4x4.org/rcforum/index.php?t...5354#msg145354
Pics in link^^^^^
1992 Jeep YJ, 350tbi, th350 automatic, 241c case
Waggy dana 44s, 4.88 gears, ected front with yukon shafts/spool rear
Hydro assist, soa front suspension, rear 4Link with coils
37" Trep radials on Raceline double beadlocks
Warn bumpers, tire carrier and rockers
Genright fenders, Cage, harnesses, winch
Located in Baltimore county MD, 21131
Jeep is ready to wheel. Could use a fan shroud and header wrap. Just needs a new home. Selling because it just sits, no time to wheel.
asking $7650
Can email or text other pics. Any questions, just ask.
engnmonkey is offline   Reply With Quote Quick reply to this message
Old 05-10-2017, 06:17 PM   #458 (permalink)
Newbie
surfingg19's Avatar
Member # 191978
Lund PN 12003 sun visor for Jeep cherokee
Lund sun visor for Jeep Cherokee 84-01. It is in good shape, will meet within 50 miles of 08234. Asking $200.00
https://southjersey.craigslist.org/pts/6126503963.html
surfingg19 is offline   Reply With Quote Quick reply to this message
Old 05-13-2017, 11:18 AM   #459 (permalink)
Member # 493553
Brand spankin new set of 38" TSL SX's...stickers still on them, never been mounted.
Wheels are recentered H1 double beadlocks, 8x6.5 pattern, new PVC inserts, new o-rings, used set of o-rings, all nuts and a couple spare studs.
$2500
East Haven, VT
Old 05-30-2017, 03:09 PM   #460 (permalink)
Highrolleres's Avatar
Member # 131536
1980 Toyota pickup parts wanted
I need 1980 toyota pickup parts
Complete doors
Fenders
Front bumper and valence
Headlight buckets and bezels
All the out side lights blinkers badges etc
Shift knobs
Gas pedal
4x4 bed flares
Cab vents
Tailgate with hinges and latches
Cap for a short bed
Few dash parts like gauge bezel and that wood grain thing
I'll be at big dogs June 23/25 if anyone has any parts
juggy under construction
Check out my other builds
R.I.P
Will/jeepon1tons
Alex
Highrolleres is offline   Reply With Quote Quick reply to this message
Old 05-31-2017, 10:06 AM   #461 (permalink)
Member # 65801
Hard Tonneau Cover 99' -06' 6.5 Bed
Aluminum folding tonneau cover for 99'-06 Chevy or GMC Full Size Short Bed
Four section fold up both rear and forward sections have new keyed locks
Works fine - seals on hinges have disintegrated over time, meaning it is not water tight. Keeps things dry in light rains, not so much in downpours.
Manufactured by Fold A Cover, parts are readily available (new seals are $20). If it was me I would buy new side rails ($95 for pair) give it a new coat of paint and have essentially a new cover... I would have done this myself, but purchased new cover before I realized parts were readily available..
pictures can be seen in Craigs List Post:
https://york.craigslist.org/pts/6154005564.html
Located in York, PA
$175.00 OBO
Seven -one Seven - 870-nine-eight-seven-zero
I'm pretty sure I can make that...
Jeep itch is offline   Reply With Quote Quick reply to this message
Old 06-05-2017, 09:09 AM   #462 (permalink)
Member # 81613
New 37x12.50x17 Goodyear MTR Kevlar tire $325
Pittsburgh Area
Can get it to Rausch creek June 21-25 2017
ransil is online now   Reply With Quote Quick reply to this message
Old 06-09-2017, 07:23 PM   #463 (permalink)
Member # 10106
Dodge spin-free / Ford d60 locking hub conversion parts
I gathered up these parts to swap onto my 2nd gen dodge but ended up selling the truck before installing them. These are the major parts need to do the conversion with the hard to find knuckles. Parts are in great used shape but assume parts need cleaned, new seals, new bearings, etc.
1997 Ford balljoint dana 60 knuckles (removable brake caliper brackets)
1997 Brake caliper brackets and core calipers
1997 Ford D60 5 bolt spindles
1997 Ford Dana 60 SRW wheel hubs with studs
1997 Ford 30 spline D60 outer stub shafts (+ 3rd extra spare shaft)
$800 cash (trades considered)
Location 18301 East Stroudsburg, Pennsylvania.
TJ/TJ/XJ/XJ/K2500/F350
jon84cj is offline   Reply With Quote Quick reply to this message
Old 06-10-2017, 08:05 PM   #464 (permalink)
Member # 420338
Wanted: Samurai Transfer Case
1999 Dodge 3500 SRW Conversion, NV5600, 4.10s, 35s
2006 TJ on 32s....commuter
jovak is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 01:16 PM   #465 (permalink)
Member # 420338
Originally Posted by D50rockbuggy View Post
Not sureshipping would be worth while but yes I could
Are you near any small airports?
Old 06-12-2017, 05:47 PM   #466 (permalink)
D50rockbuggy's Avatar
Member # 647185
Yea tweed new haven lol
D50rockbuggy is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 07:56 PM   #467 (permalink)
Member # 420338
PM me your phone number or email, thats less than an hour by air
Old 06-16-2017, 09:17 AM   #468 (permalink)
bobbing for fries
billy bones's Avatar
Member # 190574
Ford 5R110W and NP273
I was told these both work well, but have no way to verify, as the engine and body are removed from the chassis. They came from an 07 F250 with a 5.4, around 100k. Listing at core prices, no reasonable offer refused and most unreasonable offers accepted.
5R110W $200
NP273 $100
Will post pics later
If Everyone Is Thinking Alike, Then Somebody Isn't Thinking
billy bones is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 02:10 PM   #469 (permalink)
BattyblueCB's Avatar
Member # 157919
2004 TJ Rubicon 19,521 Miles
4.0 Stock Engine
Standard Transmission
Rubicon Transfercase
Price: 18000
Clean Title in Hand
Built around 3 years ago - Wheeled roughly 12 times.
This rig is low, incredibility stable, and just flat out works.
Has never rolled or flopped.
39” Reds on Raceline Monster Beadlocks (spare Raceline/Irok)
Suspension
14” ORI’S all four corners
Front 3 link
Rear Double Triangulated 4 link
Jonny Joints for link ends
Artec Suspension Brackets
Front Axle 1989 HP 60 ford Fully Gutted and Rebuilt
5.11 Yukon Gears
Spool
35 spline ECGS outers/stock inners
Reid Knuckles
Artec front ram mount & truss
Home made 1350 Drive Shaft
New rotors, calipers, and brake lines.
Full PSC steering kit
Rear Axle 2001 14 Bolt Chevy Fully Gutted and Rebuilt
5.11 Yukon Gears
Spool
Stock Shafts (w/spares)
TMR Shave Kit
Artec Rear Truss & Pinion Guard W/Truss Bridge
Tom woods 1350 Drive Shaft (Believe the pinion is 1410)
Random
Rebuilt Front Frame For Clearance W/2x2x1/4” Box
Summit Radiator Electric Fan with controls
Rebuilt Rear Frame ATX Kit
Flat Belly W/Full Skids
Sits around 19” with 5” up in front and 7” in rear
Fully Adjustable w/ORI’s Have tank and duel ORI gage
Full roll cage
Corbeau Seats 5 Pt Harnesses Bolted to cage
Rear Alum Skins
Rokemen Bumper
Summit Fuel cell w/stock sending unit
Have softtop and windshield (due to some dents around windshield mounts wont fit until straightened out)
Will sell trailer 16’ car trailer elec. brakes $1400.00
BattyblueCB is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 02:14 PM   #470 (permalink)
Member # 157919
4.0 Stock Engine
Price: 18000
Clean Title in Hand
518-six four nine-0388
Suspension
Front 3 link
5.11 Yukon Gears
Spool
Reid Knuckles
5.11 Yukon Gears
Spool
TMR Shave Kit
Random
Full roll cage
Rear Alum Skins
Rokemen Bumper
Old 06-19-2017, 02:35 PM   #471 (permalink)
Member # 135683
1994 Dodge Ram 2500 4x4 V10 motor and trans, truck has 166K on it and engine ran good but trans is stuck in drive, if you put it in park it is park+drive if you go reverse it is reverse+drive so truck sits still in place, neutral is drive and it will go up through gears like normal.
Engine $500-PRICE DROP $450
Trans $SOLD 10/28
Located in Clear Spring MD 21722, Have a skid steer to help load, I would also freight these for $25 gas/hassle fee if you want to do the setup work and all I have to do is drop them at terminal.
350TacoZilla is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 05:12 PM   #472 (permalink)
Member # 225718
looking for a rubicon t-case (241OR) probably a long shot but any leads would be great too
alexbl is offline   Reply With Quote Quick reply to this message
Old 06-30-2017, 08:54 AM   #473 (permalink)
Member # 96278
Still have Phred. Want Galaxie parts.
$3000 and some elbow grease gets you a one ton Bronco.
-Or-
$1500 on rollers. 351, 4 speed, welded 60/Sterling.
And will seperate:
(5) 37/13 Boggers like new. (4) on 16" rims, 5 road miles and 2 wheeling trips. No cuts, tears, plugs. No blems. (1) spare on 16.5" rim, never run. $1500.
Old 07-06-2017, 05:39 AM   #474 (permalink)
Member # 767273
WTB: toyota 8" selectable locker.
-ARB
-Yukon Zip
-FJ 80 / LX 450 E-locker
Looking for a locker to put in my front 8" to get rid of the LSD.
Low pinion or high pinion 3rd welcome.
If you have something that you're willing to part with or know a friend, get ahold of me.
PM me only. I don't browse this thread often.
Thanks.
mat_haas is offline   Reply With Quote Quick reply to this message
Old 07-08-2017, 06:46 PM   #475 (permalink)
Member # 155134
2016 Buggy, lsx, TH400, ATLAS. Located in Belmont NH. Trades considered, contact info is in the add.
https://nh.craigslist.org/cto/6199921992.html
Silver GT is offline   Reply With Quote Quick reply to this message
