Expedition Tundra Long Travel Suspension! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Vehicles and Trailers For Sale
Old 07-21-2012, 09:03 AM   #1 (permalink)
Fab Junky
bark beetle's Avatar
Member # 147257
Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold Sold!
New Lower Price $18,250 OBO or TRADE, Must sell to keep the C3 going!
Located in Los Alamos, NM, delivery options with non-refundable deposit
Contact Jonathan, 505-231-0250
Need funds for new K30 Crew Cab Project let me know what you are interested in trading.
Build Thread (5 years in the making!)
This truck is a one of a kind, build for exploring in comfort and style! Works extremely well in the desert, mountains, highway, DD. Also a great work truck, still hauls plywood, lumber, tools, 20' steel/pipe, etc with the slip in receiver racks in the front, headache rack, and rear.
Ford Raptor Killer!
More travel, better shocks, better skid plates, no bent frames and way cheaper than a Raptor!
2007 Toyota Tundra SR5 Double Cab
Just rolled 50k miles
General:
Black cloth seating with split bench front and rear, center console on front bench makes it just like a 5 seater except shifter is on the steering column. Icon race radio, stock single disk CD with MP3 jack, PS, PB, CC, Tilt, AC, PW, PD, PM, Heated extendable towing mirrors, and sliding rear window
Body:
Glassworks flared front fenders.
Engine:
5.7 V8 stock with Flowmaster 50 series big block cat back system. Optima Yellow Top deep cycle battery in Ruffstuff Specialties battery cage. AIP bypass system has been modification to prevent check engine and limp mode from occurring. ABS modified to operate on a switch to allow disablement for offroad driving. Using 0W20 Mobil 1 fully synthetic oil in the engine.
Transmission & drivetrain:
Stock 6 speed automatic with 4.30 differential gearing, stock rear driveshaft, custom 4340 heat treated steel front axle shafts with stock CV's. Rear brake calipers have been flipped to allow long travel shock location without caliper contact. The rear parking brake system was removed to allow the caliper swap. System can easily be reinstalled with a forward shock location. Differentials have 85w90 Valvoline fully synthetic differential oil.
Front suspension:
Total Chaos Uniball long travel system with custom built shock
towers to allow the use of Fox racing shocks. Shocks are 8" travel 2.5 remote reservoir coilovers with 3" ID Eibach springs, 8" travel 2.5 two tube piggyback reservoir bypass shocks with quad wrap limit straps, and stainless steel extended brake lines. Front suspension travel is limited to 14" of travel to keep CV angles and tie rod angles sane (reliable).
Rear suspension:
Deaver custom built long travel leaf springs, custom extended tube shackles, 16" travel Fox 2.5 two tube piggyback reservoir bypass shocks and 4" travel Fox 2.0 hydraulic bump stops used for a 15.5" of usable travel limited with quad wrap limit straps and stainless steel extended brake lines. Spring under leaf spring conversion with high clearance Ruff Stuff Specialties spring perches.
Chassis:
Custom front tube bumper with 2" receive mount in front bumper to allow winch or tubing/construction rack Skid plates include 1/8" aluminum upper skid plate and 1/4" aluminum lower skidplate on the front bumper, 1/4" aluminum engine/transmission skid plate and 1/8" aluminum gas tank skid plate for through driveline protection. Rear frame section has been reinforced and triangulated to reduce chassis flex. Wheelbase is about 185”.
Custom Expedition Flatbed:
Full 6' length, much better than a pickup box for motorcyles, camping gear and offroad equipment. Removable rails that double as motorcycle ramp when bolted together or sand/bridging ladders when offroad. Aircraft style tie down tracks located in bed with full length tie down rails along sides of bed. D shaped tie down brackets on cab end of bed, good for securing the dirt bike.
Removable 1/2 plywood for trash/parts hauling to save aluminum bed. Custom tire carrier configured under the flatbed. LED tail lights and full towing provisions. Single gas can carrier on driver side for Scepter military jugs and dual Scepter water can carrier on passenger side. There is also a removable center section built into the flatbed for a sub bed tool box. "Stubby" headache rack that has 1.5x1.5 pockets to allow removable
headache rack or construction rack. Mud flaps to stay street legal but can be easily removed when offroad.
Tires/wheels:
5 x 315/70R17 (35's) BFG A/T KO tires
5 x Rebel Racing 17x8 black aluminum wheels
5 tire rotation performed with oil changes
bark beetle is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 07:21 AM   #2 (permalink)
Fab Junky
Member # 147257
Tt
Old 07-23-2012, 07:38 AM   #3 (permalink)
Fab Junky
Member # 147257
Tt
Old 07-24-2012, 07:40 AM   #4 (permalink)
Fab Junky
Member # 147257
Tt
Old 07-24-2012, 02:01 PM   #5 (permalink)
Member # 22726
Bump for a nice ride.
The more things you own, the more they own you!
[B][SIZE="3"][COLOR="Red"]Marlin Crawler fan boy.
Trail Tough Rocks[/COLOR][/SIZE][/B]
mannysouza is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 03:06 PM   #6 (permalink)
Member # 3007
LUST! Good luck with the sale
Bones is offline   Reply With Quote Quick reply to this message
Old 07-25-2012, 09:07 PM   #7 (permalink)
Fab Junky
Member # 147257
TT, thanks for the compliments
Old 07-27-2012, 11:58 AM   #8 (permalink)
Fab Junky
Member # 147257
New lower price!!!!!!!
Must sell, need cash to finish my K30 nicknamed C3. I'm building a thread on that truck right now. Look for it in the Chevy section.
Only $19,750! There's over $10,000 in suspension parts on this truck, labor not included.
Old 07-28-2012, 08:36 AM   #9 (permalink)
Fab Junky
Member # 147257
Why Tundra has to sell
If you want to see why I am selling the Tundra, check out the build thread I just loaded up yesterday.
https://www.pirate4x4.com/forum/showthread.php?t=1081277
Old 07-29-2012, 07:36 PM   #10 (permalink)
Fab Junky
Member # 147257
Tt
Old 07-30-2012, 08:53 PM   #11 (permalink)
Fab Junky
Member # 147257
Tt
Old 07-30-2012, 10:39 PM   #12 (permalink)
Member # 209488
I keep coming back and looking at this truck. I don't think the truck would pass yearly inspection here in TX without the emergency brake. Do you have a yearly inspection in NM? Any way to arrange things so you have a working emergency brake without throwing out the long travel shocks?
EDIT: Just noticed you said shocks could be retained with a forward shock mounting location. Any downside to this? Why did you decide not to mount them in the forward position?
dgurley2000 is offline   Reply With Quote Quick reply to this message
Old 07-31-2012, 09:08 PM   #13 (permalink)
Fab Junky
Member # 147257
E brake
I do not have a yearly inspection or even smog here, gotta say that is awesome. Mounting the shocks on the forward side of the axle makes the shock shafts susceptible to damage from rocks and sand flying off the front tires. That is why the Ford Raptor has those plastic shaft guards. Guards could be made, I have made them in the past and they work. But for what I was doing, putting them behind the axle was a better solution because it also moves more of the weight to the back of the truck for a little better weight distribution. I have all the hardware and cables to put it back. Not sure if your inspection is visual or actual function test? Shock mounts would have to be cut and flipped left for right and new upper shock mounts would need to fabricated as well. This would be about a days work and I could negotiate this work with a non-refundable deposit.
Old 08-03-2012, 09:22 AM   #14 (permalink)
Member # 3140
can you give us more info on the AIP bypass mod? I am trying to figure out if it will still pass CA smog, specifically the visual inspection.
Toy truck with some poop pipe.Some Marlin, PolyPerformance and Sky junk glued on here and there.
pickeledpigsfeet is offline   Reply With Quote Quick reply to this message
Old 08-03-2012, 10:20 AM   #15 (permalink)
Fab Junky
Member # 147257
AIP Bypass
I doubt they would see the bypass. I integrated the wiring with the factory harness running out of the fuse panel and mounted the relay on the firewall on the passenger side. It certainly doesn't cause any codes on the computer if they plug into the port and check that. Here is a link to the very long thread on Tundra Solutions that led to the creation of this mod:
http://www.tundrasolutions.com/forum...ation-circuit/
Here is a link to the pdf instructions that were generated on how to do this mod:
http://www.tundrasolutions.com/forum...erride-1.1.pdf
I can post a picture of the engine compartment if that helps.
Old 08-05-2012, 06:51 PM   #16 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-07-2012, 06:20 PM   #17 (permalink)
dukguy's Avatar
Member # 29450
Can you send me some pics.
dukguy is offline   Reply With Quote Quick reply to this message
Old 08-07-2012, 07:01 PM   #18 (permalink)
Fab Junky
Member # 147257
Pictures Back
Sorry everybody, I messed with my photo albums which destroyed all the links. Got them back now.
Old 08-08-2012, 09:46 PM   #19 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-09-2012, 08:28 PM   #20 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-10-2012, 08:30 PM   #21 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-11-2012, 07:33 PM   #22 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-12-2012, 08:21 PM   #23 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-14-2012, 08:57 PM   #24 (permalink)
Fab Junky
Member # 147257
Tt
Old 08-15-2012, 06:45 AM   #25 (permalink)
Member # 3007
Kills me I just bought a new vehicle. Seems like a great buy for the right person. Wish I could take it off your hands.
