Rear Steer Buggy by James Treacy - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Vehicles and Trailers For Sale
Old 08-06-2019, 12:09 PM   #1 (permalink)
Member # 44476
Send a message via MSN to no2hud
Rear Steer Buggy
2016 Twisted Customs NW
Builder:James Treacy
Asking $63,000 or best offer, would make a deal if you had interest in the trailer.
Chassis:
Cab Forward Design
Tube Type DOM (Drawn Over Mandrel)
Tube Sizes 1”, 1.25”, 1.5”, 1.75”
Main Chassis 1.75” x .120 wall
Chassis Base Tubing ?1.75” x .120 with 1.5” x .120 sleeve from front to rear
Drive Train:
Engine: Chevrolet 5.3 LS (Factory)
Transmission - Turbo 350 w/reverse manual valve body
Transfer case - Atlas 2 w/3.8 ratio
Engine Notes - LS1 intake and injectors, Kevko Pan, Truck style tensioner, Truck style alternator,
Factory alternator tensioner w/2001 Chevy Camaro idler pulleys
(OBDII Port, Fuse block, Check engine light under dash on passenger side)
Wire harness: - Schwankee
Fuel Pump - Walbro GSL394BX
Fuel Filter - GM LS V8 Fuel Filter/Fuel Regulator Kit, 58
Fuel Cell - 8 gallon
Suspension:
Type - 4 link ¾”x 7/8” upper rod ends & 1-1/4” lower rod ends
Shocks - ORI Struts – 16”
Air pressure
FT – Upper 275 lbs. Lower – 150 lbs.
RR – Upper 175 lbs. Lower – 150 lbs.
Axles:
Front - SpiderTrax – 3.5” x .250 wall
Rear - SpiderTrax – 3.5” x .250 wall
Differentials - Ft - Mega Hi9 (blue pinion support) w/ 5.40 gear ratio & Yukon Grizzly Locker
RR – Mega Hi9 (black pinion support) w/ 5.40 gear ratio & Yukon Grizzly Locker
Braking System:
Master Cylinder - CNC Brakes
Calipers - Wilwood
Rotors - SpiderTrax Ultimate 6 Lug
Steering:
Pump - PSC – SP33352 XR Series CBR Power Steering Pump -8 out -12 in 1650 PSI
FT & RR Ram - PSC – 2.5” x 10” Stroke
Spare Parts:NEW 42” BFG w/ Trail Gear bead lock, drive shaft, links, NEW Spidertrax - front driver & passenger 300 M complete shaft/joint/stub, NEW Spidertrax - rear 300M complete shaft/joint/stub (fits driver & passenger), 16” ORI Strut, unit bearing, heim joints, and body panels.
Also have a near new 20’ Cross Trailer enclosed trailer for an additional $10,000
no2hud is offline   Reply With Quote Quick reply to this message
Old 08-06-2019, 12:11 PM   #2 (permalink)
Member # 44476
Old 08-06-2019, 12:15 PM   #3 (permalink)
Member # 44476
Old 08-06-2019, 12:17 PM   #4 (permalink)
Member # 44476
Optional Trailer
2017 Cross Trailers - Enclosed V-Nose trailer - 20' x 8.5
Asking $10,000
Would make a great package deal if interested
Old 08-06-2019, 12:18 PM   #5 (permalink)
Member # 44476
Couple videos
https://youtu.be/6jydxQI3ues
https://youtu.be/ELh0WRtIlCQ
Old 08-07-2019, 08:07 PM   #6 (permalink)
Newbie
Member # 591265
Trade for a JK?
wags1 is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 08:05 PM   #7 (permalink)
Member # 44476
Originally Posted by wags1 View Post
Trade for a JK?
Boat or RZR plus cash might work.....
Old 08-12-2019, 06:24 PM   #8 (permalink)
Member # 871664
Wheel base and total width.
four wd is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 05:51 PM   #9 (permalink)
Member # 44476
108” and 83” outside of tire, fits in an enclosed trailer.
Old 08-13-2019, 07:56 PM   #10 (permalink)
Member # 871664
Trying to send you a pm but it doesn't go thru. Definitely would like to talk to you.
Old 08-13-2019, 08:40 PM   #11 (permalink)
Member # 44476
Tried to pm you but something must be wrong with the system. Try me at four zero two 306 zero 2 nine 8. Call or text.
Old 08-16-2019, 07:49 AM   #12 (permalink)
Member # 44476
New price........ $65,000 o.b.o.
Old 08-20-2019, 01:00 PM   #13 (permalink)
Member # 44476
bump
Old 08-26-2019, 12:03 PM   #14 (permalink)
Member # 44476
New price $63,000!!
