Willys tube buggy, Linked, ORI's, RCV's etc - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Vehicles and Trailers For Sale
Old 12-08-2014, 05:36 PM   #1 (permalink)
Member # 135104
Hey guys, hate to do this but I'm posting my Willys Buggy up for sale. I'm wanting to get into a similarly built Cherokee. Something I can use as a backup vehicle and still go anywhere I want but with a top and doors.
Specs
Engine:
Chevy 4.3 V6
Bored .030 with 10.5:1 pistons
Stock Rods and crank polished
Double Roller Timing Chain
Comp Cam 270HR
Edelbrock Valve springs, push rods, retainers, locks, push rod guide plates
Comp stainless roller rockers
Stainless steel undercut 2.02/1.60 Valves
Mild port work done to heads
Edelbrock TBI performer intake manifold
Sanderson Headers w/ 3" magnafow exhaust
Custom tuned PROM in ECM
FULL MSD ignition system with 6A box, MSD coil, MSD plug wires, etc
Transmission:
Ford NP435
T-case:
Scout Dana 20
Tera-low 3.15:1 gear set
Advance Adapters 32 spline heavy duty output
Twin Sticks (can do front digs)
Front axle:
Low pinion Dana 44
4.88 G2 Gears
30 spline Detroit Locker
RCV shafts 300m inners, bells, stubs
RCV 300m Drive Slugs
Chevy High Steer knuckles, brakes, wheel hubs, etc
Driveshaft has 1310 yokes with 1.5" OD .25" wall DOM tube
Rear Axle:
Low pinion Dana 44
4.88 G2 Gears
33 Spline Detroit Locker
Dutchman 4140 Crom-moly shafts (these are brand new, one ride on them)
Driveshaft has 1310 yokes with 2" OD .25" wall DOM tube
Front Suspension:
3 Link with Panhard
All built in 3 link calculator, excellent geometry
7/8 ruff stuff heims in 2" OD .25" Wall DOM Lowers
3/4 ruff stuff heims in 1.5" OD .25" wall DOM Upper and track bar
18" Travel ORI ST struts (yes it can use ALL of it)
Rear Suspension:
Trianglulated 4 link
7/8" ruff stuff heims in 2" OD .25" wall DOM lowers
3/4" ruff stuff heims in 1.5" OD .25" wall DOM uppers
14" Travel ORI struts
Steering:
Full PSC system with high volume pump, reservoir, cooler, 1.5" Assist ram. Saginaw "Series 9" 4 bolt box
Wheels/tires:
15x8 steelies with weld on "Willys" style W bead locks
38x12.50x15 TSL's
Other Doo-dads:
All aluminum (no trouble prone epoxy) Northern radiator
3300 CFM flex-a-lite fan on a thermostat
Full On-board air with York compressor, rockers are air tanks
Front M8000 warn winch
Rear Chicago electric 8000 LB winch (has a solenoid that's been acting up)
Ammo Box electronic control panel between seats with all switches
Rough Country 20" Cree LED camo light bar
Line Lock for parking brake
Original Willys Dash, cowl, fire wall, hood, and tail gate (well half of it lol). Original 1941 GPW Grille
Chassis has YJ frame rails that were straightened and narrowed and then back halved.
The rest is all 1.5" or 1.75" tube. Chassis is designed to mimic the lines of a Willys obviously. Its just a tube chassis with 18 GA sheet metal skins.
Right now the left front strut has a blown internal seal, just noticed it. I'm pulling it off to get it fixed by ORI. Or I can call them and have it fixed after you get it. It is under warranty.
I do have a clean title. It is registered and insured as a 1946 Willys CJ2A.
Located in Chattanooga, TN but can help with delivery for a small fee. For more information call or text Tyler at 423-six one nine-4085.
$12,000
Build Thread:
https://www.pirate4x4.com/forum/jeep-...tty-build.html
Just a Willys buggy on a Tube chassis, ORI struts, RCV Shafts, a built 4.3, NP435, & a Bling D20...
Team Willys is offline   Reply With Quote Quick reply to this message
Old 12-08-2014, 08:01 PM   #2 (permalink)
51 Jeep Willys's Avatar
Member # 29208
Bad ass willys man. GLWS
Im just a flat biller with flipped up tow mirrors
51 Jeep Willys is offline   Reply With Quote Quick reply to this message
Old 12-09-2014, 06:55 AM   #3 (permalink)
Member # 122757
Send a message via Yahoo to kf_chris
Bump for a really nice guy who does GREAT work!
kf_chris is offline   Reply With Quote Quick reply to this message
Old 12-09-2014, 02:01 PM   #4 (permalink)
Member # 135104
Tuesday evening Bump...
This buggy has an excellent power to weight ratio and is perfect for tight technical trails such as Lion's Den at Harlan KY or Rattle Rock at Windrock.
It will do Lions Den from start to finish in 1st gear in less than 3 minutes without ever pushing in the clutch. Its a VERY capable, lightweight rig.
Old 12-09-2014, 03:11 PM   #5 (permalink)
Member # 194346
Have any current pics of it? Noticed that most of these pics were from 2010 it looks like.
dhallmark is offline   Reply With Quote Quick reply to this message
Old 12-09-2014, 04:54 PM   #6 (permalink)
Member # 135104
Unfortunately, I am usually driving it, not taking pictures of it, so I don't have much. We just got back from Moab with it and a buddy of mine took some pictures of it so I'll see if he can upload them. They are only a week old so that would be pretty current lol.
Actually, its still in very good shape. It could use a new coat of paint but honestly its not beat up. The passenger side has got a few bruises, but nothing bad. Right front fender tube is slightly tweaked from a flop, the passenger cowl has a small dent from the tree on Lion's Den, and there is a scrap behind the door opening from a huge rock on Wrecking Ball in Johnson Valley. But the cage is all straight, no bent tubes or anything like that. Lower links have some loving but heims are all perfect and it needs absolutely nothing (other than that strut fixed) to go wheeling.
Both axles just gone through. Front axle shafts have 2 rides on them, rear axles are literally brand new. Rode 2 days in Moab on easier trails (no ledges or high stress situations). Driveshafts were just serviced and everything is good there. New rear output yoke and u-bolts on T-case. Light bar is brand new, just installed it before Moab just in case we got caught out at night. It hasn't been on more than a minute at most. Just turned it on to make sure it worked.
Old 12-09-2014, 07:25 PM   #7 (permalink)
Member # 65983
this rig flat goes anywhere. if the spare change were in my pockets it would be in my garage already. will run through lions den at harlan without even pushing the clutch in.
just driving a camry.....
xjdoug is offline   Reply With Quote Quick reply to this message
Old 12-10-2014, 11:53 AM   #8 (permalink)
94redyj's Avatar
Member # 399522
ARE YOU INTERESTED IN ANY TRADES?
94redyj is offline   Reply With Quote Quick reply to this message
Old 12-10-2014, 01:27 PM   #9 (permalink)
Member # 135104
Eh, possibly.
I'm really looking to get into a similarly built Cherokee. Not interested in anything Renix though. I'm pretty particular too. I don't cut corners in the stuff I build, and if I did trade, I would expect the same out of the traded vehicle.
Old 12-11-2014, 11:53 AM   #10 (permalink)
94redyj's Avatar
Member # 399522
what about 1994 jeep wrangler with a few upgrades plus cash?
Old 12-11-2014, 11:55 AM   #11 (permalink)
94redyj's Avatar
Member # 399522
whats the length of your wheel base?
Old 12-11-2014, 03:35 PM   #12 (permalink)
Member # 135104
Wheel base is 103". It could easily be stretched out more in the rear. Could go to around 106-108 without much work.
As far as trades, I'm open for ideas, but I need details. Asking to trade for a Jeep without giving any description doesnt exactly excite me lol!
Old 12-12-2014, 07:34 AM   #13 (permalink)
94redyj's Avatar
Member # 399522
1994 Jeep Wrangler
front axle D44 with Detroit Tru-Trac, Yukon 4.56 gears, Chevy knuckles flat top for custom highsteer, Tattons drive shaft 12" slip.
rear axle 9in with Yukon Grizzly, Yukon 4.56 gears, disc brake conversion, Tom Woods drive shaft.
suspension
front SOA Deavers military wrap with reverse shackle
rear SOA Rubicon Express 1.5 (sprung over spring)
tires 36 13.50 15R Iroks
motor is all stock 4.0 inline 6 w/ AX15 5 speed, 231 transfer case w/ SYE, heater NO A/C,
soft top
add a few bars to the cage to beef up
Rough Country 9500lb winch (brand new) used once
stretched the front axle a little to make wheel base 97"
Smitty Built tire carrier
Old 12-12-2014, 09:54 AM   #14 (permalink)
Member # 135104
I'm gonna pass on that. Built this to get away from leaf springs. Not interested in going backwards. If I get a Cherokee it'll end up linked front rear.
Issue is we all know that jeeps are 50 cents on the dollar when selling. So for me to trade for something that's not close to what I'm looking for will cost me way more in the long run because I'm gonna have to invest a lot more to get where I want to be.
Old 12-12-2014, 10:12 AM   #15 (permalink)
Member # 448170
Trade?
Possible trade + Cash?
1998 TJ buggy 104" WB
Atlas 5.0,
Fairly new 37" BFG sticky's, Spyderlock bead locks (Have Rock Rash),
Triangulated 4 Link Rear, Modified 4 Link Front
Dana 44 front with new Yukon 4.88's, Detroit locker, Yukon chrome molly shafts with super joints, Motive Gear Axle Tube Seals, Alloy USA Ball Joints
Ford 8.8 rear, Yukon chrome molly shafts, 4.88's, Yukon Grizzle locker, New Brakes
AX5 5spd Transmission and 2.5L 4 cylinder (Recent tune up),
AGR box with Rock Ram hydraulic assist,
Fairly new 9500lb winch with synthetic rope line (new 92'x3/8 robe) and wireless remote,
New Curries Progressive 4" Springs all 4 corners with new RS9000XL (36" Rear, 28" Front) shock with limit straps, New Optima Yellow Top Battery, New Dash, New 4 Pt Harnesses (Have anti Submarine Belts), New SS Brake Lines all four corners. 2 New fire extinguishers mounted.
The buggy its light and nimble its like a little goat its very impressive. Clean Title in Florida
Capt911 is offline   Reply With Quote Quick reply to this message
Old 12-13-2014, 11:00 AM   #16 (permalink)
Member # 135104
Just throwing this out there, I do also have a windhsield for it. It needs a new piece of glass but its a real Willys frame that has been modded to fit the added slope of the cage. Make the jeep look like its doing 100 mph while sitting still.
Old 12-15-2014, 04:06 AM   #17 (permalink)
Member # 135104
Monday morning bump!
Old 12-16-2014, 05:26 PM   #18 (permalink)
Member # 135104
Pulled front strut off and sent it back to ORI. They will have it tomorrow and I should have it back in a couple of weeks!
Old 12-24-2014, 03:33 PM   #19 (permalink)
Member # 135104
Got the strut back from ORI today. I should have time to get her rolling again this weekend. Surprised there hasn't been more interest in this. Lots of trade interest but not what I'm looking for yet. I've literally got almost 3 times asking price invested in this rig!
Old 01-03-2015, 07:47 PM   #20 (permalink)
Member # 135104
Strut is back on and the Jeep is now ready to wheel again!
Old 01-12-2015, 12:16 PM   #21 (permalink)
Member # 135104
Monday bump!
Old 01-21-2015, 09:51 AM   #22 (permalink)
Member # 135104
To the top!
Old 01-21-2015, 11:34 AM   #23 (permalink)
Member # 232595
sweet rig, wish we were closer, maybe then we could work out a deal...
https://www.pirate4x4.com/forum/jeep-...-goldrush.html
i actually have a 4 link kit for the rear too...
JTPDrift.com
jtpxjc is offline   Reply With Quote Quick reply to this message
Old 01-22-2015, 03:08 PM   #24 (permalink)
Member # 135104
I love that color XJ. Its actually one of my favorites. I'm looking for something a little more hardcore, but still has to be streetable. Minimum of HP44/8.8 axles. Preferably not full width but not completely against it. Doesn't need to be daily driveable, but if I need to hit the interstate it has to be reliable enough to drive a few hours.
Old 01-23-2015, 03:52 AM   #25 (permalink)
Member # 135104
Friday bump! Spring is on the way, perfect warm weather wheeler!
