Northwest Forsale, Trade, and Wanted. - Page 30 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northwest
Old 02-15-2015, 04:34 PM   #726 (permalink)
Member # 56430
Originally Posted by pcoplin View Post
Looking for one (or two) used BFG Krawler. I blew one open on an older set I'm using for a spare set. 37x12.50r17.
Thanks!
I have a set of 4. Find a friend, and split them up.
:Your Signature: cannot include the words; Your, Signature.
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 02-16-2015, 11:16 PM   #727 (permalink)
Member # 122979
Turbo 400 np203/205
turbo 400 and a good start to a doubler.
th400 has a fresh standard rebuild, standard valve body, no shift kit. Used torque converter.
Th400 - $400
GM np203 range box, make offer
rocklobster87 is offline   Reply With Quote Quick reply to this message
Old 02-19-2015, 06:33 PM   #728 (permalink)
Member # 147891
chevy 63" in springs + fab tech 3" aal and factory overloads with hd 7in lift shackle
5037191526 Portland or
sold
mog-10 is offline   Reply With Quote Quick reply to this message
Old 02-19-2015, 09:00 PM   #729 (permalink)
Member # 40441
Sold
Toyota Tacoma Elocker 3rd. 3.73 gears. Used, had a noisy pinion bearing. It needs pinion bearings.
$400 Open to trades. I could really use a dual case adapter, a decent winch, or??
I also have a Carling E locker switch and the harness for it, both brand new. $20 for the switch, $50 for the harness.
I can ship on your dime. Max cost to ship would only be about 100$
88 SR5 3.4Runner SAS, R151F, locked geared 37s etc.
Samurai project pile
Speed_Racer442 is offline   Reply With Quote Quick reply to this message
Old 02-20-2015, 12:22 PM   #730 (permalink)
Member # 147891
parting out 1995 gmc jimmy same as s10 blazer it has a bad trans , w code vortec motor runs it has a factory code g80 limited slip differential and 3.73 gears drum brakes . I will pull parts. call or text for parts
Portland or
5037191526
Old 02-22-2015, 09:20 PM   #731 (permalink)
78bronco460's Avatar
Member # 9152
44" TSL's on H1 Beadlocks $1550
https://www.pirate4x4.com/forum/axles...l#post30447098
78bronco460 is offline   Reply With Quote Quick reply to this message
Old 02-23-2015, 11:53 PM   #732 (permalink)
Member # 220112
I'm after a set of reverse cut 4.88's, master install, a locker, and high steer arms for a HP44. Knuckles are GM, though I don't think it matters.
YJ on leaves and 5 ton. . . . . . . . . . . .jack stands
Wombat Ranger is offline   Reply With Quote Quick reply to this message
Old 02-24-2015, 12:40 PM   #733 (permalink)
Member # 36782
Daily driver/ Wheeler/ Crawler for sale or trade
1991 Toyota 3rd Gen Extra cab SAS 2rz swapped ARB's Hi Pinion Etc.
https://www.pirate4x4.com/forum/vehic...rz-8500-a.html
1991 Toy extra cab DD/Wheeler with a 2RZ!!!
Formula Toy #024 has a few scratches!!!
WRANGLER BOB is offline   Reply With Quote Quick reply to this message
Old 02-26-2015, 09:30 PM   #734 (permalink)
Member # 98174
1 BFG AT 35x12.5 tire mounted on a 16.5" rim. Was a spare to a traveall I recently sold. Good quality rim and the tire has a lot of tread. 120.00 OBO. Located in Spokane. PM me if any questions.
[QUOTE=Tigerchief;14998311]You should let people die when they're asking for it.
Don't take it personally.[/QUOTE]
71durabakscout is offline   Reply With Quote Quick reply to this message
Old 02-27-2015, 07:04 PM   #735 (permalink)
nwx
Member # 102534
Toyota 5" Lift Springs $550
HERE is the Craigslist link.
Sold
nwx is offline   Reply With Quote Quick reply to this message
Old 02-27-2015, 08:59 PM   #736 (permalink)
brandon_halter's Avatar
Member # 145505
Ford 203/205 and np435 trans trades for Toyota parts
I'm only asking $450, I don't , I don't have the adapter to mate the 203 to the 205
I've got
Ford married np203 range box, and married np205 transfercase. Both were mated to manual transmissions. Np205 is currently mated to a np435 manual trans (4sp )with granny gear.
The trans case works but is cracked and I have a new case for it just needs internals swapped!
I have a brand new bomb proof mount for the rear of the np205 case for mounting up high for flat belly.
!!!!!!!!!!( I have not yet purchased the adapter to mate the 203/205 together, JEDS maching had them for around $500 the last i looked, I've aborted my project and need to sell !!!!!!!!!!!
$450 Obo, includes 203 range box, 205 t-case, 4sp manual transmission with new trans housing.
Seperatly !
Np203 range box $200 Obo
Np205 t-case $250 Obo
Np435 trans with new case $150
Also have another Np435 trans with fixed yoke, from a divorced setup.
In awesome shape with tcase shifter yada yada...
trades considered. Toyota crawler parts!
- w56 trans with top shift t-case. Or
- Toyota dual case set up Or
- top shift t-case with 4.7 kit
(4) 3/4" hiems with bungs/ jam nuts 2LH 2RH thread..
Txt for pics 503-877-0318
yupp!!
brandon_halter is offline   Reply With Quote Quick reply to this message
Old 02-27-2015, 09:18 PM   #737 (permalink)
Member # 145505
Originally Posted by Power Giant View Post
17" Inner Air Locks- double bead locks. Very good condition. Have 2 brand new inner tubes for them. Run low air pressure in your tires with no risk of de-beading them while crawling. $250
17" x 9" Allied steel wheels with a 2 3/4" backset. 6 lug, Toyota pattern. There are rock rings on the outsides of the wheels. They're somewhat scratched up from wheeling, but are still in good shape. $250
I'm willing to drive as far south as Moscow, ID, as far west as Spokane, WA, and as far east as Kellogg, ID.
Are these still available?? I was just in the Laclede, sandpoint area this past 2 weeks, dang. . I'll prob be back up there soon or going through Spokane to Montana in the next month.
yupp!!
Old 02-27-2015, 09:39 PM   #738 (permalink)
rennat_2006's Avatar
Member # 151321
I've got
Seperatly !
Pics of np205 please. You can text to 509 947 6728
2000 zr2 blazer-hp d60/ 06 14blolt/ lockers/4.88's
rennat_2006 is offline   Reply With Quote Quick reply to this message
Old 03-04-2015, 02:26 AM   #739 (permalink)
Member # 15386
Dodge NP208 with @60K miles. $250 Previous owner rarely even put it in 4x4 because first his unit bearing vacuum front axle went bad, then the TBI went south, so it got parked for years, then parted. Bought it as a back up for my '86 Ramcharger (long ago sold) then I kept it to do a 727 swap in my '73 Jeep because it's RH drop and fixed yokes.
23 spline input and fixed yoke outputs. No shifter.
Jim Blair, Seattle, WA
Build that Jeep boys, cuz it ain't gonna build itself!
carnuck is offline   Reply With Quote Quick reply to this message
Old 03-04-2015, 09:52 PM   #740 (permalink)
Member # 554578
Something's got to go
2004 YUKON XL 5.3 V8 LEATHER
Selling the family yukon. Bought a excursion.
8runna8 is offline   Reply With Quote Quick reply to this message
Old 03-04-2015, 10:05 PM   #741 (permalink)
Member # 236378
1995-2004 Tacoma Rear Plate Bumper
It is a brand new never installed 4XInnovations Tacoma bumper. It came bare steel and I painted it black so you even get paint
These are $650 brand new plus shipping.
I'm selling it for $620
This is pick up only in Forest Grove or Beaverton
This is the manufacturer's web site.
Loud Al is offline   Reply With Quote Quick reply to this message
Old 03-08-2015, 11:56 PM   #742 (permalink)
Member # 188309
jeep tf999. less than 1k on re build. new torque converter. $400
np241c with sye and clocking ring. $200
bocephus01 is offline   Reply With Quote Quick reply to this message
Old 03-14-2015, 05:41 AM   #743 (permalink)
Member # 192711
Looking for some unmolested H1 rims. I am near Joint Base Lewis McCord. Pm me if you got any.
[SIZE="3"]https://www.facebook.com/dr.k.motorsports/[/SIZE]
kayjef is offline   Reply With Quote Quick reply to this message
Old 03-15-2015, 02:09 PM   #744 (permalink)
Member # 165757
sharing; new toyota group in idaho on facebook
sharing; new toyota group in idaho on facebook.
this might help for finding parts. https://www.facebook.com/groups/oldschoolyotaparts/
YOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 03-20-2015, 10:30 PM   #745 (permalink)
Member # 122979
wanted: compressor
looking for used a 60-80 gallon 230v 3-5 hp compressor to get me by for a while.
have cash and truck
Old 03-30-2015, 04:44 PM   #746 (permalink)
Member # 220112
ZF-6 out of a '99 7.3 F350 with drivelines, shifters, cooler lines, crossmember etc. 271 still attached. Intercooler from same truck also for sale.
7.3 ZF6/tcase and intercooler
AAM axles out of an '07 Mega Cab, 3.73 Limited slip. 2nd rear end with a bad spider in the LSD as well.
2007 Dodge Cummins Axles
Old 03-30-2015, 08:17 PM   #747 (permalink)
Member # 102813
Complete rear axle minus the third out of a Toyota FJ80.
$100
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 03-31-2015, 12:51 AM   #748 (permalink)
bretgilk's Avatar
Member # 211155
$100
Do you know anyone selling a fj80 third member>?
39.5 Iroks + Dual Cases + Spooled F/R + 529s + Chevys + 3rd Gen RUF + Tubed Front + Doved F/R
bretgilk is offline   Reply With Quote Quick reply to this message
Old 04-03-2015, 08:36 PM   #749 (permalink)
Member # 102813
Pm sent
[/COLOR]
Old 04-04-2015, 01:27 AM   #750 (permalink)
CORNFED's Avatar
Member # 2557
FJ80 front - complete $600
Team Tetanus Racing
68 Chev 4400 Blazer buggy
CORNFED is offline   Reply With Quote Quick reply to this message
