79 Toyota One Ton w/ 4.3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Vehicles and Trailers For Sale
Old 08-24-2016, 07:45 AM   #1 (permalink)
Member # 2775
Priorities are changing in life and looking to build something that is family friendly and street legal. I have had this Toyota since I was 17 in high school and has gone through multiple evolutions.
Registered as a 79 Toyota Pickup with CA Green Sticker
Engine: 87 Chevy 4.3 w/ TBI. Uses a Howell EFI harness that has been completely gone through and repined to clean up the original rats nest. Griffin radiator with Volvo fan controlled by adjustable thermostat.
Drivetrain: W56 Transmission. Dual Cases with 2.28 front & 4.7 Rear, all Trail Gear. RCV Chromoly rear output shaft and triple drilled flanges
Front Axle: GM Dana 60 with welded 4:10 gears and Artec Truss, Yukon Chromoly 35 spline inners and outers with drive slugs and spicer u-joints. 3/4 ton disc brakes. Single ended 8” PSC ram with high steer arms tied into the lower knuckle. Ruffstuff Diff Cover. Toyota driveshaft flange.
Rear Axle: Dana 70-1SU, smooth bottom. Welded 4:10 gears. 3/4 ton disc brakes. Ruffstuff Diff Cover. Toyota driveshaft flange.
Front Suspension: 3 Link with Heretic Fab heat treated lower links. Ruffstuff 1.25” lower and 7/8” upper heims. Fox 14” 2.0 Coil overs with profender coils. 14” 150lbs over 16” 200lbs. FOA Bump stops
Rear Suspension: 63” Chevy ton springs with Johnny Joints. 14” Bilstein 5100s, which probably need to be replaced.
Steering: PSC P-Pump and can with BillyBob13 remote reservoir and filter. Extruded style aluminum cooler. Single ended 8” PSC ram. Unknown orbital.
Tires: 39” KRT-B Stickies on H2 wheels. Have a spare 39” KRT-B Sticky that has a sidewall hole with plugs, needs to be vulcanized but will hold air for a weekend.
Gauges: Autometer Ultra Lite. Water Temp, Oil Pressure, and Tachometer
Tunes: Crawltunes Speaker cans with 6.5” Infinity marine speakers. Compact Pioneer amp under the dash with Aux cord and remote gain knob mounted on the dash.
Lights: Ruffstuff HID headlights and Eyeyourlife 30” Combo LED lightbar. There are also LED rocklights and interior lights on separate switches
Interior: Corbeau Baja Seats with five point harness tied into the frame. Seats are a little tore up as a cat decided to use them as a scratching post a few years back.
All of the electrical has been redone. There is not a single fuse in the vehicle as everything is ran through resettable circuit breakers located on the dash. All switches are laser engraved ARB style switches and are back lit. The only thing the dash needs is a new dash pad as the one that is one there is cracked, that or just a cover. Optimum Redtop with Ruffstuff battery box.
Recently swapped the existing transmission out and went through the replacement and resealed it. Also redid the entire exhaust with v-band clamps for easy removal of the transmission and exhaust system.
Asking 10K or best offer. Located in Loomis, CA. Just north of Sacramento.
Looking for a decent FJ-55, FL-60, or FJ-62. May be open to other options as well
63 Scout 80. 5.3, 4L65E, Atlas II 4.3 on Tons
JJeep74 is online now   Reply With Quote Quick reply to this message
Old 08-26-2016, 10:30 AM   #2 (permalink)
Member # 2775
ttt
Old 08-29-2016, 10:02 PM   #3 (permalink)
Member # 2775
TTT
Old 12-06-2016, 09:46 AM   #4 (permalink)
Member # 2775
Back from vacation, lets get this thing sold.
Old 12-06-2016, 11:35 AM   #5 (permalink)
Member # 142117
Ive got a 1942 gpw on a cj chassis and some good parts...collector plates, street rig and wheeler
I NEED A HARLEY SS175 PISTON!!!!!!!!!!!!!!!!Found and now its time to build a bobber
drewp is offline   Reply With Quote Quick reply to this message
Old 12-06-2016, 12:46 PM   #6 (permalink)
Member # 2775
Looking for something I can fit the family in, thanks for the offer though.
Old 12-11-2016, 04:54 PM   #7 (permalink)
Member # 2775
Also have a set of doors for it.
Old 12-16-2016, 02:24 PM   #8 (permalink)
Member # 2775
SOLD
