Northwest Forsale, Trade, and Wanted. - Page 37 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northwest
Old 10-31-2016, 05:26 PM   #901 (permalink)
Member # 14087
Originally Posted by brokenparts View Post
Also have a 87 Ford F350 with a high pinion kingpin dana 60, 10.5 rear, 460 big block, tranny, xfer case... It does not currently run but the fella I picked it up from said he though it was just the firewall solenoid. My plan was to use the parts from it for the FJ55.
$1200 for it... or $1500 for both rigs.
Do you still have the Ford?
balzackks84 is offline   Reply With Quote Quick reply to this message
Old 10-31-2016, 05:34 PM   #902 (permalink)
brokenparts's Avatar
Member # 71152
Send a message via AIM to brokenparts Send a message via MSN to brokenparts Send a message via Yahoo to brokenparts
Sorry it sold quite awhile ago.
I am offended by reality all the time.
brokenparts is offline   Reply With Quote Quick reply to this message
Old 11-08-2016, 06:08 PM   #903 (permalink)
Member # 141944
edit- sold.
Also have NIB used for mock-up Fox 2.5 12" emulsion coilover shocks x2 bought wrong part number, standard valving my loss your gain $850.
'05TJLWBRUBY is offline   Reply With Quote Quick reply to this message
Old 11-10-2016, 06:28 PM   #904 (permalink)
toolegit86's Avatar
Member # 655001
1978 dually 3+3 crew cab 4x4
location is tri cities wa
1978 dually 4 door crew cab long box
454 th400 205
d60/d70
the truck is clean for the year little rust and is complete the trucks been sitting for a while but fired right up.
the carb needs replaced and it needs ran. has some old fuel.
interior is clean and complete dash is not all cracked and its actually uncut still has the original tape player. tires are good. everything seems to work
picked it up to build
looking for 3k obo
I will be continuing throwing parts at it so the price may change as I go.
possible trade for jeeps or willys maybe a ext cab truck
97 tj 1ton 40s lsx turbo
toolegit86 is offline   Reply With Quote Quick reply to this message
Old 11-18-2016, 06:49 PM   #905 (permalink)
Member # 117809
Looking for a suzuki sidekick 3 speed auto 4x4.
3605297571
FToy F011
chrisstewart36 is offline   Reply With Quote Quick reply to this message
Old 11-26-2016, 05:21 PM   #906 (permalink)
Member # 718266
Canback soft top for first Gen 4runner FOR SALE $750
Pnw_4runner is offline   Reply With Quote Quick reply to this message
Old 11-28-2016, 07:42 PM   #907 (permalink)
Valley Rock's Avatar
Member # 208306
WTB FORD 203, MARRIED, 31 SPLINE INPUT FOR DOUBLER
Just like title says, need a Ford 203, married unit, 31 spline, only need front part for making a doubler .
Im in Southern OR Medford area, near I-5 exit 33 .
PM if you have one you dont need .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 11-30-2016, 01:13 AM   #908 (permalink)
Member # 716194
WANTED: dodge ram 2500 transmission
looking for a dodge ram 2500 tranny +transfer case for behind a 5.9 gas engine. auto or manual (with pedal assembly, clutch, flywheel, etc.) i believe its a 47re or 48re
..pm me
Dopepope is offline   Reply With Quote Quick reply to this message
Old 12-15-2016, 06:16 PM   #909 (permalink)
Member # 141944
Fox 2.5 12" emulsion coil overs
Have an ad on CL at $850 cash- Pirate price $800. can email pics if requested.
Qty 2 - Fox 2.5" Coil-Over Emulsion Shocks - 12" Travel 50/70 standard valving FOX-980-02-249 $961.09 after tax with free shipping from Poly Performance. These are new in box. Removed to mock up and realized I ordered wrong part number. My loss your gain save $111.09. $850.00 cash.
Best of Luck,
Mike
Old 12-21-2016, 02:05 PM   #910 (permalink)
Member # 4557
Send a message via AIM to muddogbob
I'm looking for a 14 bolt axle. C&C preferred. Gearing doesn't matter, unless it already has 4.88s, which would be a bonus.
Thanks
Bob
'90 FJ62
LQ4, 4l80-E, 203/Split Case, 38" MTRs
muddogbob is offline   Reply With Quote Quick reply to this message
Old 12-21-2016, 04:32 PM   #911 (permalink)
rennat_2006's Avatar
Member # 151321
I have one minus the gears and carrier. You can have it. Im in kennewick and it is a c&c
2000 zr2 blazer-hp d60/ 06 14blolt/ lockers/4.88's
rennat_2006 is offline   Reply With Quote Quick reply to this message
Old 01-03-2017, 10:01 PM   #912 (permalink)
Member # 4557
Got the 14 bolt housing/hubs (thanks Tanner). Does anybody have a set of 14 bolt shafts?
'90 FJ62
Old 01-03-2017, 10:14 PM   #913 (permalink)
Member # 151321
You bet.
Local pick n pull? Should be easy to find
Old 01-08-2017, 08:49 PM   #914 (permalink)
Member # 50732
T200 9k Winch Sale or Trade
Have a Thor T200 9000lb winch. Worked when pulled 10 years ago, has been stored inside, comes with electric cables and winch cable (winch is electric)
Would like to trade for a T15 3-speed transmission.
But cash would work as well
dietoy is offline   Reply With Quote Quick reply to this message
Old 01-10-2017, 04:37 PM   #915 (permalink)
Member # 133504
2500 burb
I am looking for a 2003 and up 2500 8.1 suburban 4x4 or yukon xl. trying to spend less than 8kl. If you know of one or know where to find one i would appreciate it!
shift_slide is offline   Reply With Quote Quick reply to this message
Old 01-11-2017, 01:16 AM   #916 (permalink)
Member # 50732
T200 9k Winch Sale
Picked up a T15. Still have the winch. $200
Would trade for a Dana 30 or Dana 44 front axle with 3.07's and lockout hubs
Old 01-21-2017, 12:35 PM   #917 (permalink)
Member # 598082
2004 rubicon Dana 44 front housing, axle shafts etc
I have a front Dana 44 out of a 2004 Jeep Wrangler rubicon. This is the housing which is straight, axle shafts which are in perfect shape, new set of 5.13 gears. No locker or other parts. I would like $800 obo for everything or make reasonable offer. I would consider parting out if nobody is interested in the whole thing. I can deliver to Camas wa next weekend for no additional cost.
some bronco guy is offline   Reply With Quote Quick reply to this message
Old 01-21-2017, 01:49 PM   #918 (permalink)
Member # 151321
Drw hubs off of a 1995 ford d60 front axle. Was ball joint axle. Hubs and rotors. $75 obo in kennewick
Old 01-27-2017, 12:07 PM   #919 (permalink)
86chevyjoe's Avatar
Member # 128588
Send a message via AIM to 86chevyjoe
looking for th400 4x4 GM version. need a rebuildable core at the very least, cheaper the better
I like to snow wheel
86chevyjoe is offline   Reply With Quote Quick reply to this message
Old 01-27-2017, 12:43 PM   #920 (permalink)
Corey Young's Avatar
Member # 21622
What t-case? The rear shaft lengths are different.
Old 01-27-2017, 05:35 PM   #921 (permalink)
pitbullcruiser's Avatar
Member # 193971
I have 4 used black steel wheels, Toyota lug pattern, 15". $100, I am located in Renton WA.
Tom
ECORS Toyota 779
ULTRA4 Toyota 4653
pitbullcruiser is offline   Reply With Quote Quick reply to this message
Old 02-02-2017, 10:37 AM   #922 (permalink)
Member # 125894
Anyone in the area sell Military 37 x 16.5 BFG's ?
1Bad67 is offline   Reply With Quote Quick reply to this message
Old 02-03-2017, 06:48 AM   #923 (permalink)
86chevyjoe's Avatar
Member # 128588
passenger drop np241
Old 02-03-2017, 07:29 AM   #924 (permalink)
Member # 21622
27 or 32 spline?
Old 02-03-2017, 08:04 AM   #925 (permalink)
Member # 226216
Tom
Pictures of rims? How wide are they? Back spacing?
Thanks
thefishguy77 is offline   Reply With Quote Quick reply to this message
